Everything posted by Tell
TMC traffic events no longer being received...firmware update required?
Practically I don't reckon anything is going to happen officially, it all rests on whether users can get the alternative data in somehow. The alternative method is to follow the other cars in front on a Google maps rat run when a traffic jam occurs and peel off to get to where you are going back using the cars sat nav. I've done that one. If driving yourself... helps to have the co partner on navigation. Old school methods or use Google Maps etc.
VW tend to be the brains and it's them that terminate services in the past.
I don't trust them to pull the plug on online software car updates, which connected cars use. You can put these on AA or Apple if you wish but the point is the car was sold with TMC. The INRIX technical solution will be the answer if one exists, other than that providers of the TMC data service have done the dirty on its users.
2020 so it's 3 years old for some and the plug pulled out. Reckon they will do the same for connected service. Mib4 and then the plug pulled on Mib3 soon after 2025. More like disconnected services.
I did read it takes a time to build up. I don't know how that works but isn't suppose to work instantly. May be it will arrive. The mib2 standard people can nibble at that end. You'd have to force a reboot on the standard one I guess. The high possibly does that if you used the back end menu. SWDL.
I don't think the standard unit uses the route meta checksum, some times you see it on downloads other times you don't. It's more there for a human check than a machine check. PCBBC will tell me if I'm wrong. It's the Mib2 high which is tight on fiddling. Why on the Mib2 standard people delete the language files to save space, swap the countries around get the unit working out of zone. Better test bed to experiment with than the Mib2 high on this. I'll wait for clear instruction :). Too many cooks and so forth. Got one car with a high unit on it, the other with a standard unit. So can test if anyone gets it working. Between you two or more. BTW when you compute the checksum you take out the checksum and signatures etc. I've used this in the past but I dont' think for the standard unit you don't need to bother with checksums. The POI files where it comes in more on those. That's where I've had to do it where VAG introduced new users IDs for the model so one was editing the POI input file from Poinspector prior to the programmer getting the new ID into their program. Was a Seat wifi standard unit issue now fixed. The last time I had to get my head round it. SLA1 signature check on mib2 high stops map fiddling but we'll see what PCBBC achieves. The Mr Bonk method / mib2 collective as I call them will I guess edit the map file within the unit so circumvents the check. That's how the Aussie is doing it. https://download.cnet.com/MD5-SHA-Checksum-Utility/3000-2092_4-10911445.html
Amundsen Mib2 Map Updates 2023/2024
Those are the firmware releases, not map releases which is the thread.
OK I've found that material await your testing. I can say I've never edited an ISO and put the material back inside. We are also looking for champions (I am anyhow) to turn MIB3 maps into MIB2 high ones when they pull the plug on mib2 high maps in a few years time. Chillout said it would be cool. I was hoping that would be taken onboared. Wait to see how it goes on your edit.
I was avoiding fiddling. The mib2 standard if it's in the map files can be hacked. Mib2 high they are signed so can't be edited. Had a look at the link, Mr Bonk the the mib2 high collective. I do have a version of that toolkit on my Seat, how I got the Skoda life long navigation FeC on my Seat Mib2 high when VAG did the dirty on one release and left Seat off. The tool sits in the green menu and you run it to give you retrofitter tools as if it was on a bench. They put all the retrofitters tools in it. Avoids signed updates. They found a way of side loading it into units due to a flaw in the Vag signature check so it slips into the units under the radar. I'll wait till after my holidays to fiddle with it. You really need an expert on a forum to help. I had one. The tool is paired with the firmware release you are on. It reads that. If it's in the database you get paired. If not they write one for you, hopefully. That's how it worked then. It latches onto the firmware. It uses developers hooks that were left in the firmware... so runs as test code. It might better pair now. I did look at more recent copies of it and it seemed to pair differently. May be more generalised. Come across Audi OZ person on the MartiniB map release thread who had installed the Audi firmware. They have generalised their work now to produce firmware avoiding the signature... for the Australian they had it set up against the EU maps FeC. I got them onto the toolbox to alter the FeC to RoW... It was working then... They did need Mr Bonks help, I'd said press a button, needed some one else to say what to do, I gave them the FeC, 99% there, I said press AddFeCs they hadn't. That's when it became apparent it was more generalised in how it paired. You always reboot after using it so the changes get taken. Given you only use it once for a job... It gets hazy after. We are still looking for a champion 😍. Btw the other Audi folk that appear on MartiniB navigation files thread will have the mib collectives firmware on them (aka Mr Bonk). They do this for the life long navigation FeC. They then seek help to get the maps in on them normal stumbling blocks. The toolkit gets added and then may be deleted at the end. These are the "AIO" prefixed releases. All in one. Had people that say, no don't want the toolbox installed then don't get the FeCs they were installing it for. There are toolbox versions for mib2 standard. If it was something that was useful on the TMC side it might have been added to the mib2 standard toolkit(s).
I've asked the Seat Leon 4 folk. We'll see what they say. Get them looking for it in their units. Any mib3 is worth a looks. It squares a circle.
It's in the self training material for Audi for Mib3 atleast. Attached that above. You would have to sit in a Skoda with Mib3 and look for it as a cross check.
If you pay for connected services it comes over the air but it's also in mib3 as broadcast TMC as well. They will be stuffed. The dealer training material for Audi mib3 is here. MC-10189329-0001.pdf
Yes 2020 when they moved to mib3 so units from circa 3 years old affected not 13 years ago.
I wouldnt jump trains which is 3* to 4* probably end in tears. People mod the train up. Changing software gives you an SVM, the confirmation code in the 5F unit you put through https://mib-helper.com/im-so-xory/ Then puthing the return code into confirmation code least in Obdeleven Pro. Anyhow it won't help since it's not old firmware that's the issue.
Columbus Map Update 2023 (MIB1/2 HIGH)
This thread isn't for the latest maps so you need the 330 release see below if you haven't found it but that isn't your technical issue. The instructions I was talking about are here, my 11th November post, the VW how to PDF. The gold standard: So your issue will be a presentation issue only of not presenting the update as expected (You have a mib2 high, tick, a Skoda so not a navigation FeC issue, tick, using Windows so not a Mac issue tick). That leaves not unzipped or at the wrong directory level down in how it's presented etc (see PDF in thd link). Also good to pull other cards out so it only sees the media. You are suppose to use 7zip for the unzip process. Others can give a problem. Basically the unit reads the files and checks the integrity of the files from the signatures and checksum. If they don't pass it won't see the update. Not in the correct level is another - see the PDF, not unzipped correctly, or not using a valid file system, Fat32 for the 32gb card, exFat for above cards, or NTFS for USB and it wont work. Those are the outstanding issues to check. Suppose to be in Fat32, 32gb SD card but the maps have outgrown some cards, you use say 64gb in exFat if that's the case or USB in NTFS (That isn't in the instructions above). I mention that if after using the latest you find they wont fit on the card. I did use to say only stick to the 32GB card but since the maps have expanded above what some 32GB cards can handle now, you can get issues if you don't get the file system right for exFat on big SD cards or NTFS for USB. So that was the other issue people hit. The latest maps are here: Release 330. Your 166 you see on the screen will become 330 when successful. They are the June 2023 release found early by MartiniB in April. I think poster drifted threads at this point so you might be using the latest or may be not. The Mod John needs to pin that thread above and un-pin this one so people find the latest at the top else people grab the wrong files.
- 101 replies
- 1
- columbus
- discover pro
- maps
- mib
Tagged with:
Did you use a Mac for the download ?. Macs leave a load of Mac generated rubbish in the file which causes the validation of files to fail if you presented them incorrectly. Happy go lucky Mac users fall into this trap. You download with Keka, copy to the SD card then run CleanMyDrive on the SD card, then insert it into the unit. Failing that its a presentation issue. See the manual posted on the other threads, can't get one uploaded at the minute. Failing that if it's it's not a Skoda or VW then it will be your navigation FeCs. They need to be long FeC.
- 101 replies
- columbus
- discover pro
- maps
- mib
Tagged with:
I'll see if I can get any comments from the Mib collective as I call them on the TMC LTNs location.
A. No B. Yes C. Pass D. Well there is a hobbyist Mib2 Telegram group of software experts. I have been considering posting it up on one they read. It's around getting the unit to read the other network in the UK that still broadcasts. It is a specific UK issue so those resident abroad can't really experiment. Australian and I think NZ experience is useful you find on the net. I live in the sticks so I doubt it would receive those broadcasts to experiment, so I'm not going to try. Basically it's either going to be a hack solution to get it on that network if possible or navigation users including Vag coughing up to pay TMC to continue the service. Commercially the one Vag uses folded via the FM / DAB service. Not sure whether they used both bands or not. That just leave the These hobbyists are the best bet I reckon if there is no commercial solution they know the ins and outs of mib2. https://github.com/Mr-MIBonk/M.I.B._More-Incredible-Bash But they probably haven't looked at hitching it up on a different TMC provider than those its paired with. There are some UK people on the software side that work with them.... thinking about it. That link is one of their mib2 high tools. There is a mib2 standard group somewhere as well. They produce the toolkits for the standard unit. Those folk that will know the inner workings of how it all hangs together and what's possible. It needs to be put on Inrix rather than Traffic Master as has been said on the thread. Some 2021 discussion technical here. Needs a champion. https://www.golfmk7.com/forums/index.php?threads/enabling-tmc-in-the-uk-is-it-possible.386243/
If its like Seat / Cupra you'll go through updates which may or may not fix it. Down to the quality of your dealer reading the VAG firmware update material, what the assorted systems are on in the car. They have to all match correctly so they talk to each other correctly. Then you have to have the user login correct. All VAG cars are built with the same core code but embellished with logos etc. They tend to fix VW issues first then work onto the sub brands. Mib3 was a particular disaster for Vag. Yours will be in that area.
That one falls into the category of online connected cars where the Vag software is problematic rather than TMC where Vag and other companies presumably didn't renew the contract so the Traffic Master pulled the plug.
Amundsen Mib2 Map Updates 2024
Or Seat. It uses a CID which it identifies it as a valid VAG card. It's how they generate income. Those who are too lazy to use their old issued card buy a new one and VAG gets income from it. If it's bust and they do wear out you but a new one and VAG gets income. You can hack the unit to use normal SD cards but probably not worth it. You'll see Mr Fixit shove normal SD cards in the unit after its been hacked, but hacking only works with certain firmware. Mr Fixit gets his income off YouTube videos by publishing dubious methods. Best to stick with the VAG cards. CID: https://www.cameramemoryspeed.com/sd-memory-card-faq/reading-sd-card-cid-serial-psn-internal-numbers/ With the correct card you can write your own CID but those cards cost more than the genuine card. Did it once for the hell of it. You need a "gold card". This is where you need to be careful with eBay sellers they may be using cheap Chinese gold cards in a scam. Where you need to check the star rating. You only need to buy a new card when it gives up the ghost or want a 32gb card if yours is the old 16gb.
- 98 replies
- amundsen
- discover media
- maps
- mib
Tagged with:
Suspect it needs a DIY fix if possible other than that the reasons for pulling the plug on the services will stop it (cost) eg. marry it up to the other service. It did vanish for a week or so last year or the year before but this is permanent so it appears linked solely to one of the two UK providers of traffic services. Not European wide.
Vag is notorious at pulling the plug early on things it's deemed are finished. This one is specific to the UK market and a group of manufacturers that use it and fund it. Will be interesting to see whether they raise to the occasion to fix it other than that I quess you are looking to a DIY approach along the lines of that link above of fiddling with the parameters. It has the highly respected coding expert DV52 / Don on it. May be Audi are thinking they might get the unit working on the other service if they are paying for it ?. Question is whether there is a DIY solution to that since other VAG brands wouldn't be doing a recall just for that. Any DIY is going to be developed in the UK with a collective of experts on the subject. Meantime cross checking with Google Maps and AmiGo. My normal navigator roll before heading off or if driving back from somewhere.
Interesting read here for anyone who wants to have a go: https://www.golfmk7.com/forums/index.php?threads/enabling-tmc-in-the-uk-is-it-possible.386243/page-3
You got Exciter to thank for that in 2017 when he cracked it. All Seat sites publish that now. Was called the "workaround" by the Seat Cupra site. Seat UK for mib2 decided not to sell Mapcare. It's bundled in free with VW and Skoda. Audi and Seat elected to continue to sting owners if they wanted to upgrade their maps. In Europe they sold Mapcare which gave you a 3 year license of updates. Another way of cracking it is to add long life navigation FeCs which is what VW and Skoda have. Those cracks are now known for mib2. There are some infotainment VCDS flags you can change for the traffic services. I guess some one has looked at this ?. In the 5F unit. Suspect some bright folk might have thought of that. It's how you anchor the unit to paid traffic services. Needs someone to experiment may be ?.
