Carlston
Everything posted by Carlston
  1. I thought Belarus was in Europe? It's not in the EU, but neither is Norway and Switzerland. https://www.skoda-auto.by/models/newrapid/rapid Starting price for the new Skoda Rapid in Belarus is 28500 BYN, which is £8590 at today's exchange rate as given by Visa https://www.visa.co.uk/support/consumer/travel-support/exchange-rate-calculator.html?amount=1&fee=0&utcConvertedDate=&exchangedate=10%2F12%2F2020&fromCurr=GBP&toCurr=BYN&submitButton=Calculate+exchange+rate In Russia, the starting price for the new Skoda Rapid is 819000 RUB, which is £8180 at today's exchange rate as given by Visa https://www.skoda-avto.ru/models/rapid The old Skoda Rapid had 175/70R14 tyres on entry models, but the new Rapid starts with 185/60R15 tyres with 195/55R16 also available. The outside diameters of these two tyre sizes don't match. 185/65R15 and 195/55R16 match as do 185/60R15 and 195/50R16.
  2. 205/45R16 might get rid of the rubbing. However, the 7J rims and the low sidewalls don't do the ride any favours. 195/45R16 would make the situation even worse. 185/55R15 on Audi A1 6Jx15 ET29 rims would help move the tyres to the edge of the wheelarches compared to a more normal ET43 that you might use with this size tyre on the Fabia MK1. Alcar 7415 Steel Rims 6Jx15 ET29 5/100 57.1 https://www.autodoc.co.uk/alcar/14750602 https://www.oponeo.co.uk/steel-wheel/alcar-kfz-7415#21067394 Uniroyal RainSport 5 185/55R15 82H https://www.camskill.co.uk/m53b0s287p188166/Uniroyal_Tyres_Car_Uniroyal_RainSport_5_-_185_55_R15_82H_TL_Fuel_Eff_%3A_C_Wet_Grip%3A_A_NoiseClass%3A_2_Noise%3A_70dB Vredestein Quatrac 5 185/55R15 82H https://www.camskill.co.uk/m138b0s7988p125555/Vredestein_Tyres_All_Season_Car_Vredestein_Quatrac5_Vredestein_Quatrac_5_-_185_55_R15_82H_TL_Fuel_Eff_%3A_C_Wet_Grip%3A_C_NoiseClass%3A_2_Noise%3A_69dB
  3. If you're looking for bargain priced tyres for the Yeti, 205/55R16 size tyres are a much cheaper size than 17" tyres and also cheaper than the 215/60R16 size. 205/55R16 was fitted as standard to some Yeti models and is one of the recommended winter tyre sizes. Alcar 9535 Steel Rims 6Jx16 ET50 5/112 57.1 https://www.autodoc.co.uk/spares-search?keyword=9535&car_id=14021&model_id=6363&maker_id=106&brandNo[0]=100470 https://www.oponeo.co.uk/steel-wheel/alcar-kfz-9535#21366498 Alcar 9257 Steel Rims 7Jx16 ET45 5/112 57.1 https://www.autodoc.co.uk/spares-search?keyword=9257&car_id=14021&model_id=6363&maker_id=106&brandNo[0]=100470 https://www.oponeo.co.uk/steel-wheel/alcar-kfz-9257#21246586 Snow chains The snow chains improve handling in wintry road conditions. Remove the full wheel trims before installing the snow chains » page 156. Only fit snow chains with links and locks not larger than 12 mm. The use of snow chains on vehicles with front-wheel drive and on vehicles with four-wheel drive differs. Front-wheel drive Snow chains must only be fitted on the front wheels and are applicable only to the following wheel / tyre combinations. Rim size Press depth D Tyre size 6J x 16 50 mm 205/55 R16 7J x 16 45 mm 205/55 R16 6J x 17 45 mm 205/50 R17 All-wheel drive Snow chains can be mounted on the wheels on the front and rear axles. It is only permissible to fit snow chains on the front wheels with the following wheel/tyre combinations. Rim size Press depth D Tyre size 6J x 16 50 mm 205/55 R16 7J x 16 45 mm 205/55 R16 6J x 17 45 mm 205/50 R17 It is only permissible to fit snow chains on the rear wheels with the following wheel/tyre combinations. Rim size Press depth D Tyre size 7J x 16 45 mm 215/60 R16 7J x 17 45 mm 225/50 R17 WARNING Do not use chains on snow and ice-free routes - the handling would be impaired and there is a risk of damage to the tyres https://ws.skoda-auto.com/OwnersManualService/Data/en/Yeti_5L/05-2017/Manual/Yeti/A-SUV_Yeti_OwnersManual.pdf?_ga=2.257150978.885351739.1602454750-dc3293f3-8d3b-4927-a3fc-66b699c47aa2
  4. That's why I said this... "Although 205/70R15 is a non-standard size on the Yeti, many owners do fit non-standard tyre sizes in the UK." 15" wheels have never been approved by Skoda for fitment to a Kamiq. However, skoda-parts.com are listing 15" wheels to fit them. https://www.skoda-parts.com/spare-part/2q0601027t03c-steel-wheel-disc-skoda-38412.html
  5. That's why I posted the load index of all three tyre sizes. The 205/70R15 tyre actually slightly exceeds the load carrying capacity of the 215/60R16 and 225/50R17 sizes. In many difficult winter conditions the narrower 205/70 size would outperform the boy racer 225/50 size especially if fitted with good 3PMSF tyres. Even on the Skoda Kodiaq RS with 20" wheels, you will soon find the limit of the car's handling when undertaking the moose test...
  6. Skoda specified 16" and 17" wheels because of fashion, not safety. Cars like the Skoda Citigo with skinny 165/70R14 tyres have the lowest insurance premiums because low performance equals low risk.
  7. These three tyre sizes all have similar outside diameters and similar load indexes. They are all interchangeable. 205/70R15 (710kg load index at 3Bar/44psi) 215/60R16 (690kg load index at 3Bar/44psi) 225/50R17 (670kg load index at 3Bar/44psi) The Skoda Yeti often has 312mm diameter front discs which means that you need at least 16" rims to clear the front brake calipers. However, on the lower powered models 288mm diameter front discs are fitted. This means that 15" rims will clear the front brake calipers. 205/70R15 tyres are more comfortable, more mpg, and less decibels. Alcar 7755 Steel Rims 6Jx15 ET43 5/112 57.1 https://www.autodoc.co.uk/spares-search?keyword=7755&brandNo[0]=100470 Vredestein Quatrac 5 205/70R15 96T (Euro Label C C 70dB) https://www.camskill.co.uk/m138b0s7998p144823/Vredestein_Tyres_All_Season_Car_Vredestein_Quatrac5_Vredestein_Quatrac_5_-_205_70_R15_96T_TL_Fuel_Eff_%3A_C_Wet_Grip%3A_C_NoiseClass%3A_2_Noise%3A_70dB Although 205/70R15 is a non-standard size on the Yeti, many owners do fit non-standard tyre sizes in the UK. If you go off-road there are some good all-terrain tyres in the 205/70R15 size. Bridgestone AT001 https://www.camskill.co.uk/m26b0s257p145314/Bridgestone_Tyres_SUV_4x4_Bridgestone_AT001_Dueler_Bridgestone_AT_001_-_205_70_R15_96T_TL_Fuel_Eff_%3A_E_Wet_Grip%3A_C_NoiseClass%3A_2_Noise%3A_72dB Yokohama G015 https://www.camskill.co.uk/m26b0s257p148166/Yokohama_Tyres_SUV_4x4_Yokohama_G015_Geolander_AT_Yokohama_G_015_-_205_70_R15_96H_TL_Fuel_Eff_%3A_F_Wet_Grip%3A_C_NoiseClass%3A_2_Noise%3A_70dB
  8. Asymmetric tyres are not directional. Once fitted correctly to the rim, asymmetric tyres can be fitted to the vehicle in any position...left or right, front or back.
  9. 7Jx16 ET45 5/112 57.1 is the standard rim size for the Yeti with 215/60R16 tyres ET45 means that the offset is 45mm. ET stands for Einpresstiefe which is a German word. In English, Einpresstiefe means offset. 5/112 means 5 bolt holes with a BCD (Bolt Circle Diameter) of 112mm. 57.1 means the centre bore is 57.1mm. Alcar 9257 are aftermarket steel rims that match the original Skoda steel rims. https://www.oponeo.co.uk/steel-wheel/alcar-kfz-9257#21246586 https://www.autodoc.co.uk/alcar/14750851 https://www.mytyres.co.uk/cgi-bin/skw.pl?dsco=110&s_p=Steel-Rims&sowigan=felgen&Hersteller=Skoda&PKWtyp=YETI+2.0+TDI&PKWtypgenau=%3A533741%3A%3A1968%3A81%3A200909%3A++++++%3A57.00%3A112.00%3A5%3A5L++++++++++++++++++%3A%3AO%3AE11*2007%2F46*0010*.++&Show+types=Show+types oponeo is a useful site to find the Alcar model number. autodoc are usually cheaper for steel rims than oponeo. mytyres also sell Alcar steel rims, but you have to search for them my entering a car model that they fit rather than just entering the Alcar model number. As well as 7Jx16 ET45 rims, 6Jx16 ET50 steel rims were also available for winter tyres in size 205/55R16. http://www.oemepc.com/skoda/part_single/catalog/sk/markt/CZ/modell/YET/year/2015/drive_standart/779/hg_ug/601/subcategory/601010/part_id/2543667/lang/e 7J rims are quite wide for a 215/60 tyre size. 6.5J is more normal for this tyre size. Alcar 8226 7Jx16 ET41 5/112 57.1 from the Skoda Superb MK3 which also uses the same 215/60R16 tyre size as the Yeti https://www.autodoc.co.uk/alcar/14750743
  10. This is the latest all-season tyre review. It was posted just two days ago on 27/9/20. Goodyear G3 came 1st out of 32 all-season tyres on test. Vredestein Quatrac came 2nd. The Vredestein Quatrac is new and replaces the Quatrac 5. https://www.tyrereviews.co.uk/Article/2020-Auto-Bild-All-Season-Tyre-Test.htm
  11. This link on national tyres is the Continental AllSeasonContact in size 185/55R15 86H. It's a good all-season tyre. Not the same as the TS860 which Continental classify as a winter tyre. Both tyres do well in tyre reviews. https://www.national.co.uk/tyres-search?width=185&profile=55&diameter=15&rating=H~&loadindex=&pattern=allseasoncontact However, Vredestein has just brought out a new all-season tyre called Quatrac. It replaces the Quatrac 5. Some sizes are being released now, other sizes won't be available until 2021. It came 2nd out of 32 all-season tyres in this month's autobild all-season tyre review. Goodyear G3 came in 1st place. https://www.autodoc.co.uk/tyres/vredestein-8714692358241-ap18555015hqt6a00 autobild September 2020 all-season tyre review https://www.tyrereviews.co.uk/Article/2020-Auto-Bild-All-Season-Tyre-Test.htm
  12. Sachs 311863 1T0413031DT 1T0413031EG 1T0413031EH 1T0413031EJ 1T0413031FL 1T0413031HK 1T0413031HL 1T0413031HM 1T0413031HN 1T0413031HP 1T0413031JA 1T0413031Q 2K5413031 3AA413013A 3AA413013B 3AA413013F 3AA413013G 3AA413013H 3AA413013J 3AA413013M 3C0413031AE 3C0413031AT 5C0413031BE 5C0413031CS 5C0413031DE 5C0413031K 5C0413031Q 5C0413031R https://www.autodoc.co.uk/sachs/1224535 Sachs 317575 1T0413031CB 1T0413031CC 1T0413031CS 1T0413031DR 1T0413031ET 1T0413031FA 1T0413031FB 1T0413031FK 1T0413031GK 1T0413031HH 1T0413031HJ 1T0413031JD 5C0413031P https://www.autodoc.co.uk/sachs/14436022 As you can see from the above, Sachs makes one shock absorber to replace OEM part number 1T0413031HL and another shock absorber to replace OEM part number 1T0413031JD Bilstein 22-183729 1T0413031DT 1T0413031EG 1T0413031EH 1T0413031FL 1T0413031GG 1T0413031HK 1T0413031HL 1T0413031HM 1T0413031HN 1T0413031HP 1T0413031Q 5C0413031AF 5C0413031BL 5C0413031BN 5C0413031CS 5C0413031EC 5C0413031T https://www.autodoc.co.uk/bilstein/1043473 Bilstein don't appear to make an aftermarket replacement shock absorber to replace OEM part number 1T0413031JD
  13. Continental PremiumContact 2 tyres are a summer tyre and have poor performance in the snow and ice. If you use them all year round, it might be better using winter tyres such as Continental TS860. Although the TS860 are winter tyres, they have been show in a tyre test to actually be a better all-season tyre than Continental's all-season tyre. Continental TS860 175/65R14 82T https://www.autodoc.co.uk/tyres/continental-4019238741513-0353991 Continental TS860 185/55R15 82T https://www.autodoc.co.uk/tyres/continental-4019238792812-0355124 As you can see from the above two links, the 175/65R14 82T is a much cheaper size than the 185/55R15 82T size. 175/65R14 is also a more comfortable size and has less drag, so more mpg. Alcar 6795 5Jx14 ET35 4/100 57.1 Steel Rims https://www.autodoc.co.uk/spares-search?keyword=6795&brandNo[0]=100470 175/65R14 fitted to 5Jx14 4/100 rims were one of the standard options on the Citigo, so no problems with insurance. Fitting new rims means that you won't have problems with slow air leaks. When rims get old, you can get corrosion on the bead seat, resulting in a slow air leak. This probably happens even more with alloy rims than steel rims. If you use a garage airline that has water in the air, you get water inside your tyre. This could be one of the reasons that corrosion builds up on the rim where the tyre bead sits.
  14. Rather than 235/45R20, you could fit 235/55R18 tyres with suitable 18" rims. It looks like the new steel rims from the VW ID.3 electric car would fit. Are you getting that car in NZ? These have a specification of something like 7.5Jx18 ET50 5/112 57.1 but do check first before making any purchase.
  15. If you list all your PR code numbers, someone might be able to help.
  16. That nut uses an M14x1.5 thread. That is the same thread that Fabia wheel bolts use. If you take a look at the wikipedia entry on ISO metric screw threads, you will see that the 1.5mm thread pitch is a fine thread for an M14 diameter. You will also see on the wikipedia entry, that M14 threads take a 21mm spanner if the nut or bolt with that thread is made to the ISO specification. https://en.wikipedia.org/wiki/ISO_metric_screw_thread wheel bolt M14X1,5X27 http://www.oemepc.com/skoda/part_single/catalog/sk/markt/CZ/modell/FAB/year/2008/drive_standart/453/hg_ug/601/subcategory/601010/part_id/2543667/lang/e
  17. The MK3 Superb uses 215/60R16 tyres on 6.5Jx16 ET41 rims, whereas the MK2 Superb uses 205/55R16 tyres on either 6Jx16 ET50 rims or 7Jx16 ET45 rims. The outside diameter of a 215/60R16 tyre is about 5% bigger than the outside diameter of a 205/55R16 tyre. 205/55R16 is a much cheaper size than 215/60R16.
  18. Front Shock Absorbers Bilstein 22-105813 https://www.autodoc.co.uk/bilstein/633292 Sachs 300 032 https://www.autodoc.co.uk/sachs/1220656 TRW JGM306T https://www.autodoc.co.uk/trw/7122894 Rear Shock Absorbers Bilstein 19-109589 replaces 6Q0513025P https://www.autodoc.co.uk/bilstein/638572 Sachs 290 887 replaces 6Q0513025P https://www.autodoc.co.uk/sachs/1220594 Bilstein 19-109572 replaces 6Q0513025R https://www.autodoc.co.uk/bilstein/638571 Sachs 280 564 replaces 6Q0513025R https://www.autodoc.co.uk/sachs/1220253 TRW JGT1082T replaces 6Q0513025P and 6Q0513025R https://www.autodoc.co.uk/trw/7067756
  19. Front springs OEM number 6Q0411105AK (1 Red dot, 4 Yellow dots) https://web.tecalliance.net/gkn/en/parts/1/56292/detail?targetType=cars&targetId=15584&typeNumber=15584&groups=188#@brc/brands:Car;targetType:cars;mandator:gkn/assem:SKODA%20FABIA%20I%20Combi%20(6Y5)%201.9%20TDI;targetType:cars;mandator:gkn;targetId:15584;typeNumber:15584/lnkparts:Coil%20Springs;targetType:cars;mandator:gkn;assemblyGroupId:100113;targetId:15584;typeNumber:15584;groups:188;brands:1;pf:2;page:0/detail:56292;brandId:1;articleNo:56292;mandator:gkn;targetType:cars;targetId:15584;typeNumber:15584;groups:188 coil spring 1 paint mark 4 colour strokes red yellow Model data: PR-1GA/J08 PR-1GG/J15 http://www.oemepc.com/skoda/part_single/catalog/sk/markt/CZ/modell/FAB/year/2004/drive_standart/225/hg_ug/411/subcategory/411010/part_id/2561497/lang/e Eibach R10163 https://www.autodoc.co.uk/eibach/11962878 Lesjofors 4085709 https://www.autodoc.co.uk/lesjofors/2259589 Rear springs OEM number 6Q0511115M (1 Orange dot, 2 Yellow dots, 1 Orange dot) https://web.tecalliance.net/gkn/en/parts/1/56289/detail?targetType=cars&targetId=15584&typeNumber=15584&groups=188#@brc/brands:Car;targetType:cars;mandator:gkn/assem:SKODA%20FABIA%20I%20Combi%20(6Y5)%201.9%20TDI;targetType:cars;mandator:gkn;targetId:15584;typeNumber:15584/lnkparts:Coil%20Springs;targetType:cars;mandator:gkn;assemblyGroupId:100113;targetId:15584;typeNumber:15584;groups:188;brands:1;pf:2;page:0/detail:56289;brandId:1;articleNo:56289;mandator:gkn;targetType:cars;targetId:15584;typeNumber:15584;groups:188 coil spring F >> 6Y-2X036 027 * F >> 6Y-2-446 084 * 1 paint mark 2 paint marks 1 paint mark orange yellow orange Model data: PR-1JA/0YC Period: 0899 - 1201 http://www.oemepc.com/skoda/part_single/catalog/sk/markt/CZ/modell/FAB/year/2004/drive_standart/225/hg_ug/511/subcategory/511010/part_id/2561497/lang/e Eibach R10237 https://www.autodoc.co.uk/eibach/12832014 Lesjofors 4285711 https://www.autodoc.co.uk/lesjofors/2260988 Front shock absorbers OEM number 6Q0413031BH or 6Q0413031BJ 8 6Q0413031BH shock absorbers front Model data: PR-1GA (8) 6Q0413031BJ shock absorbers front Model data: PR-1GG http://www.oemepc.com/skoda/part_single/catalog/sk/markt/CZ/modell/FAB/year/2004/drive_standart/225/hg_ug/411/subcategory/411010/part_id/2561497/lang/e Bilstein 22-105813 https://www.ebay.co.uk/itm/Bilstein-B4-Suspension-Front-Shock-Absorber-Gas-Suspension-Damper-22-105813/141694468308?epid=248919792&hash=item20fda600d4%3Ag%3Ak8wAAOSwHP1dlHzv&LH_ItemCondition=1000 Sachs 300 032 https://www.ebay.co.uk/itm/SACHS-300-032-SHOCK-ABSORBER-Front/402054751411?hash=item5d9c54a4b3%3Ag%3ACxcAAOSw8SdeL0zn&LH_ItemCondition=1000 Rear shock absorbers OEM number 6Q0513025R or 6Q0513025P 7 6Q0513025R gas shock absorber Model data: PR-K8G/1JA (7) 6Q0513025P gas shock absorber Model data: PR-K8B,K8D/ 1JA http://www.oemepc.com/skoda/part_single/catalog/sk/markt/CZ/modell/FAB/year/2004/drive_standart/225/hg_ug/511/subcategory/511010/part_id/2561497/lang/e
  20. 1K0511115BS is a lowered rear spring as it fitted to such cars as the Skoda Octavia MK2 Estate RS and the VW Golf MK6 Estate with sports suspension. You can find that information on the gknautomotive.com online catalogue: https://web.tecalliance.net/gkn/en/parts/1/86744/detail?query=1K0511115BS&numberType=1&oe=1K0511115BS&groups=188#@brc/search:Search%20by%20any%20number%201K0511115BS;mandator:gkn;query:1K0511115BS;groups:188;brands:1;pf:2;page:0/detail:86744;brandId:1;articleNo:86744;mandator:gkn;query:1K0511115BS;numberType:1;oe:1K0511115BS;groups:188 Scroll down and click "Skoda" or "VW" in the "Vehicle linkage" on the above link to see the cars that are fitted with the 1K0511115BS rear springs as standard.
  21. I thought it might be a Greenline as 1K0511115BS appear to be sports springs, and Greenline's tend to use sports springs to improve the drag coefficient by lowering the ride height. It might be worth checking the car's build codes to see what was fitted in the factory. If one of the car's build codes is PR-0YC then that means that the car was built with 1K0511115BS rear springs in the factory. http://www.oemepc.com/skoda/part_single/catalog/sk/markt/CZ/modell/SUP/year/2014/drive_standart/768/hg_ug/511/subcategory/511010/part_id/2562471/lang/e
  22. 1K0511115BS http://www.oemepc.com/skoda/part_single/catalog/sk/markt/CZ/modell/SUP/year/2014/drive_standart/768/hg_ug/511/subcategory/511010/part_id/2562471/lang/e
  23. gknautomotive.com recommends 1K0511115DE rear springs for the Skoda Superb MK2 estate 1.6TDI 1K0511115BS is 32mm shorter than 1K0511115DE. 1K0511115BS is 11.75mm coil spring thickness and 1K0511115DE is 12.25mm coil spring thickness. 1K0511115BS https://web.tecalliance.net/gkn/en/parts/1/86744/detail?query=1K0511115BS&numberType=1&oe=1K0511115BS&groups=188#@brc/search:Search%20by%20any%20number%201K0511115BS;mandator:gkn;query:1K0511115BS;groups:188;brands:1;pf:2;page:0/detail:86744;brandId:1;articleNo:86744;mandator:gkn;query:1K0511115BS;numberType:1;oe:1K0511115BS;groups:188 1K0511115DE https://web.tecalliance.net/gkn/en/parts/1/86349/detail?targetType=cars&targetId=6339&typeNumber=6339&groups=188#@brc/brands:Car;targetType:cars;mandator:gkn/assem:SKODA%20SUPERB%20II%20Estate%20(3T5)%201.6%20TDI;targetType:cars;mandator:gkn;targetId:6339;typeNumber:6339/lnkparts:Coil%20Springs;targetType:cars;mandator:gkn;assemblyGroupId:100113;targetId:6339;typeNumber:6339;groups:188;brands:1;pf:2;page:0/detail:86349;brandId:1;articleNo:86349;mandator:gkn;targetType:cars;targetId:6339;typeNumber:6339;groups:188 What springs are fitted to the front?
  24. If you are losing more than 1psi each month, then that tyre has a slow leak. This is usually caused by a corroded rim where the rim meets the tyre bead, so that air escapes at this point. Of course, a slow leak can also be caused by a foreign object such as a nail penetrating the tyre.
  25. Something doesn't quite ring true...
