MartiniB
FREEDOMTech
Everything posted by MartiniB
  1. why everyone focusing on inches of disk? while more important is what size of tire is mounted on it. 16" can be used even on 280/272, which have bigger brakes, just install spare wheel on the right place - rear axle yes, double procedure if damaged front, but it's lot safer to leave normal tire on the front axle
  2. depends on where problem has come, i weren't happy keep 80kmh manually for ~80km distance on highway another must have is DIRECT Tire Pressure Monitoring System -> https://www.briskoda.net/forums/topic/434028-tire-pressure-monitoring-system/?tab=comments#comment-4893182
  3. just few posts above i posted size comparison, with that huge (-5.3%) diameter diff car will not able activation of Cruise Control visit https://tiresize.com/comparison/
  4. Me too have used to stock 205/55r16 spare wheel just for ~80km, mounted on two line higway ~20 min PM And as i wrote above, that ~80km without Cruise Control were enough big motivation to replace rubber by 205/65r16 I don't think there will be a lot alternative tire sizes for 18" disk
  5. What benefit has 18"?
  6. @Rednut looks like Mib2 High, but i can be wrong. another guess, not all regions have got enabled life time updates, like Audi and Seat owners can upload updates just first few years https://www.seatcupra.net/forums/resources/updating-the-inbuilt-mib2-satnav-mib2-tricks-and-lost-mib1-card-solution.60/ https://www.seatcupra.net/forums/threads/ready-reckoner-on-the-limits-of-mib2-high-plus-updates-can-be-made.457561/ p.s. try copy files from SD card back to PC and compare content, there are couple of cases when fake SD cards are declared as big size while they are lot smaller
  7. size of disk is less important than size of tire 16" can be installed even on 280/272 version, just install it on correct place - rear axle stock size of spare wheel's rubber is lot smaller than normal tire and that disables usage of cruise control
  8. compared to Amundsen? asking cause 2016 8" Columbus has that option + subwoofer level thinking about new, but can't accept new 10" Columbus hasn't real volume lever interesting, what i will lose on swap 2016 8" Columbus to 2021 8" Amundsen . . . Canton is must have
  9. then you need files from Amundsen (VW's Discover Media 2) -> https://www.briskoda.net/forums/topic/486988-amundsen-mib2-map-updates-2021/ and these will work only from original SD card 26GB file is for Columbus (VW's Discover Media Pro) which can be uploaded into Columbus from any SD Card or USB flash
  10. show maps version info for Mib2H can be used even USB flash
  11. @batemansxxxb try links from Columbus tread
  12. Absolutely, even for same model, Superb III in my case, Eibach offers different springs for different weights. In case i don't like lowering, but would like to have stiffer springs, i going to install springs from 2.0 TSI AWD on mine 2.0 TSI FWD car, just one problem, i have managed to find right number for rear axle F11-15-007-04-HA (-45mm on AWD; -30mm on FWD) F11-79-008-01-HA (-30mm on AWD; -5mm on FWD) but which for front axle? F11-85-043-01-FA or F11-85-043-02-FA this guess has been made from these datasheets -> Tuv certificate F11-85-042-03-FA -> Tuv certificate F11-85-043-02-FA compare by size compare by weight
  13. please share Your opinion and part codes
  14. search for DCC cancellation kit or install cheaper with better performance -> Bilstein B6 DampTronic
  15. ^^^ @KeteCantek oh sorry, my English is far from perfect and Google Translate doesn't help in all cases in one of posts above i made guess, new 280ps can be old DSG6, but You answered it's a 7
  16. just two problems 1. waiting time 6+ months 2. for 280ps no discounts possible, while all others can get 20%, as result huge lose in aftermarket - start price diff is 30k euros vs 49k :(
  17. in case i own Columbus Mib2H, nothing of following have been tested, just some info: 1. there are SD cards which's ID can be changed, don't ask details 2. there are modified firmwares where are accepted side SD cards read with Google Translate -> RNS 310 -> RNS 510
  18. few times a year i have false TPMS warnings reported by car, but now no need to guess where is problem, after have installed Direct TPMS and there is info how does pressure is changing according conditions change
  19. then yes, BUT In light of Brexit it can be old DSG6, which is still in use in other non EU countries Latvian online configurator recently has lost 4x4 for 2.0TSI, similar were reported about Sweden :(
  20. @JayB_UK can You add some clearness there
  21. more interesting is, what DSG model it come with old 280ps - DSG6 DQ250 272ps - DSG7 DQ381 new 280ps - DSG? DQ???, is that new 280ps realy new? because non EU markets, as example in Russia, haven't seen yet 272ps version this tread must be merged to Did the 280ps Superb ever get the DQ381 7-speed DSG?
  22. @Wheelnut download archive to PC and then extract content to SD Card or USB https://www.briskoda.net/forums/topic/486625-columbus-map-update-2021-mib12-high/
  23. that method worked perfectly with Passat B7, all newer VAGs stops engine lot faster :( i have installed Start-Stop Memory module for automatic deactivating without completely disable it
