Everything posted by AGFalco
Power issues
Is it's a 110bhp 1.0 TSI engine? When were the spark plugs changed? Thanks. AG Falco
DSG for 1.0 tsi Estate ?
Cheaper RFL stopped on 1st April 2017, so you need one before this date. Thanks. AG Falco
Power issues
Normal engine protection. Any warning lights? Is the engine running normally? What is your normal MPG then? When were the Spark plugs changed? Presume this is a 1.0 TSI. 16K is very little mileage for a 2019 car. Thanks. AG Falco
Looking for LED light bulbs for the reflectors of my fabia mk3
In the photo I can see what looks like two reflectors , but can only see the top of the outer bulb. The bulb looks like the end of either an H7 or an H4. I can't see enough of the bulb to confirm, hence why I asked for a photo. There is still the possibility that the second reflector could use an H1 bulb. These can be used for main beam which is normally the in the inner position. HTH Thanks. AG Falco
Oil consumption
Get them to check with TPS on what oil's are listed for your engine. Thanks. AG Falco
Oil consumption
My VW UP had it's first service last month on a VW service plan. The car is recommended to use 0W-20, VW 508 / 509. Did manage to get them to use VW 504 / VW 507 oil though. This is a better oil to use long term and is a 5W- 30 C3 oil and not the usual VW 508 / VW 509 0W-20 C5 oil. They did ask a few questions but I took some printed information in with me just in case. After explaining, all good and without invalidating the warranty. Thanks. AG Falco
New to the Mk1V Fabia
Done that to one of mine with OBDeleven. Thanks. AG Falco
Skoda manual pages 186 to 190 for headlight bulbs. H8 are for the front fog lights if you have them. Thanks. AG Falco
It's even easier than that. Look at you headlight units. If you only have 1 bulb and one reflector each side, you have 2 H4 bulbs, and the bulbs have 3 connectors on the back. If you have two bulbs and two reflectors each side , you have 4 H7 bulbs , and the bulbs have 2 connectors on the back. Some Fabia's ( like mine ) have one projector on the outside and one reflector on the inside. The projector one has a big lens in front of the bulb and you can't see the bulb, this is for dipped beam. The inner reflector one is for main beam. HTH Thanks. AG Falco
Tyre Pressure Warning Playing up
But the warning light should come on when you turn the ignition on to demonstrate that the warning light works. It then self tests just the system ( not the pressures ) and should then go off unless you have a fault. Thanks. AG Falco
Fabia III's can come with H4, or H7 headlights from the factory. The H7's were a cost option when I ordered mine. Thanks. AG Falco
Tyre pressures are not checked on start up as the TPMS system is passive. You need to start driving the car for it to notice a problem with low pressures. Thanks. AG Falco
So, What Would YOU Do, With This Heap?
Was wondering if there is a software problem / tailgate latch that is draining the battery. Had one car where the soft touch boot release button was stuck in the ' to open the boot ' position. This in turn drained the battery. @Throw_Rope Do you lock the car when it is not being used? Thanks. AG Falco
If the tailgate latch thinks that the boot lid is open it will turn on the boot light which will flatten your battery. As I said before:- Try the page button then use the scroll wheel? Thanks. AG Falco
Want a photo of the bulbs. Look like H7's? If so just use these:- https://www.amazon.co.uk/gp/product/B07FXRDJV7/ref=ppx_yo_dt_b_search_asin_title?ie=UTF8&th=1 Thanks. AG Falco
Brake fluid change price ..........
Check if the OBDeleven one will do it? https://obdeleven.com/supported-vehicles?BMW Probably cheaper than BMW would charge you to change the brake fluid. 😀 Thanks. AG Falco
Trolley jack reccomendations and ones to avoid.
I have this one:- https://www.sgs-engineering.com/tj3x-3-ton-trolley-jack Works well for me. It is cheaper to order direct than through ebay. Thanks. AG Falco
Replacing 16" wheels with 15"
I have four 15 x 6 inch wheels? PM me for more info. Thanks. AG Falco
Flat battery then EPC light followed by eml P334B, 11824, 16712
If it is a 2013 Fabia then it is a MK II ? The engine doesn't look like a MK III TSI. Thanks. AG Falco
European Headlight Adjustment for Fabia Mk III
If you have the 4 x H7 headlamp type unit then:- You want to remove the rear bulb rubber covers from the dipped beam bulbs. These are the outer two which are almost under the wing. Then look for the small silver lever. Are your photos of the inner two main beam bulbs? Thanks. AG Falco
Mpg adjustment
So, less than 1%. Don't forget that the larger wheels/tyres will also increase you fuel consumption. Thanks. AG Falco
Oil consumption
Yes. No. 5W-30 C3 is an option! My 2023 UP had it's first service 2 weeks ago. 5W-30 C3 is an option to fit to my car, when it lists 0W-20 C5 as recommended. I asked them to fit the 5W-30 C3 oil. They did double check with me before doing it. ( I took some info in with me. ) They did note this on the invoice/worksheet. I have also changed the oil sticked under the bonnet to note the oil now fitted. All good. Thanks. AG Falco
Citigo AC Condenser pipe - A Kings Ransom..
Does it look like this:- https://www.stevensvwspares.com/vw-up-air-con-pipes/1-0-air-condenser-pipe Thanks. AG Falco
the truth about electric cars
A lot of diesels need priming first. Some are right Ba rds to do. Thanks. AG Falco
Gear selector showing the wrong gear on dashboard, and stop/start not working.
Except reverse.? Thanks. AG Falco
