Is she dead??
Hi A7, as you say your engine already had an oil habit, and combined with this new problem, unfortunately, it may very well be the end of the line for her😞 unless you can source a known good replacement engine - and the swap can be done, both within a reasonable cost.
Is she dead??
Is this a TSI or TDI? Have the timing chain and tensioner been checked?
Is she dead??
Hello A7, welcome back. It will help members if you post your engine type and code.
Accelerator pedal plug.
Hi NZ, does that latch move in towards the cable side of the connector when pressed? - if so, a pretty good bet it's a bail-catch release for the connector.
Octavia VRS touchscreen unresponsive except for the power button
I'd take a very careful read through all the warranty conditions and then demand a clear answer as to why they think it's not covered.
Help with replacement Bridgestone on 2022 vRS
Hello Jos, there is a setting in the infotainment system, settings - 'winter tyre speed warning' - if normal tyres are fitted, you need to uncheck the box.
Rear seat belt replacement on a 5 door
Hi Graham, the reference was in relation to using a used belt, for which there can be no reasonable way of knowing previous history of the replacement. NB, even if the retractor works correctly when pulled out manually is not necessarily a guarantee that it will lock and hold correctly in the event of an accident. In the case of your cut belt webbing strap, it might be better (and cheaper) to investigate having your strap replaced - I believe there are companies that can do this.
Strongly agree, seatbelts are designed for one use (accident) only, - if a used belt has actually been subjected to the high loadings involved in a serious accident, the mechanism could possibly fail in a 2nd event. Of course it is possible that the used belt was not occupied during any accident - but there will be no way to determine this,
Wind Deflectors?
I can recommend Heko.
New Turbo
But it certainly would pay to get a reliable diagnosis of the fault. Could it be possible it's something simple like a blown hose?
New Turbo
Hello James, please can you tell us what engine (TSI/TDI) and what engine code? (3 or 4 character) Personally, I'd look for a reputable turbo rebuilder (on exchange) My only experience for this was when the turbo failed on my Draco 24 - (Volvo Penta AQAD40B engine) which I exchanged with one from a specialist in Wimbledon.
Oil Change Message
I agree, one particular concern would be for the turbocharger bearings.
Oil Change Message
Hi Varooom, do I assume correctly that the bottom line is kilometres?
Oil Consumption on a 1.8 TSI Octavia
If seller persists in fobbing you off and will not take responsibility, 1 - Keep a record of all correspondence with them. 2 - Check your legal rights under Sale of Goods Act (or whatever the latest iteration is called) 3 - File a case in County Court - this isn't expensive to do. The chances are that they will see sense when they realise that you are serious, if they don't, they will have to attend a court venue convenient to you - if they fail to appear, you should get an automatic judgement in your favour, if they then refuse to pay, the bailiffs will go in and start seizing 'goods to the value' - with all the disruption to business that will ensue from this. Unfortunately, all this can take some considerable time.
New Electronics Problem?
If you can, give it an overnight charge, then see if this fixes the problem. NB. remember to attach the charger Negative clamp to the metal tag on the firewall behind the battery - not the battery post. Let us know how it goes.
What type of charger is it? Do you know if your battery is EFB or AGM? You can find this info marked on the top of battery.
New (to us) Superb - fixing niggles
Possibly worth it if it can be proved that the replacement engine has had ALL the updated components fitted, and is in good condition - otherwise quite possibly a case of rinse & repeat.
Hi Jo, the 3 milers won't be doing the battery much good, nor will regular10 mile trips - but this would probably be offset if the 100 milers were reasonably frequent. My Octavia battery struggles with the 8 to 9 mile each way commute to work. These micro-hybrids, or at least the VW-based ones, seem to rely heavily on energy recuperation and limit how much charge the alternator outputs to the battery.
The electric power steering does put a very high load on the battery when it's operating. What is the length of your typical trip? It's possible that your runs aren't long enough to charge battery - although stop-start is often 1st thing to stop working on low battery state (<>50%).
Rob's Ur Quattro
Well I never! - I lived in Grant Road to age 10, trekked all around the Town belt above and never realised it was there.
Coolant loss mystery
Hello, try a search on this forum for EGR valve leak.
Hi Jo, welcome to the forum. First thing to do anytime you get multiple fault indications like this is to give the battery a thorough condition check and recharge. How old is the battery?
Rob's Ur Quattro
Roofline looks like GT40 or Lambo compared to neighbours in shot outside Lluma.
Rob's Ur Quattro
Hi Rob, are the waterworks shots up in Kaitoke?
New engine?
Strongly advise to NOT run the engine until the cylinders and head can be inspected.
