Everything posted by bigjohn
Battery just replaced, unusual voltage reading
This can be normal if you have a healthy battery etc... Basically modern charging systems will back off re charging and wait until certain circumstances (eg overrun). All to save a couple of grammes re CO2 readings. I had a voltage sensing split relay on my previous Superb to control the running of a coolbox and it used to turn off at times especially on a long run(battery nearly full). I discovered using a high current device stopped this happening eg headlights.
Notchy 2nd gear after new clutch
Normally if it's a dragging clutch the 1st and reverse are affected first. I think it's still something to do with gear selection. Something amiss / out of line re gearbox mounts. Clearly gearbox will have been removed as part of the clutch change. Take it back! Hold assist could be confused as to which gear you have selected. What does the gear selected display show when in different gears? Gearbox oil levels correct?
Sudden problem with air vents. Making a really loud noise.
I think it's a case of removing glove box - fan motor etc is behind
Leakey DCC dampers - How bad does it have to be before replacing?
In my experience a 3rd party warranty won't cover dampers- wear and tear gov they will say.
Low oil pressure warning
Take it back - you've bought some else's problem car? Suspicious an oil change was done a week before you bought it, however make sure the correct oil filter has been used and has been fitted correctly (not over tightened etc). The oil change might have been done to disguise a problem though. Pressure test required hot and cold. Is it definitely an oil pressure warning- not level? Does it show low oil pressure when engine is cold, and hot. Any difference?
Car lose power and stutters under heavy load (uphill or at higher speeds) Skoda Octavia Mk3 SE TSi Manual Petrol 1395cc
I think my Toyota based hybrid gubbins uses a different mapping altogether - Miller cycle? Can’t complain as it feels lively but still gets mid 60’s mpg.
Yup, with my old Superb II 1.4tsi it noticeably ran better on Momentum 99 from Tesco but made little difference to the economy. However with the replacement Swace (Toyota Corolla TS gubbins) there is no discernible difference with the higher octane petrol.
Codes need reading before you start playing the parts replacement roulette game. I'd be suspecting coil packs - that can be affected by heat on a hard run. If these are changed it's also worth fitting new plugs. However I have encountered similar symptoms though with a friends 1.8 tsi Yeti. Loosing power under load/ uphill. It was the High Pressure fuel pump.
Octavia Mk4.4, Towbar preparation or not?
Octavia mk4 ? This is the Fabia mk4 section. Judging by others on other sections having difficulties re fitting a tow bar and ending up with a less than satisfactory solution (manually turning off rear sensors every time you tow/drive etc) I'd suggest getting the towbar fitted
Octavia estate Mk1 rear brake pipe corrosion.
You can just about guarantee that most of the pipes will be in poor condition now. The only really safe way is to effectively change all pipes that run outside the engine bay . flexi hoses (they can rot outside and/or inside). Re brake calipers/cylinders etc plus gas is your friend (soak for a few days), cut off pipe and use a well fitting socket. If they are still bad get new ones. You are probably better getting new clips/ connectors etc. Yes, you'll have to bleed all 4. You really need a pressure or vacuum bleed and something like VDCS to bleed the ABS block otherwise air remains trapped. I had a pipe pin hole blow many decades ago going down a hill towards traffic lights (my Dad's old MKIV Zodiac, single circuit brakes!). Fortunately a big v6 engine, large clutch and chunky gearbox meant I could get into reverse whilst going forward, rev the engine , drop the clutch and spin the rear wheel backwards to stop! The only casualty was my underwear but I've vowed never to repeat. A while later I saw a garage owner greasing metal brake pipes as part of his service so a) I used him for a few year, now retired sadly and b) I've either done it myself or insisted that my local independent does the same. Let's just say the metal brake pipes on Mrs BJ's 2006 Panda are still in remarkable condition.
12v Power Issues/Software Updates
- Hardwired TomTom
Having run a Tomtom device for years a few suggestions to try :- 1) I had a problem with a Tomtom 5200 remaining connected to my phone(and using battery) via Bluetooth behind the scenes despite being apparently shutdown. I stopped using Tomtom's bluetooth pairing. 2)They are also rather voltage and current sensitive (A cheap 12v/USB wouldn't charge mine properly) - Is it a proper Tomtom hardwire kit? Measure with a multimeter. 3)Also on a car with stop start and latest charging management that reduces charging to save a g or two of CO2 it can cause issues. I used to hear this with my previous Superb that sometimes had a cool box in the boot connected via a voltage controlled split relay (to avoid a flat battery!) that would turn off after a while when on a long run. I found if I ran with the headlights on this never happened. I'd suggest plugging in a 12v device that has a voltage readout to have a look see.- Temperature warning going uphill?
- Headlight conversion for european driving - Skoda Superb II
Your car probably has the latest LED headlight technology that may engage tourist mode when going abroad - detected using the satnav GPS. If it's the simpler LED I think the official VAG line seems to be no adjustment required. [EDIT] I've found a previous link for exactly the same questions:- https://www.briskoda.net/forums/topic/510655-adjust-full-led-headlights-for-driving-on-right/ To be honest I have the same issue with my new car (Swace) which has LED lights and no tourist mode and the lights do have a slight uptick to the left when you shine on a flat wall. It might need Eurolites stick ons - but looking at an example instruction sheet and manually making a temporary cover it doesn't mask off the slight uptick. There are multiple "bulbs" with LED headlights. I might leave alone and adjust to the lowest setting. Again my local dealer has no idea and it's not mentioned in the rather thick manual.- New to Skoda but looking for an estate car for around £15k
Excellent engine but check service history especially re 4x4 gubbins. The Superb is an amazing, comfortable and refined mile muncher that with the 2.0 petrol really flies. 2018 and earlier mkIII models have the excellent twin injection per cylinder (direct and port) that works well and mitigates re carbon buildup that just direct injection engines can suffer from (saying that I've never encountered this with 1.4 tsi). I'm making full use of my estate this week - going camping now I've seen the forecast. Sadly it's no longer a Skoda Superb.- 2020 Fabia with Apple CarPlay on newer iPhone
I found phone calls were just outputting through the tiny (and hidden) startup speaker of the Amazon Echo Auto. I'm sure I would have found the setting eventually but I decided to give up on Alexa in the car and removed the device. All worked well thereafter. I'm not that familiar with IOS but check audio / Bluetooth settings re calls. Looking online "Settings > Accessibility > Touch > Call Audio Routing. "- New to Skoda but looking for an estate car for around £15k
How about a Superb Estate 2.0 tsi?- 2020 Fabia with Apple CarPlay on newer iPhone
Could be a setting. Anything else connected to the phone via other means- eg ear buds via bluetooth? Does the iPhone 16 work ok re phone call audio? When I bought my recent car (not Skoda) I initially had phone call sound issues which turned out to be settings on my Google Pixel 6a associated with an Amazon Echo Auto device that I used previously.- My timing has always been poor... been toying with selling for a smaller car
To my eyes the Audi A3 Saloon is a very stylish looking car - way better than it's SUV cousins.- My timing has always been poor... been toying with selling for a smaller car
We still have 2 cars for now as the second member of our fleet is a low mileage 2006 Fiat Panda (I look like Mr Incredible getting into into and driving it!) that I clearly have rustproofed way too well in the past as it's in surprisingly good condition. Originally bought new by Mrs BJs late father. All looking good for now but I'm sure there will be a badly failed MOT decision day at some point - at which point we probably won't replace. I bought my current car with Mrs BJ in mind but it had to be good for me to drive long distance and have a huge boot (slightly less bothered about rear passengers now). Trouble is I've been spoilt and now have a longer list of minimum requirements - Economy 60mpg +, heated steering wheel (who new!!) , heated seats, his/her climate control, adjustable height rear view mirror(being tall some rvm's badly obstruct my forward vision) , auto (full hybrid in my case) , big door mirrors, auto beam LED headlights, Android Auto, rear camera!!. Original list still stands - spare wheel well, higher profile tyres, no Keyless entry, no touch screen for primary car functions.- EPC and engine management light. Car not pulling/accelerating
I think you need to change the plugs anyway as they are well overdue and the tsi's are heavy on them.- My timing has always been poor... been toying with selling for a smaller car
I've had two Superb models in the past and they were both just about the best normal cars (ignoring toys!) I've ever owned, saying that a Saab 9000 in the past was up there. However yes they were pretty low down to get in and out, Not quite an issue for us yet but my 87 year old Mum struggled getting in and out of my previous mkII. However once I was in either Superb I found then excellent re accommodating my 6ft4" and large frame, the larger front doors making a huge difference. Unfortunately due to retirement we've ultimately decided to down size to one car between me and Mrs BJ and she finds the Superb toooo big to drive. Driving positions / seats are an individual thing as well - we are all different. I don't like the more sit up and beg driving position of some SUV's but might have no option as we get older! Basically the Superb is er "Superb!"- EPC and engine management light. Car not pulling/accelerating
Don't guess - get the stored codes read / properly diagnosed.- Skoda superb mk2 estate 2010 rear wheel arch rust - no repair part available?
Yes , you have to be careful re water held in the sills, it will eventually rot through. The facelift doesn't have rubber bungs but it does have drains at low level inside the wheelarch (bottom of the cover) at each end of the sills. I checked mine with a thin knitting needle - one was bunged up. I Dinitrolled excessively, left it ages but some still poured out when I first drove it afterwards. Likewise behind wheel arch line was deep in leaves/ cruf etc with mine - no sign of rust fortunately. Cleaned out and more rust proofing applied. I think this is a design flaw! I checked my Son's 2016 Octavia mkIII and it has a cut out designed into the base of the front wing and was totally clear. Sunroof drains can be a pain - mine didn't have them as it was only the poverty spec but I remember my old Dad's Volvo 740 rotted through because of a broken sunroof drain. Muggins had to weld it backup as much as I could without a full blown strip down( I still had to remove all seats/carpets - and still nearly set fire to the dashboard!) but it was so bad I told him to get rid as further major rust issues would be likely. - Hardwired TomTom
