Everything posted by MartiniB
Dcc removal
@Sharkeyboy all part codes are in the link i posted above Bilstein B6 DampTronic 23-254343 front Bilstein B6 DampTronic 20-267537 rear to avoid lowering, choose Eibach Pro springs from weightier MQB: front - Audi Q2 F11-85-043-02-FA or Kodiaq/Tiguan F11-85-043-03-FA rear - ŠS 4x4 F11-79-008-01-HA or Kodiaq F11-79-013-01-RA
Dcc removal
DCC canceler is enough expensive to leave DCC, just go away from OEMs -> https://www.briskoda.net/forums/topic/510961-2023-280ps-lk-replaced-2016-220ps-style/page/3/#comment-5854160
Shock absorber help please
part codes list -> https://www.briskoda.net/forums/topic/510961-2023-280ps-lk-replaced-2016-220ps-style/?do=findComment&comment=5854160
Does the steering wheel from skoda karoq fit the superb?
"View" button will do nothing -> https://www.briskoda.net/forums/topic/459212-stolen-button-from-the-steering-wheel/
- Columbus Map Update 2025 (MIB2 HIGH)
-> next 2025-2026 cross compatible on: Skoda Columbus (Mib2H), Seat Navi Plus (Mib2H), VW Discover Pro (Mib2H), Audi MMI Navigation Plus (Mib2H) # ECE 14.0 GB Version: V03.959.821.AR 390 ECE 2025 DevVersion: P390_N60S5MIBH3_EU_NT_Q1.24 VW portal: https://vw-maps-cdn.lighthouselabs.eu/vw-maps/P390_N60S5MIBH3_EU.7z VW portal: https://navigation-maps.volkswagen.com/vw-maps/P390_N60S5MIBH3_EU.7z Files inside: 2024.04.04 Downloadable: 2024.10.15 Published: 2024.--.-- Škoda portal: https://infotainment-cdn.skoda-auto.com/base/maps/HIGH2_P390_EU_202445.zip Files inside: 2024.04.04 Downloadable: 2024.11.14 Published: 2024.12.0? # Rest of World 14.7 Gb Version: V03.959.821.BB 393 ROW 2025 DevVersion: P393_N60S5MIBH3_ROW_NT_Q1.24 VW portal: https://vw-maps-cdn.lighthouselabs.eu/vw-maps/P393_N60S5MIBH3_ROW.7z VW portal: https://navigation-maps.volkswagen.com/vw-maps/P393_N60S5MIBH3_ROW.7z Files inside: 2024.05.17 Downloadable: 2024.10.15 Published: 2024.--.-- Škoda portal: https://infotainment-cdn.skoda-auto.com/base/maps/HIGH2_P393_ROW_202445.zip Files inside: 2024.05.17 Downloadable: 2024.11.14 Published: 2024.12.0? ======= coverage ======= # EU Albania*, Andorra, Austria, Belarus*, Belgium, Bosnia and Herzegovina*, Bulgaria*, Croatia, Cyprus*, Czech Republic, Denmark, Estonia*, Finland, France, Germany, Gibraltar, Great Britain, Greece, Hungary, Iceland, Ireland, Italy, Kosovo*, Latvia*, Liechtenstein, Lithuania*, Luxembourg, Malta, Moldova*, Monaco, Montenegro*, Netherlands, Northern Macedonia*, Norway, Poland, Portugal, Romania*, Russia*, San Marino, Serbia*, Slovakia, Slovenia*, Spain, Sweden, Switzerland, Turkey*, Ukraine*, Vatican City * partially # ROW Argentina*, Australia, Bahrain, Botswana*, Brazil*, Brunei*, Chile*, Indonesia*, Israel, Jordan, Kuwait, Lesotho*, Malaysia, Mexico*, Mozambique*, Namibia*, New Zealand, Oman, Philippines*, Qatar, Reunion*, Saudi Arabia, Singapore, South Africa, Swaziland*, Thailand*, Turkey*, United Arab Emirates * partially ======= instruction ======= 1. download 7z/zip archive from direct link 2. extract content to SD Card or USB 3. insert memory device into slot of Columbus 4. start of update usually is offered automatically, manually can be found under Navi-> Settings !!! note for MAC users -> https://www.briskoda.net/forums/topic/452002-direct-download-links-for-ece-20182019-maps/page/2/?tab=comments#comment-5095042 couple of potential questions are answered in previous posts: Columbus Maps 2024/2025 Columbus Maps 2024 Columbus Maps 2023/2024 Columbus Maps 2023 Columbus Maps 2022/2023 Columbus Maps 2022 Columbus Maps 2021/2022 Columbus Maps 2021 Columbus Maps 2020/2021 Columbus Maps 2020 monthly POI's collection files downloading from X-o-m-k-a's blog
DRL eyelash activation/boot close with remote
Fifth coding from the top, but doesn't work on FL -> https://www.briskoda.net/forums/topic/516414-vcds-options-on-superb-iiifl/
Superb mk3 Strut Mount recomendations
Febi was definitely wrong choice -> https://www.briskoda.net/forums/topic/510961-2023-280ps-lk-replaced-2016-220ps-style/?do=findComment&comment=5854160 solved by Arteon's OEMs -> https://www.briskoda.net/forums/topic/510961-2023-280ps-lk-replaced-2016-220ps-style/?do=findComment&comment=5883174
Amundsen map upgrade
original(same as cloned) SD has specified hardware id number, which isn't touched at format/erase procedure
Tyre specs 94h / 98V
for 17" i will recommend 225/55r17, which gives: extra 10mm in width extra 5mm in height closer values to reality on speedometer https://www.tireoutlet.com/blog/2969/tire-speed-rating-codes-what-they-mean/ for extra comfort, search models with foam inside tire -> https://www.briskoda.net/forums/topic/447954-tyreroad-noise-advice/?do=findComment&comment=5665235
drl eyelash activation
Mk3 coding doesn't work on Mk3.FL -> https://www.briskoda.net/forums/topic/516414-vcds-options-on-superb-iiifl/ i haven't met another 😞
Dynamic indicators disappointment
your FL covers looks different to mine 2023 Mk3.FL, which are exactly same as 2016 Mk3, just blind spot indicator migrated from mirror to body
+2 when i ordered for 2016 Mk3, by first i received MB 212 model, what were wrote on the box, after contact to seller i got correct one next were ordered for 2023 Mk3.FL -> https://www.briskoda.net/forums/topic/393511-what-bulbs-are-fitted-to-the-s3-upgraded-bulb-recommendations/?do=findComment&comment=5740228 check the part code printed on device
Front springs for 2.0 tdi laurin and klement.
by your pictures aren't visible, they are DCC or not, maybe you can save a lot if they aren't, i would suggest Bilstein or Koni instead Monroe pictures of DCC version
5WA 412 331 A + 5Q0 412 249 E were ordered from local VW dealer, 132 euros for both sides have to agree @J.R. replacement of springs, dampers or top mounts will cost almost equal, better replace them all together
@gidi19 together with springs replace also top mounts, to Mk3.FL version (optional, to Arteon version) -> https://www.briskoda.net/forums/topic/510961-2023-280ps-lk-replaced-2016-220ps-style/?do=findComment&comment=5883174 I'm not alone in this opinion - OEM springs are too soft for Superb -> https://www.briskoda.net/forums/topic/510961-2023-280ps-lk-replaced-2016-220ps-style/?do=findComment&comment=5854160
MySkoda App can't add new car
No
~ 2023 03 It worked fine, now it also displays state, fuel, doors etc. but on ulock attempt, after pin, comes err msg
Android app also can't unlock doors remotely 😞 ŠS Mk3.FL 2023
Superb 280 Top Mounts
@Steviedakota Depends on compare to what -> https://www.briskoda.net/forums/topic/510961-2023-280ps-lk-replaced-2016-220ps-style/?do=findComment&comment=5883174
Replacement Shock Absorbers. Bilstein part number.
confirmed in practice -> https://www.briskoda.net/forums/topic/510961-2023-280ps-lk-replaced-2016-220ps-style/?do=findComment&comment=5854160
2023 280ps L&K replaced 2016 220ps Style
Arteon's OEM 5WA 412 331 A + Superb's OEM 5Q0 412 249 E have been installed! i can't confirm improvement in compare to OEM 5Q0 412 331 E because few months between installation and current Eibach Pro springs are about 15% stiffer than OEMs were, but definitely, they are better than my wrongly made side step FEBI 40171 + FEBI 44799 Superb's OEM 5Q0 412 331 E Arteon's OEM 5WA 412 331 A sits ~ 2mm deeper
Red avoid, green current setup Click on link above for details
i did side step and weren't happy about result - together with Eibach Pro + Bilstein B6 Damptronic were replaced also top mounts: Front FEBI 40171 + FEBI 44799 which i replaced later to Arteon's OEM 5WA 412 331 A + Superb's OEM 5Q0 412 249 E Rear Bilstein 12-281459 i had to replace to old used OEM 5Q0 513 353 E
What bulbs are fitted to the S3 & upgraded bulb recommendations
originally trunk bulbs are only two no matter hatch or wagon, hatch have them in trunk, while wagon in cover. additional two bulbs in hatch's cover were my idea different type of bulb body comes in glovebox -> https://www.briskoda.net/forums/topic/393511-what-bulbs-are-fitted-to-the-s3-upgraded-bulb-recommendations/?do=findComment&comment=5375416 door's warning light also have different type bulb bodies -> https://www.briskoda.net/forums/topic/393511-what-bulbs-are-fitted-to-the-s3-upgraded-bulb-recommendations/?do=findComment&comment=5168994
