Everything posted by Carlston
Roomster wheels on a Fabia?
Those rims are very heavy. 10.14kg https://eshop.skoda-auto.cz/cs_CZ/kolo-z-lehke-slitiny-line-15-pro-roomster-fabia-ii/p/5J0071495A+7ZS 7.5kg https://eshop.skoda-auto.cz/cs_CZ/kolo-z-lehke-slitiny-propeller-15-pro-fabia-iii-rapid/p/5JA071495A+8Z8
Anyone know whether the spare tyre from a Mark II will fit the Mark IV?
If a full-size spare wheel isn't listed for the Octavia MK4, it might be worth seeing if the Octavia MK3 full-size spare wheel fits. 205/55R16 fitted to 6.5Jx16 ET46 steel rim https://eshop.skoda-auto.cz/cs_CZ/kompletni-rezervni-kolo-16/p/5E0601011J Spare wheel replacement kit https://eshop.skoda-auto.cz/cs_CZ/sada-pro-vymenu-rezervniho-kola/p/5E0093860B Although 205/55R16 has a slightly smaller outside diameter than the standard Octavia MK4 205/60R16 tyre size, the Superb MK3 also used a 205/55R16 spare wheel with it's even bigger 215/60R16 standard tyre size.
Brake pad thickness
Assuming 256mm diameter front brake discs and not 276mm, the thickness of the front brake pads is 19.7mm which includes the metal backing plate.
Check the diameter of the front brake discs. The Octavia MK4 might have a minimum of 310mm/312mm diameter front brake discs. If so, a 15" rim won't clear the front brake calipers. Skoda sell a space saver for the Octavia MK4 125/70R18 Spare Wheel https://eshop.skoda-auto.cz/cs_CZ/kompletni-rezervni-kolo-18/p/5E3601011B Spare wheel replacement kit (includes polystyrene box, fixing screw with rose, retaining strap, jack, jack handle, wheel wrench, luggage compartment floor support) https://eshop.skoda-auto.cz/cs_CZ/sada-pro-vymenu-rezervniho-kola/p/5E3093860
Bilstein B6
They are often interchangeable. 1K0511115CS has the same specification as 5Q0511115AM even though they are from different generations of cars as you can see from the Kilen 65073 and Lesjofors 4295087 springs https://www.autodoc.co.uk/car-parts/oem/1k0511115cs?search=OEN+1K0511115CS&supplier[0]=253&supplier[1]=246 1K0511115CR, 1K0511115CS, 1K0511115CT are used on many Skodas including Octavia MK2, Superb MK2 and Yeti. Search results for Part number: '1K0511115CR' Catalog Model code Model Name Years Skoda OCT Octavia 2004 2005 2006 2007 2008 Skoda OCT Octavia 2009 2010 2011 2012 2013 Skoda SUP Superb 2008 2009 2010 2011 2012 2013 Skoda SUP Superb 2014 2015 2016 Skoda YET Yeti 2010 2011 2012 2013 Skoda YET Yeti 2014 2015 2016 http://www.oemepc.com/tvn_result/search/tvn/1K0511115CR Search results for Part number: '1K0511115CS' Catalog Model code Model Name Years Skoda OCT Octavia 2004 2005 2006 2007 2008 Skoda OCT Octavia 2009 2010 2011 2012 2013 Skoda SUP Superb 2008 2009 2010 2011 2012 2013 Skoda SUP Superb 2014 2015 2016 Skoda YET Yeti 2010 2011 2012 2013 Skoda YET Yeti 2014 2015 2016 http://www.oemepc.com/tvn_result/search/tvn/1K0511115CS Search results for Part number: '1K0511115CT' Catalog Model code Model Name Years Skoda OCT Octavia 2004 2005 2006 2007 2008 Skoda OCT Octavia 2009 2010 2011 2012 2013 Skoda SUP Superb 2008 2009 2010 2011 2012 2013 Skoda SUP Superb 2014 2015 2016 Skoda YET Yeti 2010 2011 2012 2013 Skoda YET Yeti 2014 2015 2016 http://www.oemepc.com/tvn_result/search/tvn/1K0511115CT
Bilstein B6
Octavia MK2 Scout (1) 1K0511115CR coil spring 1 paint mark 2 paint marks red green Model data: PR-1JB+0YJ (1) 1K0511115CS coil spring 1 paint mark 3 paint marks red green Model data: PR-1JB+0YK (1) 1K0511115CT coil spring 1 paint mark 1 paint mark rear red brown Model data: PR-1JB+0YL http://www.oemepc.com/skoda/part_single/catalog/sk/markt/CZ/modell/OCT/year/2006/drive_standart/419/hg_ug/511/subcategory/511012/part_id/2561497/lang/e Octavia MK3 Scout 1 5Q0511115AL coil spring Model data: PR-1JB+0YC (1) 5Q0511115AM coil spring Model data: PR-1JB,0YD (1) 5Q0511115AN coil spring Model data: PR-1JB+0YE http://www.oemepc.com/skoda/part_single/catalog/sk/markt/CZ/modell/OCT/year/2013/drive_standart/753/hg_ug/511/subcategory/511010/part_id/2563429/lang/e 1K0511115CR is the same as 5Q0511115AL (Wire Diameter 12.5mm, Length 378-380mm, Outer Diameter 114-115mm, Weight 2.4-2.45kg) 1K0511115CS is the same as 5Q0511115AM (Wire Diameter 12.75mm, Length 382-383mm, Outer Diameter 117mm, Weight 2.6kg) 1K0511115CT is the same as 5Q0511115AN (Wire Diameter 13mm, Length 382-383mm, Outer Diameter 117-118mm, Weight 2.75-2.8kg) Standard Springs for Superb MK3 estate 2.0TDI 4x4 (according to Kilen/Lesjofors) Front Springs 5Q0411105GN Rear Springs 3Q0511115M https://web.tecalliance.net/kilen/en/parts/cars/assigned?assemblyGroupId=100113&targetId=115169&typeNumber=115169&targetCountry=AT&groups=188&brands=176&page=0#@brc/brands:Car;targetType:cars/assem:SKODA%20SUPERB%20III%20Estate%20(3V5)%202.0%20TDI%204x4;targetType:cars;targetId:115169;typeNumber:115169;targetCountry:AT/lnkparts:Coil%20Springs;targetType:cars;assemblyGroupId:100113;targetId:115169;typeNumber:115169;targetCountry:AT;groups:188;brands:176;page:0 1K0511115CT https://www.autodoc.co.uk/car-parts/oem/1k0511115ct?search=OEN+1K0511115CT&supplier[0]=253&supplier[1]=16&supplier[2]=85&supplier[3]=112&supplier[4]=246&supplier[5]=253&supplier[6]=16&supplier[7]=85&supplier[8]=112&supplier[9]=246
Spare wheel / jack - polystyrene tray?
Use the OEM part number 6V0093860A to order from a UK Skoda dealer. The kit has everything except for the spare wheel. Spare wheel replacement kit Designed for: FABIA III. 988.00CZK (about £33.31) TECHNICAL SPECIFICATIONS 6V0093860A Black Polystyrene Polystyrene box, vehicle jack with information plate, special screw (rose) for attaching the spare wheel, holding strap, wheel wrench, assembly instructions. 15 kg INTENDED FOR: Fabia III (2014+) The spare wheel kit is intended for all drivers who prefer to equip a car with a spare wheel, instead of the tire repair kit for the most necessary range. Spare wheel set contains the necessary tools for replacing a defective wheel on the car, all tools are neatly stored in a polystyrene box, the box is secured in the recess of the spare wheel with a woven strap with a buckle. The spare wheel is not part of the set, it must be ordered separately from the ŠKODA Original Accessories range. A detailed description of the use of the spare wheel is given in the Vehicle Owner's Manual https://eshop.skoda-auto.cz/cs_CZ/sada-pro-vymenu-rezervniho-kola/p/6V0093860A The spare wheel on the Fabia MK3 will either be a 175/70R14 tyre fitted to a 5Jx14 ET35 5/100 steel rim or a 185/60R15 tyre fitted to a 6Jx15 ET38 5/100 steel rim. 1 6Q0601027AC steel rim 5 JX14 ET35 5/100 Model data: PR-C0D 6Q0601027AC03C rally black Period: 0814 (1) 6R0601027AE steel rim 6R0601027AE03C rally black 6JX15 ET38 Period: 0814 (1) 6R0601027R Cancelled since 01.09.2014 steel rim 6JX15 ET38 6R0601027R 03C rally black Period: 0814 http://www.oemepc.com/skoda/part_single/catalog/sk/markt/CZ/modell/FAB/year/2016/drive_standart/797/hg_ug/601/subcategory/601012/part_id/2543667/lang/e 5Jx14 ET35 5/100 Steel Rim https://www.mytyres.co.uk/rims/details?vehicleId=799637973241959524&rimCode=ALCAR5210 6Jx15 ET38 5/100 Steel Rim https://www.mytyres.co.uk/rims/details?vehicleId=799637973241959524&rimCode=ALCAR7760
Rear Suspension Information
The weight range 14 rear spring 3C0511115AJ on the Superb MK2 is called a weight range 9 rear spring on the VW Passat, and really should have been called a weight range 10 on the Superb MK2 because that is where it logically is. However, Skoda had already designated another spring weight range 10 so they couldn't do that...and this weight range 10 spring was logically only a weight range 6 spring...but Skoda had already designated another spring weight range 6... The VW Passat 2.0TDI 4x4 estate uses this rear spring according to gknautomotive.com rear axle | Skoda Superb 2011, suspension shock absorber (spring cyl.) rear combi (1) 3C0511115AJ coil spring 1 paint mark 1 paint mark 1 paint mark white lilac green Model data: PR-0YP http://www.oemepc.com/skoda/part_single/catalog/sk/markt/CZ/modell/SUP/year/2011/drive_standart/632/hg_ug/511/subcategory/511001/part_id/2561497/lang/e rear axle | Volkswagen Passat/4Motion/Santana 2015, suspension shock absorbers rear fr.wheel drv (1) 3C0511115AJ coil spring 1 paint mark 1 paint mark 1 paint mark white lilac green Model data: PR-1JA+0YJ PR-1JL+0YJ PR-UA5+0YJ PR-UA6+0YJ PR-UC8+0YJ http://www.oemepc.com/vw/part_single/catalog/vw/markt/RDW/modell/PA/year/2015/drive_standart/702/hg_ug/511/subcategory/511000/part_id/0/lang/e
2011 4x4 rear springs, help needed
The below two rear springs appear to be the next weight range up from 1K0511115DK, ie. 1K0511115CR, although they are both sold to replace both these OEM part numbers. The Spidan listing gives the game away, as Spidan lists the spring as having colour coding 1 red and 2 green, which is 1K0511115CR. Going up one weight range makes the spring about 5% stiffer, but the unladen ride height will stay the same because the uncompressed length will be a few millimetres less. Bilstein 36-257102 Sachs 994336 https://www.autodoc.co.uk/car-parts/oem/1k0511115dk?supplier[0]=16&supplier[1]=32 Octavia MK2 2004-2008 (1) 1K0511115DK coil spring 1 paint mark 1 paint mark 1 paint mark rear red green brown Model data: PR-1JB+0YH (1) 1K0511115CR coil spring 1 paint mark 2 paint marks red green Model data: PR-1JB+0YJ http://www.oemepc.com/skoda/part_single/catalog/sk/markt/CZ/modell/OCT/year/2004/drive_standart/419/hg_ug/511/subcategory/511010/part_id/0/lang/e Octavia MK2 2009-2013 (1) 1K0511115DK coil spring 1 paint mark 1 paint mark 1 paint mark rear red green brown Model data: PR-1JB+0YJ (1) 1K0511115CR coil spring 1 paint mark 2 paint marks red green Model data: PR-1JB+0YK http://www.oemepc.com/skoda/part_single/catalog/sk/markt/CZ/modell/OCT/year/2011/drive_standart/663/hg_ug/511/subcategory/511010/part_id/0/lang/e Notice that from 2004-2008, Skoda called the 1K0511115DK a weight range 8 rear spring on the Octavia MK2, but from 2009-2013 Skoda called the same spring a weight range 9 rear spring on the Octavia MK2. This shows that from 2009, Skoda softened the rear springs by 1 weight range on the Octavia MK2 with heavy duty suspension. 0YH is a weight range 8 rear spring. 0YJ is a weight range 9 rear spring. 0YK is a weight range 10 rear spring. SPIDAN Coil Spring Rear Axle Article number: 86359 Fitting Position: Rear Axle Spring Design:Coil spring with constant wire diameter Length [mm]:380 Diameter [mm]:115 Weight [kg]:2,40 Colour Coding:Green (2x), Red Vehicle Production Country:Czech Republic Wire Diameter [mm]:12,50 SPIDAN:Coil Spring ОЕМ NUMBER OEM reference number(s) comparable with the original spare part number OEN 1K0 511 115 CR — SKODA OEN 1K0 511 115 DK — VAG https://www.autodoc.co.uk/spidan/7445758
G15 means that the front shock absorbers have OEM part number 3C0413031AS (8) 3C0413031AS gas shock absorber Model data: PR-G15 front axle, steering | Skoda Superb 2011, suspension shock absorber (spring cyl.) anti-roll bar front combi http://www.oemepc.com/skoda/part_single/catalog/sk/markt/CZ/modell/SUP/year/2011/drive_standart/632/hg_ug/411/subcategory/411001/part_id/2561497/lang/e gknautomotive.com list 1K0511115BL as being suitable for the 2011 Superb MK2 estate 2.0TDI 170HP 4x4 The colour coding for 1K0511115BL is 1 white dot and 2 green dots. https://web.tecalliance.net/gkn/en/parts/1/86348/detail?targetType=cars&targetId=32789&typeNumber=32789&groups=188#@brc/brands:Car;targetType:cars/assem:SKODA%20SUPERB%20II%20Estate%20(3T5)%202.0%20TDI%204x4;targetType:cars;targetId:32789;typeNumber:32789/lnkparts:Coil%20Springs;targetType:cars;assemblyGroupId:100113;targetId:32789;typeNumber:32789;groups:188;brands:1;page:0/detail:86348;brandId:1;articleNo:86348;targetType:cars;targetId:32789;typeNumber:32789;groups:188 Eibach R10759 is sold to replace 1K0511115BK, 1K0511115BL, and 1K0511115BM. Sachs 994783 is sold to replace just 1K0511115BL. (1) 1K0511115BL coil spring 1 paint mark 2 paint marks rear white green Model data: PR-1JA+0YK rear axle | Skoda Superb 2011, suspension shock absorber (spring cyl.) rear combi http://www.oemepc.com/skoda/part_single/catalog/sk/markt/CZ/modell/SUP/year/2011/drive_standart/632/hg_ug/511/subcategory/511001/part_id/2561497/lang/e If you do have 1K0511115BL rear springs, they will be marked with 1 white dot and 2 green dots, and the car will have build codes 1JA and 0YK. 1K0511115BL on autodoc https://www.autodoc.co.uk/car-parts/oem/1k0511115bl?supplier[0]=112&supplier[1]=32 Before making any decisions, it's important to identify what rear springs the car came with out of the factory. It might for example have 1JB or 1JD build codes as follows: suspension shock absorber (spring cyl.) for models with heavy duty suspension PR-1JB suspension shock absorber (spring cyl.) for vehicles with higher vehicle chassis rear +10MM PR-1JD Build code 1JB means that the car has heavy duty suspension. Build code 1JD means that the car has a higher vehicle chassis. If the car has either of these build codes, the 1K0511115BL rear spring would not be correct as that belongs to a car with build code 1JA which is standard suspension. SPIDAN Coil Spring Rear Axle Article number: 86348 Fitting Position: Rear Axle Spring Design:Coil spring with constant wire diameter Length [mm]:365 Diameter [mm]:115 Weight [kg]:2,40 Colour Coding:Green (2x), White Wire Diameter [mm]:12,50 SPIDAN:Coil Spring ОЕМ NUMBER OEM reference number(s) comparable with the original spare part number 1K0 511 115 BL https://www.autodoc.co.uk/spidan/7445753
312mm for my new (to me) 05 plated 1.9 tdi estate
The charts are copied direct from wheel-size.com and include all their mistakes, of which there are too many to mention. It's not just tyre load indexes that are often wrong, but tyre pressures, rim widths, offsets, etc. However, below is my edited version: Skoda Fabia MK1 2005 1.9TDI – Power: 74kW | 101PS – Centre Bore: 57.1 – PCD: 5/100 – Wheel Bolts: M14x1.5 Tyre Rim 165/70R14 5Jx14 ET35 185/60R14 6Jx14 ET43 195/50R15 6Jx15 ET43 195/45R16 6.5Jx16 ET42 Skoda Fabia MK1 2005 1.9TDI RS – Power: 96kW | 131PS – Centre Bore: 57.1 – PCD: 5/100 – Wheel Bolts: M14x1.5 Tire Rim 195/50R15 6Jx15 ET43 195/45R16 6.5Jx16 ET37 https://www.wheel-size.com/size/skoda/fabia/2005/#trim-19tdi-eudm-129 Skoda Fabia | 2005 | wheels http://www.oemepc.com/skoda/parts_lst/markt/CZ/modell/FAB/year/2005/hg/6/catalog/sk/drive_standart/453/lang/e
Bilstein B6
I doubt the Eibach Pro Kit springs would lower the car as much as the H&R springs. Eibach springs tend to be more sensible and give a better ride than the rather extreme H&R.
312mm diameter front brake discs won't let you use anything smaller than 16" diameter front rims, so popular Fabia MK1 tyre sizes such as 185/60R14 and 195/50R15 can't be used. The ride on tyre sizes such as 195/45R16 fitted to 6.5J rims is hard and uncomfortable. They will perform great on a smooth racetrack, but on typical bumpy and potholed British roads, not so good. Skoda Fabia 2005 1.9TDI – Generation: Mk1 (6Y) [1999 .. 2007] – Power: 99 hp | 74 kW | 101 PS – Engine: 1.9L, ATD, AXR, I4, Diesel – Center Bore: 57.1 mm – PCD: 5x100 – Wheel Fasteners: Lug bolts – Wheel Tightening Torque: unknown – Thread Size: M14 x 1.5 – Trim Production: [1999 .. 2007] Tire Rim 165/70R14 82T 6Jx14 ET37 2.4 185/60R14 82H 6Jx14 ET37 2.3 / 2.4 195/50R15 82H 6Jx15 ET43 2.2 / 2.3 195/45R16 82V 6.5Jx16 ET43 2.2 / 2.3 205/45R16 82V 6.5Jx16 ET45 2.1 / 2.2 205/40R17 82V 7Jx17 ET45 2.1 / 2.2 Skoda Fabia 2005 1.9TDI – Generation: Mk1 (6Y) [1999 .. 2007] – Power: 129 hp | 96 kW | 131 PS – Engine: 1.9L, ASZ, BLT, I4, Diesel – Options: vRS – Center Bore: 57.1 mm – PCD: 5x100 – Wheel Fasteners: Lug bolts – Wheel Tightening Torque: unknown – Thread Size: M14 x 1.5 – Trim Production: [2003 .. 2007] Tire Rim 195/50R15 82V 6Jx15 ET43 2.2 / 2.3 195/45R16 82V 6.5Jx16 ET43 2.1 / 2.2 205/45R16 82V 6.5Jx16 ET45 2.1 / 2.2 205/40ZR17 82W 7Jx17 ET45 2.1 / 2.2 https://www.wheel-size.com/size/skoda/fabia/2005/#trim-19tdi-eudm-129
Bilstein B6
It's not the 19" wheels causing the low ride height, but the low ride height H&R springs. 235/45R18 tyres and 235/40R19 tyres have similar outside diameters. Outside diameter of 235/45R18 tyres is 668.7mm Outside diameter of 235/40R19 tyres is 670.6mm
A few queries
You could take a look on ebay to get an idea of prices, seaching using the OEM part number 5E0071499 (Anthracite) or 5E0071499B (Silver). Note that 5E0071499 is the same OEM part number as 5E0071499 HA7. The HA7 is the associated colour code, in this case anthracite. Similary, 5E0071499B is the same OEM part number as 5E0071499B 8Z8. The 8Z8 is the associated colour code, in this case silver. Check this is actually your OEM part number by looking on the back of the rims, as the OEM part number is always marked on the back of OEM alloy rims. Note that the zeros in this alphanumeric code are NOT capital letters, but numbers. So don't type 5EOO71499 if you want potential buyers to find your rims. To get an idea of new prices of OEM alloy rims for the Octavia MK3, take a look at "skoda eshop cz" converting the Czech currency into British Pounds. https://eshop.skoda-auto.cz/cs_CZ/hlinikove-disky/c/alloyWheels?q=%3ApriceAsc%3AcarType%3AOctavia%2BIII%2B%282017%2B%29%3AcarType%3AOctavia%2BIII%2B%282012-2017%29&page=1 X-TREM 19" light alloy wheel for OCTAVIA III RS Rim size: 7.5Jx19 ET51 TECHNICAL SPECIFICATIONS Product code 5E0071499 HA7 Colour Anthracite Material Light alloy Rim size 7.5Jx19 ET51 Tyre size 225/35R19 https://eshop.skoda-auto.cz/cs_CZ/kolo-z-lehke-slitiny-x-trem-19-pro-octavia-iii-rs/p/5E0071499++HA7 X-TREM 19" light alloy wheel for OCTAVIA III RS Rim size: 7.5Jx19 ET51 TECHNICAL SPECIFICATIONS Product code 5E0071499B 8Z8 Colour Silver metallic paint Material Light alloy Rim size 7.5Jx19 ET51 Tyre size 225/35R19 https://eshop.skoda-auto.cz/cs_CZ/kolo-z-lehke-slitiny-x-trem-19-pro-octavia-iii-rs/p/5E0071499B+8Z8
Change to 18" Gemini from 19" extreme alloys.
The Kodiaq's 340mm front calipers are the same as the Octavia MK3's 340mm front calipers, except the colour is sometimes different. The Kodiaq uses red or silver, whereas the Octavia MK3 only uses red. 340mm TRW Front Calipers 5G0615123B (Kodiaq, Octavia MK3) https://www.autodoc.co.uk/trw/7488952 340mm TRW Front Calipers 3C0615123 (Kodiaq, Superb MK2, Superb MK3) https://www.autodoc.co.uk/trw/2184642
Front Suspension Spring Dislocated
Front OEM Scout springs don't usually break after just 4 years. Maybe someone charged you for front OEM springs but fitted cheap aftermarket springs. If they are OEM 1K0411105DM front springs they will have 2 violet dots on them. Keep these old springs, clean them up, and check that they do have 2 violet dots. Aftermarket springs don't have these coloured dots. No dots, and someone has fitted cheap aftermarket springs. 1K0411105DM Front Springs 1K0411105DM 2 violet paint marks/dots
Kilen 23123 matches 1K0411105DM Available on ebay for £51.07 for both front springs (ie. under £26 each) https://www.ebay.co.uk/itm/174765026545?epid=897187141&hash=item28b0ceacf1%3Ag%3ADx4AAOSwx6ZgsMDL&LH_ItemCondition=3 KYB RA3364 also matches 1K0411105DM https://www.autodoc.co.uk/kyb/7909084
Michelin Cross Climate 2 (replaces cc plus)
Outside diameter of 225/45R18 tyre is 659.7mm Outside diameter of 205/55R17 is 657.3mm Outside diameter of 215/45R18 tyre is 650.7mm So 225/45R18 has a 1.4% bigger outside diameter than 215/45R18. But if you compare the 225/45R18 size to 205/55R17 (another standard tyre size) the difference is only 0.4%. The difference between the outside radius of a 225/45R18 tyre and a 215/45R18 tyre is 4.5mm. The difference between the width of a 225/45R18 tyre and a 215/45R18 tyre (when they are both fitted to a 7J rim width) is about 7mm NOT the 10mm which you might expect. PROXES COMFORT Developed to provide premium levels of stability and comfort for relaxed driving experience. Tire Size Tread Depth (mm) Overall Diameter (mm) Overall Width (mm) Approved Rim Width Range (inch) 215/45 R18 93W XL 7.5 651 213 7.0-7-8.0 PROXES COMFORT Developed to provide premium levels of stability and comfort for relaxed driving experience. Tire Size Tread Depth (mm) Overall Diameter (mm) Overall Width (mm) Approved Rim Width Range (inch) 225/45 R18 95W XL 7.6 659 225 7.0-7.5-8.5 Notice that the above 225/45R18 chart shows the tyre width when fitted to a 7.5J rim, but if fitted to a 7J rim it will only be about 220mm in width, ie. only 7mm wider than the 215/45R18 tyre. https://www.toyo.co.uk/tirefinder/index/width/225/aspect/45/rim/18
Aftermarket Alloys.
Winter Tyres According to wheel-size.com 235/60R18 103T will fit all models of the Enyaq iV Skoda Enyaq iV 2021 EV – Generation: I [2020 .. 2022] – Power: 201 hp | 150 kW | 204 PS – Engine: EBJC L1F Electric – Options: 80, Sportline 80 – Center Bore: 57.1 mm – PCD: 5x112 – Wheel Fasteners: Lug bolts – Wheel Tightening Torque: unknown – Thread Size: M14 x 1.5 – Trim Production: [2020 .. 2021] Tire Rim 235/50R20 100T 8Jx20 ET45 235/45R21 101T 8.5Jx21 ET40 235/60R18 103T 8Jx18 ET45 235/55R19 101T 8Jx19 ET45 235/55R19 101T 8Jx19 ET45 235/50R20 100T 8Jx20 ET45 235/45R21 101T 8.5Jx21 ET40 https://www.wheel-size.com/size/skoda/enyaq-iv/2021/ Continental WinterContact TS870P 235/60R18 107H XL https://www.mytyres.co.uk/rshop/tyre/Continental/WinterContact-TS-870-P/235-60-R18-107H-XL/D-124605
What size wheels/tyres will fit to Superb III
Skoda Superb MK3 Tire Rim 205/60R16 92V 6.5Jx16 ET41 2.3 / 2.1 215/60R16 95V 6.5Jx16 ET41 2.3 / 2.1 215/55R17 94V 6.5Jx17 ET41 2.3 / 2.1 215/55R17 94V 7Jx17 ET40 2.3 / 2.1 235/45R18 94W 8Jx18 ET44 2.4 / 2.2 235/40R19 96W 8Jx19 ET44 2.4 / 2.2 https://www.wheel-size.com/size/skoda/superb/2020/ The best ride comfort on standard tyres and rims will be 215/60R16 on 6.5Jx16 ET41 rims. However, I would go with 215/60R16 on 0.5" narrower 6Jx16 ET40 rims (from the Superb MK1). The narrower rims improve ride comfort even more. Alcar 9490 6Jx16 ET40 Steel Rim https://www.mytyres.co.uk/rims/details?vehicleId=180887804711015536&rimCode=ALCAR9490 Vredestein Quatrac 6 215/60R16 95H https://www.mytyres.co.uk/rshop/tyre/Vredestein/Quatrac/215-65-R16-98H/R-435880 Vredestein Quatrac 6 215/60R16 99V XL https://www.camskill.co.uk/m139b0s8007p202130/Vredestein_Tyres_All_Season_Car_Vredestein_Quatrac_6_-_215_60_R16_99V_XL_TL_Fuel_Eff_%3A_C_Wet_Grip%3A_B_NoiseClass%3A_2_Noise%3A_71dB 2020 Auto Bild All Season Tyre Test (includes Vredestein Quatrac 6) https://www.tyrereviews.com/Article/2020-Auto-Bild-All-Season-Tyre-Test.htm
225/45R18 could be used instead of 215/45R18. 225/45R18 has a 0.4% bigger outside diameter than 205/55R17. The Octavia MK3 uses a 7J rim width for it's 225/45 tyre and the Kamiq uses the same 7J rim width for it's 215/45 tyre. Skoda Octavia MK3 Tire Rim 225/45R17 91Y 7Jx17 ET49 Skoda Kamiq Tire Rim 215/45R18 89V 7Jx18 ET39
It's actually 66 sizes, not 107 sizes as shown below. However, the CrossClimate 2 is often available in more than one version of each size such as different speed ratings and load indexes making a total of 107 different versions: 15" Michelin CrossClimate 2 (7 Sizes) 175/65 185/60 185/65 195/55 195/60 195/65 205/60 16" Michelin CrossClimate 2 (18 Sizes) 185/50 185/55 195/45 195/50 195/55 195/60 195/65 205/45 205/50 205/55 205/60 215/45 215/55 215/60 215/65 225/50 225/55 225/60 17" Michelin CrossClimate 2 (16 Sizes) 205/45 205/50 205/55 215/40 215/45 215/50 215/55 215/60 215/65 225/45 225/50 225/55 225/60 235/45 235/55 245/45 18" Michelin CrossClimate 2 (12 Sizes) 215/40 225/40 225/45 235/40 235/45 235/50 235/55 235/60 245/40 245/45 255/45 265/35 19" Michelin CrossClimate 2 (11 Sizes) 205/55 225/40 235/40 235/45 235/50 235/55 245/35 245/40 245/45 255/35 255/40 20" Michelin CrossClimate 2 (2 Sizes) 195/55 275/45
Aftermarket Alloys.
245/45R20 could be used instead of 235/50R20. The Barum is available in this size for a lot less than £150. Barum Bravuris 5HM 245/45R20 103Y XL £101.90 https://www.camskill.co.uk/m63b0s5593p188793/Barum_Tyres_Car_Barum_Bravuris_5HM_-_245_45_R20_103Y_XL_FR_TL_Fuel_Eff_%3A_C_Wet_Grip%3A_B_NoiseClass%3A_2_Noise%3A_72dB
KYB RH2957 should fit the Octavia 2.0TDI MK2 Scout 4x4 https://www.ebay.co.uk/itm/234096696212?hash=item3681401b94%3Ag%3AJY8AAOSwYuhg9p8S&LH_ItemCondition=3 They are similar to OEM part numbers 1K0411105DK and 1K0411105DL. KYB RH2957 Coil Spring Front Axle Length [mm]: 348 Diameter [mm]: 149 Thickness [mm]: 13.5 Weight [kg]: 2.47 https://www.autodoc.co.uk/kyb/834293 Front Springs for Octavia 2.0TDI MK2 Scout 4x4 (1) 1K0411105DK coil spring 3 paint marks orange Model data: PR-L60 (1) 1K0411105DL coil spring 4 colour strokes orange Model data: PR-L61 (1) 1K0411105DM coil spring 2 paint marks violet Model data: PR-L66 (1) 1K0411105DN coil spring 3 paint marks 1 paint mark pink brown Model data: PR-L67 http://www.oemepc.com/skoda/part_single/catalog/sk/markt/CZ/modell/OCT/year/2008/drive_standart/419/hg_ug/411/subcategory/411012/part_id/2561497/lang/e
