AGFalco
Everything posted by AGFalco
  1. Yes, but not by much. Thanks. AG Falco
  2. I have had my Fabia III 1.2 TSI 90 4 cylinder from new in June 2016. Now at 70,000 miles and still good. Due its 8th service soon. I have posted my service history up on this site. 55 MPG from the last tank, filled up yesterday. Does better than my 1.0 MPI 3 cylinder Skoda Citigo. 😮 I hired a 1.0 TSI 90 3 cylinder in 2019 for 10 days / 1000 miles. Both engines are good, with very little difference between them. Both produce good low down torque. Both sweet engines. Both punch above their weight. Both similar to the Ford Eco boost engine, especially the 3 cylinder TSI. Same engine. The 110PS have the 6 speed gearbox. The road tax changed in April 2017. Before April 2017 they are £20.00 per annum. After April they are £165.00 per annum. The heaviest Fabia III is lighter than the Heaviest Fabia II. Try first. Thanks. AG Falco
  3. RHS support arm. Thanks. AG Falco
  4. This is what has been done on my Fabia, servicing wise. Thanks. AG Falco
  5. Get your Independent to test/check the brake fluid. Doubt it needs doing. Don't waste your money on the fuel treatment. In your bio it has:- Year 2022 Is this the total milage on the car or since you have had it? Thanks. AG Falco
  6. My 2016 1.2 TSI does NOT make that noise. Car at 70 K miles / 110 K Kms. Thanks. AG Falco
  7. Exhaust heat shield loose? After driving through a puddle/water. Thanks. AG Falco
  8. What does it display? Do you have buttons on the steering wheel? Thanks. AG Falco
  9. Yesterday the GoGo had it's MOT and 5th Service. MOT straight through with car now up to 44 K miles. 5th service is just a small oil and filter service and a check over, Bosch P7143 oil filter less than a tenner. Needed to buy 20 Litres of oil as I was almost out. The oil I buy will go in all three of my cars so I buy in bulk. Battery still good, brake fluid good and antifreeze/coolant good. Reset Service/Inspection light and updated electronic service record via Skoda Erwin. Will change back to summer tyres in about a month. Car still good. Thanks. AG Falco
  10. You use different oil depending on if you are on Fixed ( Normal ) or Variable ( Flexible ) Servicing regime. See Here:- https://www.commaoil.com/products/results/91098390 Would indicate you are on a Variable ( Flexible ) Servicing regime. Or use VW standard 502 00 and VW standard 505 00 If you are on Fixed ( Normal ) Servicing regime. Thanks. AG Falco
  11. Will the selling garage do it? Thanks. AG Falco
  12. Assume these will want doing by next mot in December 2024. Can be 2 hours labour and get the alignment checked after. Asymmetrical tyres fitted the wrong way round. What make are the front tyres? Look at all the mot history. CRUISE, PARK PILOT, Check these are fitted. Advert lists:- SmartLink Bolero Radio This can be looked at with just a 10 mm socket. Thanks. AG Falco
  13. Have you seen the service and MOT history? Check the photo's and the spec... Thanks. AG Falco
  14. Same spec and age as mine and mine has it. The infotainment system looks like Bolero so it should have it. Thanks. AG Falco
  15. Centre of the dash. 😏 Thanks. AG Falco Swing low. Bolero mid. Columbus high.
  16. Bent after going through a puddle? Engine moves more when under load, enough to touch. Thanks. AG Falco
  17. The only problems I have had with the Vredestein tyres in the snow / ice / cold is:- Got to work one day and exited the car then fell straight over on the ice. 😒 Being told: 'If I can't drive my £60k 4x4 up this hill then there is no way your Citigo will get up there.' 😁 Being followed by other cars with them thinking they can drive as fast as me. 1 Range Rover went up the bank to the side of the road. 1 Honda Civic went through a metal fence. You need to make allowances for your ability to stop quicker than any following car. Did drive down one road where the snow was so deep that the front wheels were lifted off the ground. Just turned the steering and reversed out. Thanks. AG Falco
  18. Fitted Osram night breaker laser in both of my Skoda's and the Panda I have. Good improvement with these. Thanks. AG Falco
  19. Just start the engine but not drive it, but....... This would suggest the noise is rotational, eg from the transmission, gearbox, wheel bearings, brakes? So maybe this is not it. Does temperature affect it, or distance travelled, or when you turn the steering wheel, or if the brakes are applied? Any other clues? Thanks. AG Falco
  20. Remove aux belt and see if the noise is still there would be my first move. Thanks. AG Falco
  21. This is the Fabia III section not the Fabia II section. Thanks. AG Falco
  22. The Alternator does NOT charge the battery all the time by design. If the electrical load is low it will get turned off. She has a Micro Hybrid car. For more details look here:- https://www.yuasa.co.uk/info/technical/micro-hybrid-hybrid-vehicles-explained/ Especially these sections. Micro Hybrid 2, Regenerative braking & Battery care and Charging. Thank, AG Falco
  23. Skoda Citigo 85 SE 2018 with 175 65 14 Vredestein Quatrac 4 on. Now on the car for the second winter season as I run Conti's in the summer. Car does 10K+ miles per year with the all season on for less than 5K miles PA. No problem with them. Would recommend them if you asked me. I also run a Fiat Panda JTD 2009 with them on since 2016. Also no problem. Ran Dunlop winters from 2010 until 2016. Car owned from new and now at 133K miles. If the Hankook's work for you then stick with them. I only fit Asymmetrical tyres to my cars for various reasons. I am further South than you. North Dorset, Rural area. Thanks. AG Falco
  24. Under the MENU button he needs to look for the SMARTLINK option. See here:- Thanks. AG Falco
  25. Look for the 'MENU' button. Not car 1 but car 2 & 3 should have it, Just push the 'MENU' button and look for it. Thanks, AG Falco
