Dying gearbox. Need replacement.
That tends to suggest that the oil spill she noticed in the car park isn't from yours.
Loss Engine Power
Certainly on the Mk3, the engine power cuts-out if the brake pedal is pressed while throttle is open - accompanied by a message on the infotainment screen.
Place a weighted piece of clean cardboard under the engine the next time it's parked up at home.
Is there any sign of oil leaking from the bottom of the clutch bellhousing?
Air con not working
'The curse' is where as soon you mention an item to be trouble-free, it fails - AKA Sods Law. ☹️
Ask the guy who is claiming probable damage how much oil was recovered when he originally drained the box. Sudden failure is very unlikely unless the gearbox has been making loud and unusual noises for a considerable time, or has been throwing out of gear under acceleration/decelleration.
Definitely get a second opinion! Where is the oil leaking from - engine or gearbox? How or where were you checking oil level? Are there any symptoms from the gearbox at present?
Air con not working
There's nothing serviceable on the AC compressor, apart from actually checking the refrigerant charge - This'll probably trigger 'The Curse', but my 11-year old system is still operating correctly and has never been touched.
Air con not working
Did the AC technician identify (and repair) the refrigerant leak?
WHEEL HUB NUT
I've not worked on a drive hub for a very long time, but yes, with the caliper and everything else off the hub, I would expect it to pull off over the driveshaft splines. Take care with the CV joints.
WHEEL HUB NUT
In my silly youth days I fitted tapered rollers on my rally car build, they used a spacer between the inner and outer races - so they weren't adjustable in the usual sense, adjustment required machining of the spacer.
WHEEL HUB NUT
Just curious - are these wheel bearings tapered rollers - or a type of deep row ball bearing?
2016 Octavia RS162 Part Numbers
I'd be very surprised if the tail lights were different between Combi trim levels of the same model.
- Is it possible to convert push to start to turn key ignition start in a 2011 skoda superb v6 4x4?
Good thing you don't have a pair of Danes!
Bcm issues
- Bcm issues
Check that you hadn't accidently switched on the parking lights - which are activated by moving the indicator stalk up or down when the ignition is switched off.- Air con not working
Unlikely for the spilt fuel to have damaged the AC compressor or shear plate - the aux. belt, possibly - but that would also cause issues with the alternator. When my fuel rail bolts failed, all the fuel was running down the front of the engine, not the offside.- Tracking - pulling to the left
- New Elroq - Just arrived at Dealers! Tips?
Request clear confirmation that suspension transit blocks have been removed during PDI.- Skoda Superb Business 2019 (pre facelift) Amundsen MIB2 map update & region switch question
- Cybertruck!
Musk should have got Acme in.- key fob battery?
If the key fob loses sync, it becomes inoperative until it is resynced. I always rotate the spare fobs on both our vehicles, so have never had to do it - but I think I have seen references to some procedure using the emergency lock cylinder to unlock, then starting the vehicle within a short time period.- key fob battery?
AFAIK, habitually using only one key fob can lead to issues where the unused fob gets 'out of sync' with the immobiliser rolling code. - Bcm issues
