Everything posted by nige8021
2022 F1
It's just the Welshman that is an embarressment, he just thinks he's a funny comedian, asks inappropriate questions and then buts in when someone who has genuine knowledge asks a question with some inane comments and you can see the face of the team principal or driver "who is this idiot"
how can i test the rev counter?
On the MK1 it is the gearbox sensor according to the wiring diagrams but the OP has a 2008 MK2 and on that it's either the gearbox sensor or if fitted ABS
Engine oil level creeps up the dipstick on BBZ
Looking at the parts listing it does look like @Pete_Ex-Wino photo with the O ring #13 sealing onto the engine block ?
The RPM & coolant temperature are sent via the engine ECU on the CANbus drive network, the vehicle speed and fuel quantity are analogue inputs into the speedo unit however if the car has ABS then the vehicle speed is also via the CANbus via the ABS control unit
Fuel lines?
Same filter housing on my Treg I just put the new filter in and filled it with Moly Purge refitted the top and started no problem
Pipe to power steering pump split leaking fluid
Might also pay to call/email these guys https://www.stevensvwspares.com/
Fuel lines?
Looking at your picture the filter doesn't look like it's been touched in a while ? might pay to replace the filter element ?
With VCDS in section 17 (Instruments) the output tests should drive the needle to prove the instrument motor is ok
Fuel lines?
But a bit further in the manual it shows two different outlet pipe configs Fuel filter upper part, type A 1 -8 Nm 2 -(Not necessarily installed) plug for water extraction (unscrew and extract about 100 cm3 liquid using diesel extractor -VAS 5226- (renew seal). 3 -Fuel supply line from fuel tank, white or white marking. Ensure secure seating. 4 -Fuel return line to fuel tank, blue or blue marking. Ensure secure seating. 5 -Fuel supply line to engine, white or white marking. Ensure secure seating. 6 -Fuel return line from engine, blue or blue marking. Ensure secure seating. Fuel filter upper part, type B 1 -5 Nm 2 -Fuel return line to fuel tank, blue or blue marking. Ensure secure seating. 3 -Fuel supply line from fuel tank, white or white marking. Ensure secure seating. 4 -Fuel return line from engine, blue or blue marking. Ensure secure seating. 5 -Fuel supply line to engine, white or white marking. Ensure secure seating.
You'll be hard pressed to do that on my current car (VW Touareg) no dipstick fitted just the empty tube, only way to check the level is via the info screen and only after the oil is at working temperature and if it's empty it's a bit late to find out, that's why I bought a dipstick from a Q7 at least I can now check the level before the engine makes a horrible noise
2022 F1
Perez & Leclerc topped todays practice, Merc's 1.2 & 1.6 seconds off the pace Good news for the Ch4 coverage looks like it's Lee McKenzie back as lead presenter for this race
The other option could be a mobile hydraulic hose company like https://www.pirtek.co.uk/services/
M1 is the vehicle approval category not it's MK # that goes on the year of manufacture in your profile you state 2007 so it's that what makes it a MK1
Mudflaps fixings
No mention of any fittings in this listing https://skoda.7zap.com/en/cz/octavia/oct/2009-663/0/071-71050/ ??
Rear wiper - how many times should it sweep?
First thing would be to take it to a good independant VAG garage who have trained mechanics not halfrauds 🐵
2012 octavia mkii cr tdi won't start
As it's ex Ambulance it might of had the wiring modified for "Run-Lock" ??
Cam belt change CYVB engine 1.2 Tsi
Special tools and workshop equipment required t Torque wrench -VAS 6583- t Counterhold -T10172- with adapter -T10172/1- t Locking pin -T10340- t Counterhold -T10475- t Special wrench, 30mm -T10499- t Socket -T10500- t Camshaft clamp -T10494- t Assembly tool -T10487- t Release tool -T10527- and release tool -T10527/1- t Screwdriver with minimum shaft length of 250 mm (not illustrated) That's from the dealer manual for the same engine as fitted in a 2017 Golf
Identify this pneumatic connection ?
I want to purchase a couple of replacements if possible to make up some custom adapters, for a non automotive project and still use the Sealey hand pump unit
Roomster 2009 door locks
Blue/Red & Blue/Purple are the wires going to the motor on the body side of the 28 pin disconnect
That looks the closest but physically much bigger according to the PDF Those are the standard "Euro" connectors, I have these on my compressor and they don't mate with the unkown fitting
Cassette Deck Belts - who can replace 'em?
I used to have a rolls of O ring type rubber various diameters, that I used to repair numerous VCR's just cut a length off and superglue the ends together, I think I bought them from Tandy/Maplins ?
Can anyone identify this pneumatic connector type, it's on a Sealey coolant system pressure test kit, they use the same connectors on their Turbo pressure test kit, I've contacted Sealey and they say they have no idea of what type of connector is fitted which seems a bit odd ? A Google picture search only came back with a lighthouse !! and searching for "pneumatic quick release couplings" hasn't found anything yet
Radio code
I've used this guy before https://www.ebay.co.uk/itm/323738029964?hash=item4b604a4f8c:g:2A8AAOSwlThcK53c
Warning lights,
You will need to code the system to tell it you have LED's and to do that you'll need VCDS or Carista/OBD11
Warning lights,
Have you replaced any of the bulbs with LED equivalents ? as they require a much lower current to work, so the system thinks the bulb has blown
