AGFalco
Everything posted by AGFalco
  1. You DON'T have the type of headlight unit that you have circled. You have the 4 H7 headlight projector bulb type units with the LED DRL / side lights. The two inner ones that you can see are the main beam ones in the reflector. The two outer ones are behind the projector lens are the two dipped beam ones. You cannot see the bulbs from the front of the car. You need to remove cover E to get to the dipped beam bulbs. See my finger pointing to the drivers side cover here. These are underneath the wing / bonnet area as opposed to in the engine bay. Thanks. AG Falco
  2. How many wires are on the connector that fits on the bulb/bulbs? What about a photo of your headlight units? See below for the two types of headlight units:- So back to my question? Thanks. AG Falco
  3. That's an H4 bulbs with three connectors on the back, and two filaments inside, like this:- Thanks. AG Falco
  4. So the two outer H7 bulbs are the dipped ones, and the two inner H7 bulbs are the main beam bulbs. Have you tried to swap the dipped bulb with the main beam bulb? Is there any voltage in the double connection for the outer dipped beam bulbs? Thanks. AG Falco
  5. Have you got the 2 x H4 bulb or the 4 x H7 bulb set up for your headlights? Fuses 4, 8 & 14? Thanks. AG Falco
  6. https://e-heko.com/en_GB/p/Winter-cover-SKODA-Fabia-I-2000-2007/5049 Might be out of stock though. Thanks. AG Falco
  7. Try turning the Bluetooth OFF. Thanks. AG Falco
  8. If you PM me the registration number, I can try and get some more details for you. Thanks. AG Falco
  9. Many things:- Normally accompanied for a short time by a message in the MDF and further info on the Car section of the Infotainment screen. Might have not gone though. Car Manuals are available on line to download. Thanks. AG Falco
  10. Ninth Service and sixth MOT done last week. MOT is good with no advisories. Last years advisory was for the front lower suspension arm rear bushes which I have already replaced. Have noticed some bad wear on the drivers footwell carpet mat in two places. Going to have to ask the driver ( me ) to start lifting his heels of the floor. 😀 Service and Inspection warning reset. Updated service record on Erwin. Scanned for faults none showing. Nothing else noted. Car still good. Thanks. AG Falco
  11. Four 1 litre engines are fitted to the 2015-2021 Fabia III:- 1.0 MPI 60 PS. 1.0 MPI 75 PS. 1.0 TSI 95PS & 1.0TSI 110 PS Thanks. AG Falco
  12. Correct. Thanks. AG Falco
  13. Yes, counterfeits are around. You could try a motor factors like:- https://www.gsfcarparts.com/za049083?auto_apply_coupon=ROAD10&gad_source=1&gclid=Cj0KCQjw3ZayBhDRARIsAPWzx8pDz2sF_f2iAz3BS-uxFZakxsPBN-Z0CXOXcRp6tag822YHGMOc_2saAkKoEALw_wcB&ibt=1 They do last 4 years / 40K miles though. Thanks. AG Falco
  14. NGK 93231 PZKER7B8EGS spark plugs are what fit my 2016 TSI Fabia III. Thanks. AG Falco
  15. Don't use moths. 😮 Been running mine on Tesco Momentum for the last six months, good. Will be changing the spark plugs again this month as it is due it's 8th service. Thanks. AG Falco
  16. Yes it will learn, but it is better for the battery long term if you do reset it. The car as a whole has done very well. MOT and 8th service to do this month. Thanks. AG Falco
  17. After removing the air filter housing there are 4 black square blocks with one 10 mm bolt and one electrical connector to the side. Remove connector, then remove bolt from metal sleeve in one corner of the block, see above. Pull coil pack straight up. I didn't need any special tools. Spark plug is a long way down a small hole. See this thread with photos on another forum where they had issues:- https://www.upownersclub.co.uk/threads/how-to-remove-ignition-coil-units-with-pics.9299/ Thanks. AG Falco
  18. Good. 👍 It will try and charge the battery more than the old one was being charged to. I am still on the original battery at 8 years old and 81K miles on my Fabia. Thanks. AG Falco
  19. Spark plugs due at 4th service / 40K miles. Thanks. AG Falco
  20. Where are you? I am in North Dorset and I can code for beer money. Are you connecting the charger to both battery terminals? Thanks. AG Falco
  21. Correct. OBDELEVEN. I can still turn it on or off with a dedicated switch on the dash, so easy enough. No motorways in any of Dorset. Nearest to me is 45 miles away. Might use it one day. Thanks. AG Falco
  22. Bought a 2023 VW UP last year. This also has the gear change recommendation display which is always suggesting you change up much too early. The same system in my 2018 Skoda Citigo and 2016 Skoda Fabia is more realistic. The lane assist in the UP is on by default whenever you turn the ignition on. But around where I drive ( North Dorset country roads ) it was so annoying/dangerous, I have made it so it now remembers the last state it was in. It has now been off for 4 months. Thanks. AG Falco
  23. This help:- Thanks. AG Falco
  24. This could be brakes, but could also be play in the rear bushes on the lower front suspension arms. Figures look good. A slight thrust angle from the rear axle but well within tolerance. Since it has been pulling from before you had new tyres this would make me think it is not a tyre problem. I have had to replace mine on a 2016 Fabia. The rubber had separated from the metal outer rings. See here:- Does the car drive straight ahead if you hold the steering wheel straight? Does the car pull left when you drive in the left hand side of a two lane road? EG when you are overtaking on a dual carriageway. Thanks. AG Falco
  25. Do you have a printout of the Alignment results? Were all four tyres exactly the same and with the same correct tyre pressure? Are the lower front arm, rear bushes good? Thanks. AG Falco
