AGFalco
Everything posted by AGFalco
  1. No. Yes. Only on Dipped & main Beam not side lights. Yes. Thanks. AG Falco
  2. With mine if the stop/starts cuts in I can restart the engine by turning the heater fan up to three and putting the AC on. So having the AC / fan on can stop it working as well. Thanks. AG Falco
  3. So do you have a warning light on now? Thanks. AG Falco
  4. If both the handbrake/parking brake was not on and the foot brake not on then the wheel should spin freely. Brake shoes on the rear are inside the drum. Look here:- Thanks. AG Falco
  5. It won't always work. After a 12 mile trip home it never works outside my house. But after 10 miles in the morning it normally works if I stop at some lights. 🥺 Battery was good when I tested it. Car does need to learn the new battery. It will try to charge it more than it charged the old one. Did Skoda do a scan for faults when you were there? Beginning to think that the Bolero problem is a different one. Do you know why the Bolero/car bongs? Thanks. AG Falco
  6. When the fuel cap is locked the fuel cap will spin freely in both directions on mine? When it is unlocked you twist it anticlockwise to remove it. Thanks. AG Falco
  7. Is the brake stuck on at that wheel position then? Brake dust? No pictures here? Thanks. AG Falco
  8. Some times if there is no power to the car during a battery change the car can 'forget' things. As you know even with the ignition off the Bolero system is still powered. Thanks. AG Falco
  9. Fingers crossed. 🤞 Did the garage that fitted the battery use a memory / code saver power supply in the OBD2 port when changing the battery? Thanks. AG Falco
  10. Some non Skoda garages can update the digital service history on ERWIN but they have to registrar / pay to do it. It is just as good to have all the invoices from any service work that has been done. Have heard of this before. I have removed / refitted coil packs from my cars and had no problems at all. There are special coil pack removal tools, and clips on youtube on how to get any stubborn ones out. middle one? Thanks. AG Falco
  11. Anything found / solved by them? Thanks. AG Falco
  12. Some thing like this help:- https://www.amazon.co.uk/LINDY-Premium-Audio-Cable-Female/dp/B01MXN0TZ1 Thanks. AG Falco
  13. Sounds like a talk with Skoda would be a good idea. There are good small sound boxes you could use with your portable CD player. Ask if it comes to that. Thanks. AG Falco
  14. Have you tried this? Thanks. AG Falco
  15. Battery goes flat quicker. Thanks. AG Falco
  16. A second scan to see if an codes are now present might give us a clue, but see below. Always worth doing first. Please keep us posted. If all else fails I have a big hammer to do some reprogramming with. 😉 Thanks. AG Falco
  17. All my All season tyres have the TPMSS ( Three Peak Mountain Snowflake Symbol ) on them. Thanks. AG Falco
  18. Battery tested and shows all good, with 12.9 V at rest and 14.9 V engine running. Battery now coded. Car also scanned for any faults, three old ones now cleared. Hopefully we will hear if this was successful from the OP. Thanks. AG Falco
  19. 4 Cars:- One runs just summers all year round. One runs summers and all season in the winter. Two run just all season all year. I did run one with summers and winters for 5 years. Down South in North Dorset the all seasons are more than up to the job in the winter. Thanks. AG Falco
  20. PM send. Thanks. AG Falco
  21. Only a delivery inspection in 2016 and an oil service at 57K miles in 2021, done in different places. Thanks. AG Falco
  22. Do you want me to code it for you? With OBDEleven. I charge Beer Money. Thanks AG Falco
  23. Where in Dorset are you? Thanks AG Falco From N Dorset.
  24. A Citigo / UP cabin filter flap/cover looks like this:- The LHS of this photo is towards the front of the car and the RHS is just behind the bottom of the glovebox looking up from the passenger footwell. Note, your car also doesn't have the fresh air / recycle lever like below. Thanks. AG Falco
