Warrior193
  1. Try your local branch of Timpson's. AFAIK, certain branches are able to cut and code replacement keys.
  2. Hello, why does the vehicle owner want to do that - is there some reason why the installed immobiliser is thought to be not enough? The simplest way might be to put a concealed switch in the supply for the fuel pump.
  3. It was because of this leaking issue that I decided not to spec one when configuring the Octavia.
  4. I believe that all micro-hybrids do, in fact, have regenerative charging/recuperation - you may be correct that the BMS will protect the battery from overcharging, but I have not seen any reference of this. I suspect that it might not, otherwise there would have been no real reason for limiting the alternator charging in normal running conditions.
  5. My understanding is that it was intended to slowly add silicates, extending the anti-corrosion properties of the coolant. Can cause serious issues to waterways if (when) the bag fails. Coolant should require shorter replacement intervals without the bag.
  6. Certainly take a very close look at - DPF condition, Glow plugs and that P.S. fault. See if the fault lights extinguish after a drive. Also see if it's trying to re-gen the DPF.
  7. I suggest walking away from that one unless you can get a tame mechanic to take a look. Lack of 'interest' from the dealer could be a cover for just getting shot of a lot of problems.
  8. My understanding is that the % limit on alternator charging is to allow capacity for regenerative charging - under those conditions, there could be a possibility of overcharging the battery.
  9. Hi, welcome to the forum. I assume this this a diesel? Yes, there is a rev-limiter when transmission is in neutral. Steering wheel symbol will be for some problem with power steering, although could possibly be low battery charge. If steering rack faulty, probably expensive. Is this being sold by a dealer - if so, what do they say about the fault lights?
  10. - Or my old GM Holden Kingswood wagon - that could take a fully-assembled racing Kart.
  11. Hello, welcome to the forum. Please can you post more details of your car? (engine code, Kessy, etc) - this way, other members might be able to offer relevant advice. I assume that you want to install an extra anti-theft device, it that correct? Why do you consider the installed immobiliser insufficient?
  12. (In Scots accent) 'It canna go any faster, Captain' 😁
  13. It is a pity that there do not appear to be many (any?) measured mile points on roads now in the UK - I used to find these very useful for a spot check on speedo and odo readings.
  14. Hello Leezy, welcome to the forum.
  15. I would have thought that would only be possible if the crankshaft is removed first.
  16. I'd certainly consider changing the pollen and engine air filters, inexpensive and pretty easy to do. long period of disuse could mean they've got pretty damp.
  17. @likaleica The 096 battery size is not an issue - what is most likely the problem is either the type (EFB or AGM required) or the terminal layout is not suitable. You will probably get a lot of spurious error codes pop up when you connect the new battery, but these should all clear after a short drive. AFAIK, ICE codes are permanent as long as the unit stays in original vehicle.
  18. That should do the job very well, looks identical to the AstroAl 6K - I guess they are clones of each other. Great price from Ali!
  19. @cado for storing the smart charger, take a look at the small aluminium cases (like a mini flight case) online - I found a small case that takes my Ring charger and the battery condition tester. Originally intended for storing hand guns. Very reasonable price and good protection. Those wheel support rods (alignment tool) really take a lot of the strain out of wheel changing. 👍
  20. Hi, is your consumption calculation correct? Unlikely that a stage tune will significantly improve your consumption figures, you will most likely be tempted to use the extra performance - and the fuel use will increase.
  21. Either of them would serve very well for pretty much anything you need to check with electrics - the shrouded test leads can be a bit of a nuisance sometimes - but that applies to all test instruments now (Elf & Safety) I think the 4000 count will do all that you need, the display updates plenty fast enough for dynamic measurements - put the extra money towards a few more litres of fuel the next time you get robbed at the pumps.
  22. Hi @nta16, Martindale instruments have a long history in the trade, I've only used their contact-free voltage testers, but that DMM should do the job well. I see that, from a reasonable sample, 90% of purchasers on Amazon give it 4 or 5 star. Nice gift! Rather difficult to gauge accuracy unless you have access to bench-calibrated instruments, but for normal use, I can see no reason to suspect readings from that meter. What were you comparing it to?
  23. Hi @cado I've been using an AstroAl , 4000 count DMM for the past 2 years, I use this one for work and can recommend it as a good, reliable, budget DMM. It is auto-ranging, simple to use, reads true RMS values, has battery test function for dry/rechargeable cells and even a non-contact test function for mains. The only negative point is that it doesn't come with a protective case. It's not a Fluke 77 IV, but for less than £21, it's a bargain.
  24. By leaving permanently connected, they mean attaching (usually optional) DIN type connector leads to the vehicle battery charging points, and connecting the charger to that when required. The old battery will almost certainly require a bit of a 'boot' from your RAC charger before the new Ring charger will initiate charging - it might never do so because the battery is beyond recovery. Depending on use, I'd suggest charging every month to 6 weeks, bear in mind that, even on relatively longish trips, the battery will rarely get a full charge. If you have a reasonable digital multimeter (pretty good ones are not especially expensive, and are always useful to have about the house) If you do buy a DMM, go for one with a higher count reading, suggest over 2500-3000 count. If interested, I can recommend a reasonable one for you. I'd recharge when the battery standing voltage drops below approx. 50-60% (12.1 - 12.2 volts) Give the new battery a full charge, the Ring charger will tell you when it's got there. It is safe to leave unattended, the internal circuitry of the charger will prevent any risk of damage through overcharging - just make sure you select the correct mode.
  25. I hope there weren't any speed cameras around.
