Dave77
Everything posted by Dave77
  1. I'm replacing a rear camera in my estate, the current one is shown below. I've found a video showing how to remove the whole trim but was wondering if it's possible to just unclip the top part where the arrows are, does anyone know?
  2. I've bought one of these to try, will report back with the results https://www.amazon.co.uk/dp/B00X0VPAH4
  3. Thanks, I've found this one too, no mention of coding in 10 Park/Steer Assist like shown above though. The above translates to "Lane keeping assistant with steering intervention installed"
  4. My Sportline came with lots of scratches on the black trim below the side windows. Has anyone got any tips to fill these in eg a particular touch-up pen or black marker maybe?
  5. Does anyone have the instructions to enable lane assist in the FL model? I believe it's slightly different to the non-FL.
  6. Not sure what is, so it prevents closure if someone is in the way? If so part numbers !!!!!
  7. I came across the topic below whilst trying to work out why my fuse slots 13/41 are empty (seat belt tensioners). As @Aperture777 points out in this when a fuse slot is not in use you will just see the 'bus bar' (power) and nothing in the other slot (to device) This is my fuse box with the 2 fuse taps removed, outlined red (40/47). You can see to the right of each an empty slot (green), I have tested both of these and the upper is permanent live, the bottom is ignition live, so both could have been used to power the dashcam rather than piggybacking an existing fuse. Looking at several other posts I see some people saying they can't use a 'fuse tap' in a socket as there is currently no fuse there. Correct me if I'm wrong but surely it's better to use an empty slot?
  8. Is it recommended to disconnect the battery when removing the A pillar due to the airbags?
  9. I've managed to confirm it's the wrong way round. I removed original fuse from the fuse tap and re-fitted the same way as above, the Halo dashcam did not work. Fitted it the other way (wire down) and the dashcam worked. Probably a dodgy Halfords job. It won't fit the correct way around with both fuses in the fuse tap in 47 as that big yellow fuse gets in the way. My 48 fuse slot is empty so should be able to use that. Then to deal with the other upside down fuse tap above it!
  10. Hi all, I got my car a month or so ago and it came a Road Angel Halo already fitted. I had already bought a Thinkware dashcam earlier this year and am planning to fit it at the weekend. I thought i'd have a quick look at how the Halo is wired so i've just unclipped the glovebox to get to the fusebox. In each fuse tap the original fuse is in the lower socket and a 2 amp fuse in the upper as it should be but are these fuse taps the wrong way round? I haven't got my voltage tester at the moment to check but all other installs I have seen on here has the fuse tap with the wire going downwards.
  11. Maybe I have the latest already then, my online updates expired in Aug. Maps is 24.8. The logo I'm after is for Radio X, I think I'll have to live without it!
  12. Does anyone know where I can see what version of logos are currently installed?
  13. The files are n the right place, I just extracted straight to the drive Not sure where to find that SK number. I have a VCDS scan but nothing with SK-MQ in there.
  14. Not working as exFAT either, what's Presentation? I've just check https://www.phonostar.de/vw/en/download with my HU p/n, 3V0035816K, and it comes up as no update available so maybe mine can't be updated 🤷‍♂️
  15. PC. I thought it had to be FAT32? I'll try exFAT
  16. Still no luck with my MIB3, I bought one of these Sandisk drives from Amazon, formatted it to FAT32 using this tool, then extracted the zip to the drive. The HU does nothing when plugging the USB in 🤷‍♂️ How are others formatting to FAT32 on Windows?
  17. ......plugged in a USB-C charger 😁 Not a major mod but it may help someone! I wanted a USB-C charger for the rear ashtray that when fitted still allowed the tray to close, this one fits perfectly. https://www.amazon.co.uk/dp/B0BTP9GF27 I would have preferred a double USB-C but all the ones I found would have stopped the tray closing when fitted. At some point I may swap for ones of these https://www.ebay.co.uk/itm/285669357516
  18. Are you holding '1' down for it to go into position?
  19. I'm just removing the pads when not in use as shown in my last picture above. The frame stays on, the pads are removed in seconds with a push button. Whilst the OEM ones do look neat, they don't look big enough to me.
  20. So that came with the car when you bought it, Is it hidden somewhere? Mine is a 2022 model
  21. It's not working in my Superb MIB3 using a USB A stick with a USB C adapter. Can anyone recommend one that works?
  22. This is the right way round! The downside is they don't fold back out of the way but they're easily removable when not needed.
  23. I think I have it on the wrong way round actually 🤣 Still worked though.
