MartiniB
FREEDOMTech
Joined
Last visited
Currently
Viewing Forum: Škoda Superb
Everything posted by MartiniB
- Mib3 Map Updates 2024.06
- Radio stations Logos database updates
Replacement Shock Absorbers. Bilstein part number.
@Baggins info on sellers page often is wrong, tested and confirmed part codes are listed in link i posted above (2016 Mk3 & 2023 Mk3.FL)
S3 Winter wheel / brake sizes
add to options list also to 225/55r17, recommending especially for winter usage
Choosing a spare wheel advice needed
-> https://www.briskoda.net/forums/topic/520234-superb-mk3-spare-wheel/#comment-5817816
Head vs Heart: 4x4 or not?
have no info and can't see signs of that - on my previous 220ps usual motor oil temperature were 100°C + - 5°C while on 280ps 110°C + - 5°C
Columbus Map Update problem
by Type-C socket it's Mi3, which don't display any progress bar during update as i used to Type-C adopter to Type-A -> SD Card reader -> SD Card i were able see blinking led on SD Card reader @enoktakenokta browse this thread for additional info -> https://www.briskoda.net/forums/topic/513799-mib3-map-updates-2025/
some things that aren't mentioned in any advertising brochure, 272/280 4x4 will get: 1. bigger brake discs 340/310 front/rear, all rest have 310/298 2. additional radiator for DSG 3. visible exhaust pipes down sides: 1. extra one liter on highway and extra 3 in urban 2. The OEM 18" spare wheel is one of the worst choice, had to replace it i'm not regretting of upgrade from 2016. Mk3 2.0 TSI 220ps FWD Style ODO 5-123 000 km to 2023. Mk3.FL 2.0 TSI 280ps AWD L&K ODO 8-29 000 km . . .
VCDS options on Superb III.FL
-> Memory module for Start-Stop button
- Columbus Map Update 2025 (MIB2 HIGH)
MIB3 map update
@RodDuggan standard behavior 😞 title is half year forward than release, but contents is half year outdated
Suspension info
i can't recommend Bilstein / Febi top mounts, had to replace them -> https://www.briskoda.net/forums/topic/510961-2023-280ps-lk-replaced-2016-220ps-style/page/3/#findComment-5854160
Luggage light
1. yes, white, but less bright if compare to Ali 2. i have no idea, in theory yes
Luggage light
@ile7 click on link above picture
1. try download archive from VW server -> https://www.briskoda.net/forums/topic/527309-columbus-map-update-2025-mib2-high/ 2. cleanup were made in previous release -> https://www.briskoda.net/forums/topic/524024-columbus-map-update-2024-2025-mib2-high/ 3. unpack firstly to local drive and then copy content to SD/USB
Luggage light
Tere! check also bulb in Glove box -> https://www.briskoda.net/forums/topic/393511-what-bulbs-are-fitted-to-the-s3-upgraded-bulb-recommendations/page/20/#findComment-5375416 i also have replaced all incandescent to LEDs and installed few extra on my previous 2016 Mk3 and current 2023 Mk3.FL this warning i saw just once on FL, at first ignition on after replace in glove box, but later msg gone, can't remember now, were the error codes cleaned by OBDEleven places for extra bulbs: -> https://www.briskoda.net/forums/topic/510961-2023-280ps-lk-replaced-2016-220ps-style/page/2/#findComment-5760999 -> https://www.briskoda.net/forums/topic/393511-what-bulbs-are-fitted-to-the-s3-upgraded-bulb-recommendations/page/28/#findComment-5739366
Tyre check indicator
what are you talking about? additionally to TPMS warning comes restriction of cruise control what came as reason to replace OEM -5.3% sized spare to full diameter spare wheel -> https://www.briskoda.net/forums/topic/520234-superb-mk3-spare-wheel/#comment-5817816
Fuel filler. Adding a bottle of additive troubles
-> https://www.briskoda.net/forums/topic/501427-filler-cap-stuck-query/ -> https://www.briskoda.net/forums/topic/507390-fuel-flap-is-stuck-and-wont-open/ -> https://www.briskoda.net/forums/topic/459115-instructions-for-winter-refueling/ . . . . . . board search "fuel flap"
Superb Scout edition harsh suspension
1. it's far away from sport, stiffer for 15-20% 2. that was my goal, get some extra stiffness and avoid lowering 3. no info, haven't met any resource with Bilstein's production sizes like this https://size.name/en/catalog/pruzhiny
@Tonies make picture from the side and compare your's current height to B6 DampTronic + Eibach Pro Kit from Kodiaq -> https://www.briskoda.net/forums/topic/510961-2023-280ps-lk-replaced-2016-220ps-style/?do=findComment&comment=5854160 @mr-t we can manage some test drive in Riga
Mib 1 maps update.
@francescobettazzi -> https://www.briskoda.net/forums/topic/481828-amundsen-mib1-map-update-2020-2021/
Amundsen MIB1 maps update ?
some links are still alive -> https://www.briskoda.net/forums/topic/481828-amundsen-mib1-map-update-2020-2021/
@Balika23 start by this post -> https://www.briskoda.net/forums/topic/510961-2023-280ps-lk-replaced-2016-220ps-style/page/3/#comment-5854160 and dive into several similar, use board search 'dcc suspension'
Front springs
try some stronger -> https://www.briskoda.net/forums/topic/510961-2023-280ps-lk-replaced-2016-220ps-style/page/3/#comment-5854160 rear OEM vs Eibach Pro
Lowering Springs
@Buddxrs i can't suggest what exact springs, but you can use my method - put known parameters of springs into table and compare parameters -> https://www.briskoda.net/forums/topic/510961-2023-280ps-lk-replaced-2016-220ps-style/?do=findComment&comment=5854160
