Warrior193
  1. That manoeuvre would certainly be 'interesting' from lane 4 on the M25.
  2. Hi Rob, was that a type 82 Kubelwagen at the Cars & Coffee meet?
  3. Just be aware that in the event of an accident, your insurance company could take the view that an accident was 'preventable' if the front assist had been active - they might consider apportioning some fault to you if the system was deactivated.
  4. Hello Paddy, welcome to the forum. Check that the front radar sensor (or mounting bracket) has not been damaged in a minor parking shunt.
  5. Does the battery appear to be recovering OK from low charging?
  6. Hello Columbo, welcome to the forum. Get the battery tested as well, intermittent power steering can be an indication that the battery is failing.
  7. The Love emoticon is for your account of the trip - 😞 is for your wife getting C-19 on the flight home.
  8. Hope you enjoyed your stay in the Old Country Cobber. I guess you're back home now.
  9. Still not an unreasonable expectation - my Octavia has a 6 year old EFB, most mileage is short trips commuting, and always use stop-start, battery still tests as good.
  10. Hi NightShadow, welcome to the forum. From other postings on this question, you will probably get multiple fault warnings light up when you reconnect the battery terminals - but these should all clear after a short drive. If you wish to avoid this possibility, you could keep the car system 'alive' by connecting a 12-volt supply to the power socket, but this is not really necessary.
  11. Although quite reasonable to expect at least 4 to 5 years life from a battery given normal care.
  12. Hi Andy, welcome to the forum. That message means that one of the criteria for allowing the engine to perform an 'Idle stop' has not been met - therefore the engine keeps running (stop-start temporarily disabled) One of the criteria is A/C running - but set temperature not met. Another is possible windscreen misting/fogging conditions.
  13. On Auto setting, the fan speed will adjust in an attempt to get the cabin temperature to commanded temperature quickly (usually full-speed) - then ramp fan speed down as temperature approaches set point.
  14. Hi Beaumont, welcome to the forum. I'm afraid I don't know the answer - but I very much suspect there may be very significant differences between the two body styles. Ask the supplier for clarification - and an assurance in writing that it will fit. You might need to supply them your VIN.
  15. Cue a sharp intake of breath 😆.
  16. For a normal, smart charger, there will be no issues with charging the battery while still on the vehicle - important to follow the instruction that the Negative charger connector be attached to the metal tag on the firewall - NOT to the battery Negative post.
  17. I think you will find that the mode of operation of energy recuperation VW uses normally prevents the alternator from charging the battery more than 60-75% - this to allow battery capacity for the energy recovered under recuperation conditions - which, on shorter trips is limited and does not normally get the battery anywhere near 100% charged. It is not ideal for these types of battery to be undercharged for extended periods.
  18. I had the alternator and battery on my MY16 Octavia replaced under warranty in the first year of ownership due to the stop-start not functioning. The cheapskates at the supplying dealer replaced the original AGM with a Moll EFB! - which still tests OK at 6 years, but I do 'nurse' it with an occasional charge because of frequently doing fairly short runs.
  19. 'Wheels - check, Tyres - check' That's 8 to start with😆.
  20. How about disconnecting a fuel line as Gav_is-_con suggests and just using the vehicles fuel pump?
  21. That could figure considering hitting the big bump in the road.
  22. I've always called the part in direct contact with the cam a cam follower.
  23. Second trying the 1.0 TSI - be aware there are two engine versions, keep a lookout for the 6-speed, 110 PS version.
  24. I can recommend the Ring smart charger.
  25. I assume by that is that you felt that there was a significant drop in performance - did your consumption also go up?
