MartiniB
FREEDOMTech
Everything posted by MartiniB
  1. @francescobettazzi -> https://www.briskoda.net/forums/topic/481828-amundsen-mib1-map-update-2020-2021/
  2. some links are still alive -> https://www.briskoda.net/forums/topic/481828-amundsen-mib1-map-update-2020-2021/
  3. @Balika23 start by this post -> https://www.briskoda.net/forums/topic/510961-2023-280ps-lk-replaced-2016-220ps-style/page/3/#comment-5854160 and dive into several similar, use board search 'dcc suspension'
  4. try some stronger -> https://www.briskoda.net/forums/topic/510961-2023-280ps-lk-replaced-2016-220ps-style/page/3/#comment-5854160 rear OEM vs Eibach Pro
  5. @Buddxrs i can't suggest what exact springs, but you can use my method - put known parameters of springs into table and compare parameters -> https://www.briskoda.net/forums/topic/510961-2023-280ps-lk-replaced-2016-220ps-style/?do=findComment&comment=5854160
  6. content is exactly same
  7. i have sent PM to @ColinD, but this time that doesn't work 😞
  8. by my understanding: B4 - normal B6 - improved performance B8 - improved performance + lowering B14 - track my choice: B6 DampTronic + Eibach Pro Kit from Kodiaq/Tiguan -> https://www.briskoda.net/forums/topic/510961-2023-280ps-lk-replaced-2016-220ps-style/?do=findComment&comment=5854160
  9. @Robbo12 1. try extract to local storage and then copy to SD 2. try download archive from VW's server @JR RS Mib2High archives have been cleaned from unnecessary Mib1 files a lot of questions already have been answered -> https://www.briskoda.net/forums/forum/7-audio-electronics-and-security/
  10. that whole list were done by using OBDEleven 1.Gen as mentioned in the head post of thread
  11. have you installed that system? i have met just one crazy, in the best sense, man here on BS who made that complicated upgrade i prefer alternative, independent of car systems, dTPMS system -> https://www.briskoda.net/forums/topic/434028-tire-pressure-monitoring-system/?do=findComment&comment=5895850
  12. that is the worst choice! you will not know what exactly were changed which in some cases makes it impossible to revert look at known and tested tweaks -> https://www.briskoda.net/forums/topic/516414-vcds-options-on-superb-iiifl/
  13. @PeterSwe Mib3 has no progress bar, my previous Mib2H had P119 isn't latest, scroll two posts above
  14. by first forget about silent suspension on whatever MQB car 😞 as next check out shocks - on my previous 2016. Mk3 220ps FWD front OEM DCC shocks were replaced on 43 kKm left and at 48 kKm right after another 60 kKm, when warranty ended, i replaced to Bilsteins B6 DampTRonic on current 2023. Mk3.FL 280ps AWD i replaced to Bilsteins without waiting warranty ending (details in my signature) another source of rattle was power steering , which were replaced on 21, 45 and 26 kKm for 17" rims i recommending 225/55 OEM Pirellis P7 were loudest i have ever had
  15. SD Card slot -> Mib2 or Mib2.5 High, for Amundsen original card required or some with cloned serial number Type-C port -> Mib3 click on link in my signature, a lot of questions have been already answered
  16. you have downloaded P119 23.12 https://infotainment-cdn.skoda-auto.com/base/maps/OI_P119_EU_202425_Offline_Update.zip while i gave you direct link to P129 24.06 https://infotainment-cdn.skoda-auto.com/base/maps/OI_P129_EU_202448_Offline_Update.zip
  17. download -> extract -> copy to USB/SD -> put into car -> install https://infotainment-cdn.skoda-auto.com/base/maps/OI_P129_EU_202448_Offline_Update.zip where is the problem?
  18. P119 23.12 is latest published on Å koda's portal P129 24.06 is latest available for download open thread i posted above
  19. my crystal ball says, you haven't downloaded the latest, because 24.06 is downloadable just one week long and previous were exactly 23.12 -> https://www.briskoda.net/forums/topic/513799-mib3-map-updates-2025/
  20. in Mk3.FL 2023 Amundsen 8" version date changed after one day, longest trip were about 90 minutes. no progress bar and message about finished operation if compare to my previous Mk3 2016 Columbus 8" 😞 updated from OTA loaded 23.12 to Offline 24.06
