AGFalco
Everything posted by AGFalco
  1. My one does that. Fabia III 1.2 TSI Petrol. Thanks. AG Falco
  2. Some more clues please. EG+:- With engine running? After you turn the engine off? While driving? While turning? What engine? Thanks. AG Falco
  3. Some Fabia III's also come with 185 60 15 H. In 205 55 16 size V is very common and normally cheaper the H so def go for V's. Thanks. AG Falco
  4. Also a customer of them and more than happy.😃 Are you going to them in Quintdown? Thanks. AG Falco
  5. I think the sensor on the bottom of the sump. Is the heat shield there? Undertray? Thanks. AG Falco
  6. Have you physically checked the oil level? Thanks. AG Falco
  7. Did they ( service dept ) check the strength / at what temperature it will freeze? Mine at 2016 is still good. I have not had to top it up at all from new. Thanks. AG Falco
  8. Does it say which tyre it is on the infotainment system? Start by checking ALL the tyre pressures when the tyres are cold, and then reset the TPMS system. Then check the pressures in a week or if/when the TPMS warning comes back on. Thanks. AG Falco
  9. The handbrake only uses the rear brakes so try that and if you here the noise then look at the rear. The inside disk face is normally worse for rust than the outer face. Thanks. AG Falco
  10. What does it say on the tyre pressure sticker plate? 205 40 17 does come up as an option. Thanks. AG Falco
  11. Is this on a Fabia III or your Octavia? Is it the state of your mobile phone battery? This only shows when your phone is connected to the infotainment system. Thanks. AG Falco
  12. Is it the same as last December? What were the fault codes from that? Thanks. AG Falco
  13. Same here. That is what I have in my Citigo. Are the headlights adjusted as both my Skoda's and the VW needed adjusting the beam up to make them work well. Thanks. AG Falco
  14. My Citigo has the best headlights out of the 4 cars I have. But all of them have Osram Nightbreakers in them. Thanks. AG Falco
  15. Facelift Citigo's like my 2018 use 4 x H7 bulbs. Is it a facelift one? Thanks. AG Faclo
  16. This? :- https://www.lllparts.co.uk/catalogs/skoda/CZ/SUP/632/8/837/837060 Or this? :- https://www.google.com/search?q=3T0837901B&rlz=1C1CHBF_en-GBGB917GB917&sourceid=chrome&ie=UTF-8#vhid=E6sTjqbTs4cUcM&vssid=l Thanks. AG Falco
  17. Check the MOT history. Check the Skoda Service history on ERWIN at a Skoda dealership. Number of previous owners and how long any owner has had the car. Thanks. AG Falco
  18. I presume this didn't solve the problems? Did the new battery get coded? What fault codes did the car have? Thanks. AG Falco
  19. Is this in a Fabia III or in your 2014 Octavia? Or was it Front Assist? Thanks. AG Falco
  20. Has the service been done? Thanks. AG Falco
  21. Wind noise is good with mine. Nothing to note or pick out for wind noise. Engine only noisy when being used. ( hard and fast ) What DB rating are the tyres that you have fitted to the car? Thanks. AG Falco
  22. Any one or all? Yes , smaller cars can be more noisy. Smaller engine as well. Thanks. AG Falco
  23. Compared to what? What size tyres have you got? What mileage is it at? Thanks. AG Falco
  24. Sorry different Swing to mine. Have you tried to post in the Fabia II section? Thanks. AG Falco.
  25. Correct, forgot to mention that bit. Thanks. AG Falco
