Steviedakota
Members-
Posts
689 -
Joined
Last visited
Content Type
Profiles
Forums
Gallery
Shop
Events
Downloads
Everything posted by Steviedakota
Replacement anti roll bar poly bushes
Steviedakota replied to DB72's topic in Skoda Superb Mk III (2015 - 2023)
Keep in mind a new anti roll bar fitted by Skoda could have exactly the same problem. How they have not got on top of this problem is beyond me. -
Skoda release first glimpse of Superb mk4
Steviedakota replied to SurreyJohn's topic in Skoda Superb Mk III (2015 - 2023)
Really looking forward to seeing what they do. Superb 3 is a tough act to follow, hope they retain some analogue controls for the interior. -
I did, as it is one of those jobs I don't actually believe they will do if you leave the car them! Saw the oil go out and new oil go in. They showed me what came out.
Black may have been an overstatement but it was certainly a good deal darker compared to the new oil. Quite why I can't say!
Can't help with the question but had mine changed on a 1.4tsi at 80,000km by an Indy. The oil was black and very thin, was very happy to get it changed. Got the oil from a Skoda dealer and it took 3.5 lites I think.
Skoda Superb 2023 model
Steviedakota replied to vrskeith's topic in Skoda Superb Mk III (2015 - 2023)
I'd say it will evolve the handsome exterior styling but expect more bling and more screens in the interior. -
New rear shocks needed - brands?
Steviedakota replied to Steviedakota's topic in Skoda Superb Mk III (2015 - 2023)
Cheers for the detailed response Carlston. The mechanic has the car VIN and is going to fit Monroe. -
Car failed test for leaking N/S rear so need to get both sides done. (150,000km and 6 years) Any recommendations on brands, currently thinking Monroe/Sachs or Bilstein B4. Also am I correct in thinking this is not a huge job, everything can be done from inside the real wheel arch? TIA
Headlight switch knob damage/ rip off
Steviedakota replied to Zmywarka's topic in Skoda Superb Mk III (2015 - 2023)
https://www.youtube.com/watch?v=Ds-5pN3_W2o Without a nob this might be tricky but it may help. -
Superb clutch judder
Steviedakota replied to Superbsport's topic in Skoda Superb Mk III (2015 - 2023)
My car (2015 same engine and gearbox) also does this intermittently. I think you would be very lucky to get to Skoda to cover any of this repair, unless a leak is found once they open it up. Are they quoting £1400 just for the clutch? Flywheel really needs to be done at the same time. You might get a much better price elsewhere. In. my case clutch and flywheel are the obvious answer, but as it is intermittent and the clutch is not slipping I haven't bitten the bullet as yet. I'm also concerned that I may do the above and it may not fix the problem. Keep us posted as to how you get on. -
Drivers side window switches
Steviedakota replied to CBas's topic in Skoda Superb Mk III (2015 - 2023)
You will need thin trim remove Tools. Mask Blue area with tape in case trim tool slips and scratches plastic. Orange arrows, start here. Once this area is lifted you can slot a credit card in there to keep the gap where are you use your trim removal tools on the next next stage. Green arrows next. Blue arrow, trim just hooks under here, no prying required. It will then lift out allowing you to disconnect the two block connectors for the windows and mirrors. It is a tight fit but will pop up as you work your way around. -
Steviedakota replied to boydeee's topic in Skoda Superb Mk III (2015 - 2023)
So today I drove of a small branch, whacked the underside of the car, immediately dashboard light - Skoda oil sensor workshop! Took it to my local mechanic and sure enough the branch had whacked the connector and ripped out a wire. They were able to reconnect it but the block, which is part of the wiring loom is damaged. Light is off for now. Allieexpress to the rescue and a new block connector on the way from China for €5. Moral of the story, don't drive over a small branches! -
Big fan of TW sealants too. So easy to use, cheap and last forever. -
Also don't be tempted by a cheap pollen filter, OEM or charcoal activated are best.
I also had the same problem after a few years, just stale bacteria in the AC system. I run an AC deodoriser spray but as I didn’t replace the pollen filter at the same time the smell lingered. So I removed the pollen filter and used a Maguires product, installed a new pollen filter and the car smells super fresh again.
