Everything posted by Carlston
Does the Sportline have stiffer suspension?
Kilen and KYB list these springs for the standard ride height Superb MK3 2.0TDI 150HP hatchback. 5Q0411105GM Kilen 25117, KYB RA1089 1 5Q0411105GM Front Coil Spring 1 paint mark 1 paint mark Blue Grey 2 PR-L07 Wire diameter 12.25mm, Length 315mm, Weight 1.7kg (specification taken from gknautomotive.com) 3Q0511115AK Kilen 65124, KYB RA5330 1 3Q0511115AK Rear Coil Spring 2 PR-1JA+0YC Wire diameter 12.25mm, Length 364mm, Weight 2.2kg (specification taken from gknautomotive.com) Your sports/lowered ride height springs 5Q0411105HD 1 5Q0411105HD Front Coil Spring 1 paint mark 1 paint mark brown white 2 PR-L17 Wire diameter 12.25mm, Length 284mm, Weight 1.7kg (specification taken from gknautomotive.com) 3Q0511115T 1 3Q0511115T Rear Coil Spring 2 PR-1JC+0YB Wire diameter 12.75mm, Length 324mm (specification taken from eibach and includes 3Q0511115AA which is one weight range higher, so actual 3Q0511115T is probably a slightly lighter spring than this perhaps having a wire diameter of between 12.25mm and 12.5mm) With aftermarket springs, there tends to be much less choice of sports/lowered springs with many OEM part numbers not available. This is one reason for sticking to or changing to standard ride height springs if you like to replace your old broken springs with aftermarket springs. Plus of course, standard ride height springs tend to give a softer and more comfortable ride. Not forgetting the increased ride height and improved ground clearance. https://www.kilensprings.com/springs-catalouges/onlinecatalogue.asp https://kyb-europe.com/catalogue/ https://www.gknautomotive.com/
Yes, the rear shock absorbers could be either 3Q0513049FN or 3Q0513049FP. The KYB and Sachs rear shock absorbers listed on autodoc cover both of these OEM part numbers, so if you were going for these aftermarket shock absorbers it wouldn't matter which OEM part number your car originally came with out of those two OEM part numbers. The rear Bilstein shock absorbers that you purchased are only listed against the increased ride height part number, which is the complete opposite of the sports/lowered ride height that you have. Saying that, many of the rear aftermarket shock absorbers use a one size fits all approach, so sell just one rear shock absorber to cover sports/lowered suspension, standard ride height suspension, and increased ride height suspension (sometime called off-road suspension and/or heavy-duty suspension). Anyhow, because of this discrepancy with the Bilstein rear shock absorbers, I would have probably gone for either Sachs or KYB rear shock absorbers. The Sachs and KYB are both sold to replace all three OEM part numbers. Maybe the Bilstein will be fine with all three ride heights, but maybe not. Rear shock absorbers for Superb MK3 FWD 7 3Q0513049FP Gas shock absorber rear 2 PR-1JA 7 3Q0513049FN Gas shock absorber rear 2 PR-1JA 7 3Q0513049FP Gas shock absorber rear 2 PR-1JC 7 3Q0513049FN Gas shock absorber rear 2 PR-1JC 7 3Q0513049FT Gas shock absorber rear 2 PR-UC7
All Season Tyres....
Narrower tyres such as 215/60R16 and 215/55R17 should have lower fuel consumption than wider 235/45R18 and 235/40R19, although the increased fuel consumption of the wider tyres could be due to the increased weight and the increased wind drag rather than increased friction with the road. I would be more concerned about the high wear rate of the Hankook all-season tyres. The wear rate was only about 63% of the best in one of the tests. Maybe take a look at Continental all-season tyres. Some of them are given a B rating for rolling resistance.
The Bilstein B4 front 22-232342 and rear 19-232362 shock absorbers that you list are the only Bilstein B4 shock absorbers that are listed on autodoc that cover some of the OEM part numbers for the Superb MK3 FWD without electronic suspension control. I don't know if you have a white sticker/label under the carpet in the spare wheel well area, because someone suggested that Skoda stopped doing this around 2015/16 model years. Howver, that not be totally accurate information. The white label only includes some of the build codes, perhaps around 40 of them. The actual number of build codes is much higher, perhaps around 140. When you get all your build codes, I find it useful to sort them into alphanumerical order. To determine your front springs, you are looking for a build code between L01 and L35. To determine your front shock absorbers, you are looking for build code G01 or G02 or G03. To determine your rear springs, you are looking for a build code between 0YA and 0YL, and whether you have build code 1JA or 1JC or UC7. To determine your rear shock absorbers, you are looking for build code 1JA or 1JC or UC7.
Is it possible to upgrade the wheel (bigger size Rim)
If you put a photo up with a side view, someone might be able to comment on the tyre to top of wheel arch gap. Maybe the gap is less than it should be if hitting humps is a problem? Maybe you've got sagging and/or broken springs or someone has previously fitted lowering springs?
Converting Karoq SE-L with space saver spare wheel to full-size spare wheel
What are you going to fit in the space in the spare wheel well that you have saved by using a space saver instead of a full sized spare?
Which Bilstein B4 front shock absorbers did you fit? You may have accidentally fitted front shock absorbers for increased ride height, which is the complete opposite of what you want for the sportline with its presumably lowered ride height. To avoid this kind of mistake, it's important to match the OEM part number of your factory shock absorbers with the list of OEM part numbers that the particular Bilstein B4 shock absorber is sold to replace.
If you get your car's build codes you should be able to work out what parts the car left the factory with, such as springs and shock absorbers. There is an ebay seller that can supply these for about 3 Euros. Search "skoda vin decoder" on ebay. search "skoda vin decoder" on ebay for your car's build codes https://www.ebay.co.uk/itm/224631127243 Here are some front springs from the Superb MK3 parts catalogue 1 5Q0411105HL Coil spring 2 paint marks brown 2 PR-L25 1 5Q0411105HM Coil spring 1 paint mark 1 paint mark brown Grey 2 PR-L26 1 5Q0411105HN Coil spring 1 paint mark 1 paint mark Grey yellow 2 PR-L27 1 5Q0411105HP Coil spring 1 paint mark 1 paint mark Grey orange 2 PR-L28 1 5Q0411105HQ Coil spring 1 paint mark 1 paint mark Grey red 2 PR-L29 1 5Q0411105HR Coil spring 1 paint mark 1 paint mark Grey violet 2 PR-L30 1 5Q0411105HS Coil spring 1 paint mark 1 paint mark Grey blue 2 PR-L31 1 5Q0411105HT Coil spring 1 paint mark 1 paint mark Grey green 2 PR-L32 1 5Q0411105DQ Coil spring 1 paint mark 1 paint mark 1 paint mark yellow brown red 2 PR-L35 1 5Q0411105GF Coil spring 1 paint mark 1 paint mark blue orange 2 PR-L01 1 5Q0411105GG Coil spring 1 paint mark 1 paint mark blue red 2 PR-L02 1 5Q0411105GH Coil spring 1 paint mark 1 paint mark blue violet 2 PR-L03 1 5Q0411105GJ Coil spring 2 paint marks blue 2 PR-L04 1 5Q0411105GK Coil spring 1 paint mark 1 paint mark blue green 2 PR-L05 1 5Q0411105GL Coil spring 1 paint mark 1 paint mark blue brown 2 PR-L06 1 5Q0411105GM Coil spring 1 paint mark 1 paint mark blue Grey 2 PR-L07 1 5Q0411105GN Coil spring 1 paint mark 1 paint mark green white 2 PR-L08 1 5Q0411105GP Coil spring 1 paint mark 1 paint mark green yellow 2 PR-L09 1 5Q0411105GQ Coil spring 1 paint mark 1 paint mark green orange 2 PR-L10 1 5Q0411105GT Coil spring 1 paint mark 1 paint mark green blue 2 PR-L13 1 5Q0411105HA Coil spring 2 paint marks green 2 PR-L14 1 5Q0411105HB Coil spring 1 paint mark 1 paint mark green brown 2 PR-L15 1 3Q0411105 Coil spring 1 paint mark 1 paint mark 1 paint mark yellow red yellow 2 PR-L42 1 5Q0411105HC Coil spring 1 paint mark 1 paint mark green Grey 2 PR-L16 1 5Q0411105HD Coil spring 1 paint mark 1 paint mark brown white 2 PR-L17 1 5Q0411105HE Coil spring 1 paint mark 1 paint mark brown yellow 2 PR-L18 1 5Q0411105HF Coil spring 1 paint mark 1 paint mark brown orange 2 PR-L19 1 5Q0411105HG Coil spring 1 paint mark 1 paint mark 2 PR-L20 Here are some front shock absorbers from the Superb MK3 parts catalogue 8 3Q0413031BG Gas shock absorber D >> - 29.07.2018 2 PR-G01 8 3Q0413031CR Gas shock absorber D - 30.07.2018>> 2 PR-G01,G02 8 3Q0413031BF Gas shock absorber D >> - 29.07.2018 2 PR-G01 8 3Q0413031CQ Gas shock absorber D - 30.07.2018>> 2 PR-G01 8 3Q0413031BG Gas shock absorber D >> - 29.07.2018 2 PR-G02 8 3Q0413031CR Gas shock absorber D - 30.07.2018>> 2 PR-G01,G02 8 3Q0413031BF Gas shock absorber D >> - 29.07.2018 2 PR-G02 8 3Q0413031CQ Gas shock absorber D - 30.07.2018>> 2 PR-G02 8 3Q0413031BJ Gas shock absorber D >> - 29.07.2018 2 PR-G03 8 3Q0413031CT Gas shock absorber D - 30.07.2018>> 2 PR-G03 8 3Q0413031BH Gas shock absorber D >> - 29.07.2018 2 PR-G03 8 3Q0413031CS Gas shock absorber D - 30.07.2018>> 2 PR-G03 Here are some rear springs from the Superb MK3 parts catalogue 1 3Q0511115AH Coil spring 2 PR-1JA+0YA 1 3Q0511115AJ Coil spring 2 PR-1JA+0YB 1 3Q0511115AK Coil spring 2 PR-1JA+0YC 1 3Q0511115AL Coil spring 2 PR-1JA+0YD 1 3Q0511115M Coil spring 2 PR-1JA+0YE 1 3Q0511115N Coil spring 2 PR-1JA+0YF 1 3Q0511115P Coil spring 2 PR-1JA+0YG 1 3Q0511115Q Coil spring 2 PR-1JA+0YH 1 3Q0511115R Coil spring 2 PR-1JA+0YJ 1 3Q0511115BC Coil spring 2 PR-1JA+0YK 1 3Q0511115S Coil spring 2 PR-1JC+0YA 1 3Q0511115T Coil spring 2 PR-1JC+0YB 1 3Q0511115AA Coil spring 2 PR-1JC+0YC 1 3Q0511115AB Coil spring 2 PR-1JC+0YD 1 3Q0511115AC Coil spring 2 PR-1JC+0YE 1 3Q0511115AD Coil spring 2 PR-1JC+0YF 1 3Q0511115BH Coil spring 2 PR-1JC+0YG 1 3Q0511115AE Coil spring 2 PR-1JC+0YH 1 3Q0511115AF Coil spring 2 PR-1JC+0YJ 1 3Q0511115AG Coil spring 2 PR-1JC+0YK 1 3Q0511115BD Coil spring 2 PR-1JC+0YL 1 3Q0511115BG Coil spring 2 PR-UC7+0YA 1 3Q0511115AN Coil spring 2 PR-UC7+0YB 1 3Q0511115AP Coil spring 2 PR-UC7+0YC 1 3Q0511115AQ Coil spring 2 PR-UC7+0YD 1 3Q0511115AR Coil spring 2 PR-UC7+0YE 1 3Q0511115AS Coil spring 2 PR-UC7+0YF 1 3Q0511115AT Coil spring 2 PR-UC7+0YG 1 3Q0511115BA Coil spring 2 PR-UC7+0YH 1 3Q0511115BB Coil spring 2 PR-UC7+0YJ 1 3Q0511115BE Coil spring 2 PR-UC7+0YK Here are some rear shock absorbers from the Superb MK3 parts catalogue 7 3Q0513049FP Gas shock absorber rear 2 PR-1JA 7 3Q0513049FN Gas shock absorber rear 2 PR-1JA 7 3Q0513049FP Gas shock absorber rear 2 PR-1JC 7 3Q0513049FN Gas shock absorber rear 2 PR-1JC 7 3Q0513049FT Gas shock absorber rear 2 PR-UC7 VW codes decoder 1JA = Rear shock absorption, basic design 1 1JC = Rear shock absorption for sports design UC7 = Rear shock absorption, chassis with increased ride height http://igorweb.org/equidec.aspx
Wheel make recommendations ?
8Jx18 ET45 5/112 57.1 rims from the VW iD.4 would fit. Both alloy and steel rims are available in this specification. 245/45R18 would be ideal for the 8J rim. It has an almost identical outside diameter to 245/40R19. https://www.mytyres.co.uk/rims/details?vehicleId=1314745426959668336&rimCode=ALCAR9383 8Jx18 ET45 5/112 57.1 alloy rim 11A601025C (from VW iD.4) https://www.ebay.co.uk/itm/155175380732
The below VW Golf MK4 is on 6Jx15 ET38 5/100 57.1 alloy rims with 195/65R15 tyres. With the right rims or wheel trims even 15" wheels can look good. https://en.wikipedia.org/wiki/Volkswagen_Golf_Mk4#/media/File:2003_Volkswagen_Golf_(1J_MY03)_Generation_2.0_5-door_hatchback_(2015-07-09)_02.jpg
225/40R18 are easily damaged by potholes because the sidewalls are so low. 205/55R16 are rarely damaged by potholes, and are Europes most popular car tyre size. Low profile tyres are the equivalent of sleeping on a hard plank of wood. What you've done is take away your cushions.
New alloys headache…
Atlanta rims have a 5/112 PCD and were fitted to the VW Golf MK5. 1K0601025BM Aluminium rim 'ATLANTA' 6,5JX16H2 ET50 5/112 https://www.lllparts.co.uk/catalogs/vw/RDW/GOLF/474/6/601/601055
New tyres on the 4x4 superb
Having passed the 3PMSF test, the Bridgestone all-season tyre although not the best in the snow is still much closer in performance to a winter tyre than a summer tyre.
Front Brake disc size?
On autodoc, ATE, Ferodo, and Jurid only list 312mm front brake discs for the Karoq 1.5TSI. https://www.autodoc.co.uk/car-parts/brake-disc-10132/skoda/karoq/karoq-nu7/128287-1-5-tsi?supplier[0]=48&supplier[1]=62&supplier[2]=3&supplier[3]=48&supplier[4]=62&supplier[5]=3&criteria[100][6]=VA The 312x25mm front brake discs on the Karoq use TRW brake calipers. Skoda parts catalogue 5Q0698151F 1 set: brake pads with wear indicator for disc brake 312X25mm 5Q0615301F Brake disc (vented) 312X25mm 5/112 https://www.lllparts.co.uk/catalogs/skoda/CZ/KAR/834/6/615/615001 TRW GDB1956 front brake pads 5Q0698151F https://www.autodoc.co.uk/trw/7489103 https://www.ebay.co.uk/itm/234610257695 Bosch 0986479932 front brake discs 5Q0615301F https://www.autodoc.co.uk/bosch/7309458 https://www.ebay.co.uk/itm/234757578379
ride comfort - going from 18" 235-45 to 17" or 16". Has anyone done it?
All Superb MK3 cars except for the 280HP/272HP 4x4 cars use 312x25mm front brake discs. The big 340x30mm front brake discs used on the Superb MK3 280HP/272HP 4x4 cars are matched with ventilated 310x22mm rear brake discs. So if you have solid 300x12mm rear brake discs, the front brake discs will be 16" rim compatible, ie. 312x25mm front brake discs. 310x22mm ventilated rear brake discs (used in combination with 340x30mm front brake discs) Skoda Superb MK3 1.6TDI – Generation: III B8 (3V) [2015 .. 2019] – Market: EUDM – Power: 118 hp | 88 kW | 120 PS – Engine: 1.6L, DCXA, I4, Diesel – Options: Active, Ambition, GreenLine, Style – Center Bore: 57.1 mm – PCD: 5x112 – Wheel Fasteners: Lug bolts – Wheel Tightening Torque: 140 Nm – Thread Size: M14 x 1.5 – Trim Production: [2015 .. 2018] Tire Rim 215/60R16 95V 6.5Jx16 ET41 2.3 / 2.1 215/55ZR17 94W 6.5Jx17 ET41 2.3 / 2.1 215/55ZR17 94W 7Jx17 ET40 2.3 / 2.1 235/45ZR18 94W 8Jx18 ET44 2.5 / 2.3 https://www.wheel-size.com/size/skoda/superb/2017/#trim-16tdi-eudm-118
17" rims clear the front brake calipers on 340x30mm front brake discs. There aren't any Skodas that need 18" rims.
Disc and Pads part number request - 2.0 TDI 150 Estate
ATE 24.0125-0158.1 front discs are sold to replace both 1K0615301AA and 5Q0615301F part numbers. It's a TRW brake system so I suspect TRW brake pads were used.
1K0615301AA 5Q0615301F 12 1K0615301AA Brake disc (vented) 312X25MM 5/112 2 12 5Q0615301F Brake disc (vented) 312X25MM 5/112 2 https://www.lllparts.co.uk/catalogs/skoda/CZ/SUP/851/6/615/615000 ATE 24.0125-0158.1 https://www.autodoc.co.uk/ate/957620 ATE 24.0125-0158.1 https://www.ebay.co.uk/itm/374366360127 8V0698151B brake pads with wear indicator for disc brake 1ZA https://www.lllparts.co.uk/catalogs/skoda/CZ/SUP/851/6/615/615000 ATE 13.0460-2785.2 https://www.amazon.de/-/en/ATE-13-0460-2785-2-02-13-0460-2785-2-TEVES-Brake/dp/B01CRNJ9UY/ref=sr_1_1 TRW GDB1956 https://www.ebay.co.uk/itm/234610257695
2018 Octavia Scout tyres
There's lots of options, but what you need is more sidewall height to prevent the tyres from being damaged by the rough roads. Fitting tyres with more sidewall height to your current 18" rims will make the outside diameter of the tyres too big. Therefore, to get more sidewall height you need smaller diameter rims such as 16". 225/60R16 tyres fitted to 7Jx16 ET45 5/112 57.1 rims (from the Yeti) is one option. 7Jx16 ET45 5/112 57.1 steel rim https://www.mytyres.co.uk/rims/details?vehicleId=185941160152274032&rimCode=ALCAR9257
The best ride on standard tyres and rims will be 215/60R16 tyres fitted to 6.5Jx16 ET41 5/112 57.1 rims. However, if you fit the 215/60R16 tyres to slightly narrower 6Jx16 ET43 5/112 57.1 rims from the Karoq, you should be able to fit these in the spare wheel well with the carpet flush. The slightly narrower 6J rim will also help improve the ride comfort further. 6Jx16 ET43 5/112 57.1 steel rim (from the Karoq) https://www.mytyres.co.uk/rims/details?vehicleId=1302234084152546416&rimCode=ALCAR6665 6.5Jx16 ET41 5/112 57.1 steel rim (from the Superb MK3) https://www.mytyres.co.uk/rims/details?vehicleId=1037328747869009008&rimCode=ALCAR8426
1st post don't be hate'n SUSPENSION PART NUMBER
Have you got a white build code label under the carpet in the spare wheel well area? Example of white build code label http://igorweb.org/decoder/stitok.jpg I suspect you have build code L60, L61, L66, or L67 representing your front springs. You can see in the bottom chart the corresponding OEM part numbers. Some Octavia MK2 4x4 front springs 1 1K0411105DK Coil spring 3 paint marks orange 2 PR-L60 1 1K0411105DL Coil spring 4 colour strokes orange 2 PR-L61 1 1K0411105DM Coil spring 2 paint marks violet 2 PR-L66 1 1K0411105DN Coil spring 3 paint marks 1 paint mark also marked with: 3 paint marks pink brown violet 2 PR-L67 https://www.lllparts.co.uk/catalogs/skoda/CZ/OCT/663/4/411/411012
Increasing the size of my Karoq tyres.?.
As you can see below in the charts from wheel-size.com, the Karoq 4x4 uses bigger outside diameter tyres than the Karoq FWD (Front Wheel Drive). The Karoq 4x4 has 225/60R16, 225/55R17, 225/50R18, 225/45R19 tyre options. The Karoq FWD has 215/60R16, 215/55R17, 215/50R18, 225/40R19 tyre options. Skoda Karoq 2.0TDI 4x4 – Generation: NU7 [2017 .. 2022] – Market: EUDM – Power: 148 hp | 110 kW | 150 PS – Engine: 2.0L, DFFA, I4, Diesel – Options: SE, SE L, Ambition, Executive, Style, Scout, SportLine – Center Bore: 57.1 mm – PCD: 5x112 – Wheel Fasteners: Lug bolts – Wheel Tightening Torque: 140 Nm – Thread Size: M14 x 1.5 – Trim Production: [2017 .. 2021] Tire Rim 225/55R17 97V 7Jx17 ET45 2.4 225/60R16 98V 6Jx16 ET43 2.3 225/50R18 95V 7Jx18 ET45 2.4 225/45R19 92W 8Jx19 ET45 2.4 Skoda Karoq 2.0TDI FWD – Generation: NU7 [2017 .. 2022] – Market: EUDM – Power: 148 hp | 110 kW | 150 PS – Engine: 2.0L, DFFA, I4, Diesel – Options: SE, SE L, Ambition, Executive, Style, SportLine – Center Bore: 57.1 mm – PCD: 5x112 – Wheel Fasteners: Lug bolts – Wheel Tightening Torque: 140 Nm – Thread Size: M14 x 1.5 – Trim Production: [2018 .. 2021] Tire Rim 215/60R16 95V 6Jx16 ET43 2.2 215/55R17 94V 7Jx17 ET45 2.2 215/50R18 92V 7Jx18 ET45 2.4 225/40R19 93W 8Jx19 ET45 2.4 https://www.wheel-size.com/size/skoda/karoq/2020/#trim-20tdi-eudm-148 As you can see in the below Yeti photos, changing 225/50R17 to 235/55R17 gives the Yeti a more chunky look. For an even more chunky look on the karoq 4x4, maybe try 235/60R16 on 7Jx16 ET45 rims. 7Jx16 ET45 rims were a standard rim size on the Superb MK2 and Yeti, with steel and alloy rims being available in this size. The 235/60R16 could be an ideal "chunky" tyre size for the Karoq 4x4 because the outside diameter is less than 0.5% bigger than the standard 225/45R19 tyre size. Yokohama G015 Geolander AT - 235/60R16 100H https://www.camskill.co.uk/m62b0s425p148190/Yokohama_Tyres_Car_Yokohama_G015_Geolander_AT_Yokohama_G_015_-_235_60_R16_100H_TL_Fuel_Eff_%3A_E_Wet_Grip%3A_C_NoiseClass%3A_B_Noise%3A_72dB Yeti 225/50R17 top photo, 235/55R17 bottom photo
MK3? Shocks same as MK2?
Front springs L31 1K0411105DK 1K0 411 105 DK coil spring 3 paint marks orange 2 PR-L31 https://www.autodoc.co.uk/car-parts/oem/1k0411105dk?search=OEN+1K0411105DK&supplier[0]=85&supplier[1]=246&supplier[2]=85&supplier[3]=246 https://www.ebay.co.uk/itm/354419416797 Front shock absorbers G15 3C0413031AS 3C0 413 031 AS gas shock absorber 2 PR-G15 https://www.autodoc.co.uk/car-parts/oem/3c0413031as?search=OEN+3C0413031AS&supplier[0]=16 Skoda parts catalogue https://www.lllparts.co.uk/catalogs/skoda/CZ/SUP/632/4/411/411001
Replacement tyre(s)
Where is the air escaping? It might have nothing to do with the tyre. You might simply have a damaged or corroded rim. Sometimes it can be a leaky valve.
Skoda Fabia 1.0 TSI Colour Edition Wheels and tyres
According to Jurid on autodoc, 256mm front discs were fitted to cars up to and including 95HP. So for the Fabia MK3 1.2TSI 90HP and 1.0TSI 95HP 14" wheel will fits. 175/70R14 fitted to 5Jx14 ET35 5/100 57.1 rims is a standard tyre and rim size on the Fabia MK3. 175/70R14 has the same outside diameter and load index 84 (500kg) as the 185/60R15 tyre size. The 5Jx14 ET35 5/100 57.1 rim was used on cars such as the Fabia MK1/MK2/MK3. The Fabia MK1/MK2 used 165/70R14 tyres on this specification of rim whereas the later Fabia MK3 used 175/70R14 tyres on this specification of rim. Slightly oversize 185/70R14 fitted to the 5Jx14 ET35 5/100 57.1 rims would be a good alternative to 175/70R14 and 185/60R15 and give a super comfy ride. The Fabia MK4 has a 185/70R14 fitted to 5Jx14 ET38 5/100 57.1 option, although not necessarily in the UK where fashion dictates thin rubber bands. Vredestein Quatrac 5 185/70R14 88T https://www.camskill.co.uk/m137b0s7981p144829/Vredestein_Tyres_All_Season_Car_Vredestein_Quatrac5_Vredestein_Quatrac_5_-_185_70_R14_88T_TL_Fuel_Eff_%3A_D_Wet_Grip%3A_C_NoiseClass%3A_B_Noise%3A_69dB Skoda Fabia MK3 1.2TSI – Generation: Mk3 (NJ) [2015 .. 2022] – Market: EUDM – Power: 89 hp | 66 kW | 90 PS – Engine: 1.2L, CJZC, I4, Petrol – Options: Active, Ambition, Style, Monte Carlo – Center Bore: 57.1 mm – PCD: 5x100 – Wheel Fasteners: Lug bolts – Wheel Tightening Torque: 120 Nm – Thread Size: M14 x 1.5 – Trim Production: [2015 .. 2017] Tire Rim 185/60R15 84H 6Jx15 ET38 2.1 175/70R14 84T 5Jx14 ET35 2.1 215/45R16 85V 7Jx16 ET46 2.1 215/40R17 87T 7Jx17 ET46 2.2 Skoda Fabia 2017 1.0TSI – Generation: Mk3 (NJ) [2015 .. 2022] – Market: EUDM – Power: 94 hp | 70 kW | 95 PS – Engine: 1.0L, CHZB, I3, Petrol – Options: Active, Ambition, Style, Monte Carlo – Center Bore: 57.1 mm – PCD: 5x100 – Wheel Fasteners: Lug bolts – Wheel Tightening Torque: 120 Nm – Thread Size: M14 x 1.5 – Trim Production: [2017 .. 2018] Tire Rim 185/60R15 84T 6Jx15 ET38 2.1 175/70R14 85T 5Jx14 ET35 2.1 215/45R16 86T 7Jx16 ET46 2.1 215/40R17 87T 7Jx17 ET46 2.2 https://www.wheel-size.com/size/skoda/fabia/2017/#trim-12tsi-eudm-89
