Carlston
Everything posted by Carlston
  1. 5/100 57.1 Alloy Rims https://eshop.skoda-auto.cz/cs_CZ/hlinikove-disky/c/alloyWheels?q=%3AscoreDesc%3AcarType%3AFabia%2BII%2B%282006-2010%29%3AcarType%3AFabia%2BII%2B%282010-2014%29%3AcarType%3AFabia%2BIII%2B%282014%2B%29%3AcarType%3ARapid%2B%282012-2020%29%3AcarType%3AScala%2B%2F%2BKamiq%2B%282019%2B%29%3AcarType%3ARoomster%2B%282006-2010%29%3AcarType%3ARoomster%2B%282010-2015%29%3AcarType%3AKamiq%2B%282019%2B%29%3AcarType%3AScala%2B%282019%2B%29&text=#
  2. I would put a small piece of masking tape where the chip is. Then when the springs are fitted, coat the chip with a tiny squirt of motorcycle chain lube or grease to stop it rusting. Most people have a garage to change springs, and I doubt they would worry about chipped coatings. The garage might roughly handling the springs on concrete and add an extra chip. Anyhow, springs usually break at the ends...usually the last half turn or so...as this is where the stress point is. Many people will chip front springs using coil spring compressors. Were the boxes unsealed? or could the chip have been done in the factory before boxing?
  3. You might want to carefully take some measurements and write down the specification of each spring. This is so that if you notice a problem after you have fitted them, you can refer to your notes. For example, if one side is higher than the other, if the back end is high or low, if the ride seems too hard or too soft, etc. Weight: Wire Diameter: Length: Outer Diameter: Number of Coil Turns: If they are a matched pair, they should be within a few grams of each other. They should be within a couple of millimetres height difference...preferably you won't be able to spot any difference in height when held up together.
  4. The problem of soft rear Octavia springs started on 06.03.2006 when a switch was made to softer rear springs. Here's an example. Until 05.03.2006, Octavia MK2s with build codes 1JA+0YD were fitted with 1K0511115BF rear springs. From 06.03.2006 Octavia MK2s with build codes 1JA+0YD were fitted with 1K0511115BD rear springs. Now 1K0511115BD rear springs are two weight ranges softer than 1K0511115BF, which is about 10% softer...or to put it another way, until 2006 the rear springs were about 10% stiffer. (1) 1K0511115BF coil spring 1 paint mark 3 paint marks D >> - 05.03.2006 white yellow Model data: PR-1JA+0YD (1) 1K0511115BD coil spring 1 paint mark 1 paint mark D - 06.03.2006>> white yellow Model data: PR-1JA+0YD http://www.oemepc.com/skoda/part_single/catalog/sk/markt/CZ/modell/OCT/year/2006/drive_standart/419/hg_ug/511/subcategory/511001/part_id/2561497/lang/e The problem has continued with Octavia MK3s and MK4s. So to correct the problem, simply change the rear springs to 1 or 2 weight ranges stiffer. However, if you've got your eye on comfort, I suggest you don't go more than 1 weight range stiffer. Cars that came with factory fitted towbars will already have rear springs 1 weight range stiffer. There's no need to fit lowering springs, as simply fitting 10% stiffer springs and keeping the ride height the same will enable better cornering...at the expense of a harder ride. Most people prefer the more comfortable ride, hence the softer springs Skoda started fitting in 2006.
  5. What are the official tyre pressures for the various tyre sizes on the 2017 SEAT Toledo IV 1.2TSI 81kW ? I've seen 32psi (2.2 Bar) front and 29psi (2.0 Bar) rear tyres pressure mentioned on wheel-size.com for the 185/60R15 tyre size. 185/60R15 has an 84 (500kg) load index, whereas 185/65R15 has an 88 (560kg) load index. If the above tyre pressures are correct (presumably for a lightly loaded car with just two passengers), then you can drop the tyre pressures by 3psi (0.2 Bar), to 29psi (2.0 Bar) front and 26psi (1.8 Bar) rear. You are correct in that the relatively wide 6J rims are stretching the sidewalls on the 185/65 tyres thereby making them less flexible and thereby giving a harder ride. 185/65R14 tyres have the same outside diameter as 195/55R15 tyres. As you are reluctant to use 15" tyres with a larger outside diameter than standard, I would suggest using the standard 185/60R15 tyre size on relatively narrow 5Jx15 ET28 rims. Alternatively, 195/55R15 on 5.5J rims. There's not much choice in steel 5.5J rims, but 5.5Jx15 ET34 and 5.5Jx15 ET40 rims are available in Europe. You would notice a softer ride fitting 195/55R15 tyres to narrower 5.5J rims instead of 6J rims. For comfort, 185/60R15 is a better choice than the low profile stiffer carcass 195/55R15. Although 195/55R15 fitted to a 5.5J rim may be similar to a 185/60R15 fitted to a 6J rim. It's disappointing that you don't have 256mm diameter front discs, as that would allow 185/65R14 tyres on relatively narrow 5Jx14 ET35 or 5Jx14 ET38 rims. The Toyota Aygo uses 165/65R14 and 165/60R15 tyres on relatively narrow 4.5J rims, so 185/65R14 and 185/60R15 tyres fitted to 5J rims give a similar fit. The Toyota Aygo fitment of these two 165 tyre sizes is unusual to such narrow rims as the 4.5J size. Usually these 165 tyre sizes are fitted to wider 5J rims by motor manufacturers. Toyota will have done this to prioritise comfort over handling. In doing this, Toyota have risked upsetting motoring journalists when they drive hell for leather around a race track, but for everyday UK motorists many will approve of the improved ride comfort. It's certainly the way I set my cars up. Two oversize 15" tyres that you might want to consider are 175/65R15 on 5Jx15 ET28 rims, and 195/60R15 on 5.5Jx15 ET40 rims. These are both slightly less oversize than 185/65R15.
  6. gknautomotive.com lists both versions for the Octavia MK2 1.6TDI hatchback. The 1K0511115BD version has an 11.25mm wire diameter, whereas the 1K0511115BE version is stiffer with an 11.75mm wire diameter. The BE version is for things like towing a caravan, and it will give a harder more uncomfortable ride in normal use. It's best to stick to the standard BD version unless you really need stiffer rear springs. 1K0 511 115 BD Fitting Position Rear Axle Wire Diameter 11,25 mm Length 352 mm Outer diameter 110 mm Weight 1,75 kg https://web.tecalliance.net/gkn/en/parts/1/56654/detail?targetType=cars&targetId=31590&typeNumber=31590&groups=188#@brc/brands:Car;targetType:cars/assem:SKODA%20OCTAVIA%20III%20(1Z3)%201.6%20TDI;targetType:cars;targetId:31590;typeNumber:31590/lnkparts:Coil%20Springs;targetType:cars;assemblyGroupId:100113;targetId:31590;typeNumber:31590;groups:188;brands:1;page:0/detail:56654;brandId:1;articleNo:56654;targetType:cars;targetId:31590;typeNumber:31590;groups:188 1K0 511 115 BE Fitting Position Rear Axle Wire Diameter 11,75 mm Length 348 mm Outer diameter 113 mm Weight 1,90 kg https://web.tecalliance.net/gkn/en/parts/1/86607/detail?targetType=cars&targetId=31590&typeNumber=31590&groups=188#@brc/brands:Car;targetType:cars/assem:SKODA%20OCTAVIA%20III%20(1Z3)%201.6%20TDI;targetType:cars;targetId:31590;typeNumber:31590/lnkparts:Coil%20Springs;targetType:cars;assemblyGroupId:100113;targetId:31590;typeNumber:31590;groups:188;brands:1;page:0/detail:86607;brandId:1;articleNo:86607;targetType:cars;targetId:31590;typeNumber:31590;groups:188
  7. (1) 1K0511115BD coil spring 1 paint mark 1 paint mark white yellow Model data: PR-1JA+0YD http://www.oemepc.com/skoda/part_single/catalog/sk/markt/CZ/modell/OCT/year/2013/drive_standart/663/hg_ug/511/subcategory/511000/part_id/0/lang/e
  8. rear axle | Skoda Octavia MK2 2009, suspension shock absorber (spring cyl.) for models with heavy duty suspension rear sedan: fr.wheel drv PR-1JB (1) 1K0511115CR coil spring 1 paint mark 2 paint marks red green Model data: PR-1JB+0YK (1) 1K0511115CS coil spring 1 paint mark 3 paint marks red green Model data: PR-1JB+0YL (1) 1K0511115CT coil spring 1 paint mark 1 paint mark rear red brown Model data: PR-1JB+0YM http://www.oemepc.com/skoda/part_single/catalog/sk/markt/CZ/modell/OCT/year/2009/drive_standart/663/hg_ug/511/subcategory/511010/part_id/0/lang/e rear axle | Skoda Octavia MK3 2013, suspension impact padding SCOUT 4wd PR-0N4,1JB 1 5Q0511115AL coil spring Model data: PR-1JB+0YC (1) 5Q0511115AM coil spring Model data: PR-1JB,0YD (1) 5Q0511115AN coil spring Model data: PR-1JB+0YE http://www.oemepc.com/skoda/part_single/catalog/sk/markt/CZ/modell/OCT/year/2013/drive_standart/753/hg_ug/511/subcategory/511010/part_id/0/lang/e The following Octavia MK2 and Octavia MK3 rear springs appear to be the same, and interchangeable. You can compare the specifications such as wire diameter, length, outer diameter, number of coil turns, weight. 1K0511115CR is the same as 5Q0511115AL (Wire Diameter 12.5mm, Length 378-380mm, Outer Diameter 114-115mm, Weight 2.4-2.45kg) https://web.tecalliance.net/gkn/en/parts/1/86359/detail?query=1K0511115CR&numberType=1&oe=1K0511115CR&groups=188#@brc/search:Search%20by%20any%20number%201K0511115CR;query:1K0511115CR;groups:188;brands:1;page:0/detail:86359;brandId:1;articleNo:86359;query:1K0511115CR;numberType:1;oe:1K0511115CR;groups:188 https://web.tecalliance.net/gkn/en/parts/1/87730/detail?query=5Q0511115AL&numberType=1&oe=5Q0511115AL&groups=188#@brc/search:Search%20by%20any%20number%205Q0511115AL;query:5Q0511115AL;groups:188;brands:1;page:0/detail:87730;brandId:1;articleNo:87730;query:5Q0511115AL;numberType:1;oe:5Q0511115AL;groups:188 1K0511115CS is the same as 5Q0511115AM (Wire Diameter 12.75mm, Length 382-383mm, Outer Diameter 117mm, Weight 2.6kg) https://web.tecalliance.net/gkn/en/parts/1/86501/detail?query=1K0511115CS&numberType=1&oe=1K0511115CS&groups=188#@brc/search:Search%20by%20any%20number%201K0511115CS;query:1K0511115CS;groups:188;brands:1;page:0/detail:86501;brandId:1;articleNo:86501;query:1K0511115CS;numberType:1;oe:1K0511115CS;groups:188 https://web.tecalliance.net/gkn/en/parts/1/87970/detail?query=5Q0511115AM&numberType=1&oe=5Q0511115AM&groups=188#@brc/search:Search%20by%20any%20number%205Q0511115AM;query:5Q0511115AM;groups:188;brands:1;page:0/detail:87970;brandId:1;articleNo:87970;query:5Q0511115AM;numberType:1;oe:5Q0511115AM;groups:188 1K0511115CT is the same as 5Q0511115AN (Wire Diameter 13mm, Length 382-383mm, Outer Diameter 117-118mm, Weight 2.75-2.8kg) https://web.tecalliance.net/gkn/en/parts/1/87414/detail?query=1K0511115CT&numberType=1&oe=1K0511115CT&groups=188#@brc/search:Search%20by%20any%20number%201K0511115CT;query:1K0511115CT;groups:188;brands:1;page:0/detail:87414;brandId:1;articleNo:87414;query:1K0511115CT;numberType:1;oe:1K0511115CT;groups:188 https://web.tecalliance.net/gkn/en/parts/1/87971/detail?query=5Q0511115AN&numberType=1&oe=5Q0511115AN&groups=188#@brc/search:Search%20by%20any%20number%205Q0511115AN;query:5Q0511115AN;groups:188;brands:1;page:0/detail:87971;brandId:1;articleNo:87971;query:5Q0511115AN;numberType:1;oe:5Q0511115AN;groups:188 KYB RH6426 matching 1K0511115CT is about £50 for the pair on ebay, and can be used to replace 5Q0511115AN. The Sachs 992103 matching 5Q0511115AN is about £100 for the pair. https://www.ebay.co.uk/itm/2x-Kayaba-RH6426-Rear-Suspension-Coil-Springs-OCTAVIA-II-SUPERB-II/223591301666?hash=item340f148222%3Ag%3AMdAAAOSwpc5dMCXZ&LH_ItemCondition=1000 The VW group may be hiding the fact that some of their newer cars are using springs from their older cars, ie. using more than one OEM part number for what is essentially the same spring. When cars get older, replacement aftermarket springs tend to get cheaper. Car manufacturers make a lot of money selling springs, often charging between £60 to £120 for just one spring. It's therefore in the car manufacturer's interest to hide the fact that some of the springs used on newer models are actually from older models...like in the examples above.
  9. The £30 Halfords 2 tonne trolley jack is unusual among cheap 2 tonne trolley jacks in that it has a bigger/wider 67mm outside diameter saddle. Minimum saddle height 14cm. Maximum saddle height 34cm. https://www.halfords.com/tools/garage-workshop/axle-stands-trolley-jacks/halfords-2-tonne-hydraulic-trolley-jack-657081.html?utm_medium=affiliate&utm_source=skimlinks_phg&utm_campaign=phgreferral The 2 tonne Halfords trolley jack has a 67mm outside diameter saddle. The relevance of this, is that it will allow a junior ice hockey puck (60mm x 20mm) to be used as a jacking pad. You do however have to remove the inner saddle to fit the 60mm x 20mm rubber jacking pad. This is easy, as it is only held in place with one circlip. Even the big Halfords 3 tonne trolley jack uses the same size saddle, so again the "junior ice hockey puck" could be used as a jacking pad to prevent metal to metal contact between the trolley jack saddle and the underside of the car. Minimum height 14cm. Maximum height 43cm. So the 3 tonne jack has a maximum saddle height of 43cm compared to the maximum saddle height of 34cm on the smaller 2 tonne trolley jack. This extra 9cm (3.5") could come in handy when placing the car on axle stands, although a block of wood could be used as a workaround with the smaller jack.
  10. I've only found two Eibach Pro-Kit rear springs (F11-70-012-01-HA and F11-15-007-15-HA) listed for the Octavia MK3. As you can see below, it's a one size fits all approach. The F11-15-007-15-HA model will even fit the Superb MK2 as well as the Octavia MK3. No distinction is being made between independent rear suspension and non-independent rear suspension. If this is your idea of tuning your car's suspension to perfection, then go for it. But to sell the same rear spring for the Octavia MK3 1.0TSI hatchback as the Superb MK2 3.6 V6 4x4 estate sounds a little imprecise to me. Eibach Replacement Pro-Kit Spring F11-15-007-15-HA https://www.eibachshop.co.uk/eibach-replacement-prokit-spring-f111500715ha_p32476198.htm Eibach Replacement Pro-Kit Spring F11-15-007-15-HA SKODA OCTAVIA III (5E3, NL3, NR3) 1.0 TSI 2016-05 - On SKODA OCTAVIA III (5E3, NL3, NR3) 1.2 TSI 2012-11 - On SKODA OCTAVIA III (5E3, NL3, NR3) 1.2 TSI 2015-05 - 2017-02 SKODA OCTAVIA III (5E3, NL3, NR3) 1.4 TSI 2012-11 - On SKODA OCTAVIA III (5E3, NL3, NR3) 1.4 TSI 2014-08 - On SKODA OCTAVIA III (5E3, NL3, NR3) 1.5 TSI 2017-02 - On SKODA OCTAVIA III (5E3, NL3, NR3) 1.6 2014-01 - On SKODA OCTAVIA III (5E3, NL3, NR3) 1.6 TDI 2012-11 - On SKODA OCTAVIA III (5E3, NL3, NR3) 1.6 TDI 2013-05 - On SKODA OCTAVIA III (5E3, NL3, NR3) 1.6 TDI 2017-02 - On SKODA OCTAVIA III (5E3, NL3, NR3) 1.6 TDI 4x4 2014-09 - On SKODA OCTAVIA III (5E3, NL3, NR3) 1.6 TDI 4x4 2015-05 - On SKODA OCTAVIA III (5E3, NL3, NR3) 1.6 TDI 4x4 2017-02 - On SKODA OCTAVIA III (5E3, NL3, NR3) 1.8 TSI 2012-11 - On SKODA OCTAVIA III (5E3, NL3, NR3) 1.8 TSI 4x4 2014-09 - On SKODA OCTAVIA III (5E3, NL3, NR3) 2.0 TDI / TDI RS 4x4 2013-05 - On SKODA OCTAVIA III (5E3, NL3, NR3) 2.0 TDI 2012-11 - On SKODA OCTAVIA III (5E3, NL3, NR3) 2.0 TDI 4x4 2014-09 - On SKODA OCTAVIA III (5E3, NL3, NR3) 2.0 TDI RS 2013-05 - On SKODA OCTAVIA III (5E3, NL3, NR3) 2.0 TSI 2017-02 - On SKODA OCTAVIA III (5E3, NL3, NR3) 2.0 TSI 4x4 2019-02 - On SKODA OCTAVIA III (5E3, NL3, NR3) 2.0 TSI RS 2013-05 - On SKODA OCTAVIA III (5E3, NL3, NR3) 2.0 TSI RS 2015-05 - On SKODA OCTAVIA III (5E3, NL3, NR3) 2.0 TSI RS 2017-02 - On SKODA OCTAVIA III Combi (5E5, 5E6) 1.0 TSI 2016-05 - On SKODA OCTAVIA III Combi (5E5, 5E6) 1.2 TSI 2012-11 - On SKODA OCTAVIA III Combi (5E5, 5E6) 1.2 TSI 2015-05 - 2017-02 SKODA OCTAVIA III Combi (5E5, 5E6) 1.4 TSI 2012-11 - On SKODA OCTAVIA III Combi (5E5, 5E6) 1.4 TSI 2014-08 - On SKODA OCTAVIA III Combi (5E5, 5E6) 1.5 TSI 2017-02 - On SKODA OCTAVIA III Combi (5E5, 5E6) 1.6 2014-01 - On SKODA OCTAVIA III Combi (5E5, 5E6) 1.6 TDI 2012-11 - On SKODA OCTAVIA III Combi (5E5, 5E6) 1.6 TDI 2013-05 - On SKODA OCTAVIA III Combi (5E5, 5E6) 1.6 TDI 2017-02 - On SKODA OCTAVIA III Combi (5E5, 5E6) 1.6 TDI 4x4 2012-11 - On SKODA OCTAVIA III Combi (5E5, 5E6) 1.6 TDI 4x4 2015-05 - On SKODA OCTAVIA III Combi (5E5, 5E6) 1.6 TDI 4x4 2017-02 - On SKODA OCTAVIA III Combi (5E5, 5E6) 1.8 TSI 2012-11 - On SKODA OCTAVIA III Combi (5E5, 5E6) 1.8 TSI 4x4 2012-11 - On SKODA OCTAVIA III Combi (5E5, 5E6) 2.0 TDI / TDI RS 4x4 2014-09 - On SKODA OCTAVIA III Combi (5E5, 5E6) 2.0 TDI 2012-11 - On SKODA OCTAVIA III Combi (5E5, 5E6) 2.0 TDI 4x4 2012-11 - On SKODA OCTAVIA III Combi (5E5, 5E6) 2.0 TDI RS 2013-05 - On SKODA OCTAVIA III Combi (5E5, 5E6) 2.0 TSI 2017-02 - On SKODA OCTAVIA III Combi (5E5, 5E6) 2.0 TSI 4x4 2019-02 - On SKODA OCTAVIA III Combi (5E5, 5E6) 2.0 TSI RS 2012-11 - On SKODA OCTAVIA III Combi (5E5, 5E6) 2.0 TSI RS 2015-05 - On SKODA OCTAVIA III Combi (5E5, 5E6) 2.0 TSI RS 2017-02 - On SKODA SUPERB II (3T4) 1.4 TSI 2008-07 - 2015-05 SKODA SUPERB II (3T4) 1.6 TDI 2010-09 - 2015-05 SKODA SUPERB II (3T4) 1.8 TSI 2008-03 - 2015-05 SKODA SUPERB II (3T4) 1.8 TSI 2009-03 - 2015-05 SKODA SUPERB II (3T4) 1.8 TSI 4x4 2008-11 - 2015-05 SKODA SUPERB II (3T4) 1.8 TSI 4x4 2009-03 - 2015-05 SKODA SUPERB II (3T4) 1.9 TDI 2008-03 - 2010-11 SKODA SUPERB II (3T4) 2.0 TDI 16V 2009-01 - 2015-05 SKODA SUPERB II (3T4) 2.0 TDI 16V 4x4 2010-11 - 2015-05 SKODA SUPERB II (3T4) 2.0 TDI 2008-03 - 2010-05 SKODA SUPERB II (3T4) 2.0 TDI 2008-07 - 2015-05 SKODA SUPERB II (3T4) 2.0 TDI 4x4 2008-09 - 2015-05 SKODA SUPERB II (3T4) 2.0 TSI 2010-05 - 2015-05 SKODA SUPERB II (3T4) 3.6 FSI 4x4 2008-11 - 2015-05 SKODA SUPERB II Estate (3T5) 1.4 TSI 2009-10 - 2015-05 SKODA SUPERB II Estate (3T5) 1.6 TDI 2010-09 - 2015-05 SKODA SUPERB II Estate (3T5) 1.8 TSI 2009-10 - 2015-05 SKODA SUPERB II Estate (3T5) 1.8 TSI 4x4 2009-10 - 2015-05 SKODA SUPERB II Estate (3T5) 1.9 TDI 2009-10 - 2010-11 SKODA SUPERB II Estate (3T5) 2.0 TDI 16V 2009-10 - 2015-05 SKODA SUPERB II Estate (3T5) 2.0 TDI 16V 4x4 2010-11 - 2015-05 SKODA SUPERB II Estate (3T5) 2.0 TDI 2009-10 - 2010-03 SKODA SUPERB II Estate (3T5) 2.0 TDI 2009-10 - 2015-05 SKODA SUPERB II Estate (3T5) 2.0 TDI 4x4 2009-10 - 2015-05 SKODA SUPERB II Estate (3T5) 2.0 TSI 2010-05 - 2015-05 SKODA SUPERB II Estate (3T5) 3.6 V6 4x4 2009-10 - 2015-05
  11. Octavia MK3 VRS Hatchback Rear Springs 5Q0511115Q Length: 332mm Diameter: 106mm Wire Thickness: 11.25mm Weight: 1.7kg KYB RA7156 Kilen 63142 Octavia MK3 VRS Estate Rear Springs 5Q0511115R Length: 342mm Diameter: 106mm Wire Diameter: 11.25mm Weight: 1.6kg KYB RA7157 Kilen 63143
  12. Independent Rear Sports Springs 5Q051111P Wire Diameter 11,25 mm Length 326 mm Outer diameter 105 mm Weight 1,65 kg https://web.tecalliance.net/gkn/en/parts/1/87786/detail?query=5Q0511115P&numberType=1&oe=5Q0511115P#@brc/search:Search%20by%20any%20number%205Q0511115P;query:5Q0511115P;page:0/detail:87786;brandId:1;articleNo:87786;query:5Q0511115P;numberType:1;oe:5Q0511115P Independent Rear Sports Springs 5Q0511115Q 5Q0511115R Wire Diameter 11,25 mm Length 335 mm Outer diameter 106 mm Weight 1,70 kg https://web.tecalliance.net/gkn/en/parts/1/87787/detail?query=5Q0511115R&numberType=1&oe=5Q0511115R#@brc/search:Search%20by%20any%20number%205Q0511115R;query:5Q0511115R;page:0/detail:87787;brandId:1;articleNo:87787;query:5Q0511115R;numberType:1;oe:5Q0511115R Non-Independent Rear Sports Springs 5Q0511121AL 5Q0511121AM 5Q0511121CS 5Q0511121CT Wire Diameter 11,00 mm Length 321 mm Outer diameter 111 mm Weight 1,45 kg https://web.tecalliance.net/gkn/en/parts/1/87823/detail?query=5Q0511121AM&numberType=1&oe=5Q0511121AM&groups=188#@brc/search:Search%20by%20any%20number%205Q0511121AM;query:5Q0511121AM;groups:188;brands:1;page:0/detail:87823;brandId:1;articleNo:87823;query:5Q0511121AM;numberType:1;oe:5Q0511121AM;groups:188 Non-Independent Rear Sport Springs 5Q0511121AN 5Q0511121DA Wire Diameter 11,00 mm Length 321 mm Outer diameter 110 mm Weight 1,45 kg https://web.tecalliance.net/gkn/en/parts/1/87824/detail?query=5Q0511121AN&numberType=1&oe=5Q0511121AN&groups=188#@brc/search:Search%20by%20any%20number%205Q0511121AN;query:5Q0511121AN;groups:188;brands:1;page:0/detail:87824;brandId:1;articleNo:87824;query:5Q0511121AN;numberType:1;oe:5Q0511121AN;groups:188 The independent rear sports springs have an 11.25mm wire diameter and 7.5 coil turns. The non-independent rear sport springs have an 11mm wire diameter and 6.75 coil turns. If the number of coil turns were equal, the 11.25mm wire diameter spring would be about 5% harder, but because the 11.25mm wire diameter spring has about 10% more coil turns it's actually about 5% softer. The spring with 7.5 coil turns should last longer than the spring with 6.75 coil turns because each coil turn is flexing less.
  13. Kilen 65108 is sold to replace the following OEM part numbers 5Q0511115BF 5Q0511115DP 5Q0511121AJ https://www.autodoc.co.uk/kilen/10080538 Independent Rear Suspension 5Q0511115 A B C D E F G H J K L M N P Q R S T K AA AB AC AF AG AH AJ AK AL AM BF BG BH BJ BK BL Standard Rear Springs 1JA A B C D E F G H J K BF BG BH BJ BK BL Sports Rear Springs 1JC M N P Q R S T AA AB AC Raised Rear Springs UC7 B C E L AF AG AH AJ AK AL AM Non-Independent Rear Suspension 5Q0511121AA AB AC AD AE AF AG AH AJ AK AL AM AN AP AQ AR AS AT BA BB BC BD BE BF BG BH BJ Standard Rear Springs 1JA AA AB AC AD AE AF AG AH AJ Sports Rear Springs 1JC AK AL AM AN AP AQ AR AS AT Raised Rear Springs UC7 BA BB BC BD BE BF BG BH BJ
  14. (3) 5Q0512297B Cancelled since 01.09.2014 underlay lower 5 5Q0512149 Cancelled since 01.09.2014 underlay upper rear axle | Skoda Octavia 2016, suspension shock absorbers PR-0N4 fr.wheel drv http://www.oemepc.com/skoda/part_single/catalog/sk/markt/CZ/modell/OCT/year/2016/drive_standart/753/hg_ug/511/subcategory/511001/part_id/0/lang/e 5Q0511115 A B C D E F G H J K L M N P Q R S T K AA AB AC AF AG AH AJ AK AL AM BF BG BH BJ BK BL rear axle | Skoda Octavia 2016, suspension gas shock absorber PR-0N1 http://www.oemepc.com/skoda/part_single/catalog/sk/markt/CZ/modell/OCT/year/2016/drive_standart/753/hg_ug/511/subcategory/511000/part_id/0/lang/e 5Q0511121AA AB AC AD AE AF AG AH AJ AK AL AM AN AP AQ AR AS AT BA BB BC BD BE BF BG BH BJ The OEM part numbers for the lower underlay and upper underlay for both types of rear suspension are the same. This means that the ends of the rear spring coils are the same. Together with the similar specifications wire diameter, length, outer diameter, weight, and number of coil turns...they look very much two peas out of the same pod.
  15. Octavia MK3 2.0TDI 150HP Hatchback Rear Springs 5Q05111121AD 5Q0511121AE https://web.tecalliance.net/gkn/en/parts/1/87627/detail?targetType=cars&targetId=58761&typeNumber=58761&groups=188#@brc/brands:Car;targetType:cars/assem:SKODA%20OCTAVIA%20IV%20(5E3%2C%20NL3%2C%20NR3)%202.0%20TDI;targetType:cars;targetId:58761;typeNumber:58761/lnkparts:Coil%20Springs;targetType:cars;assemblyGroupId:100113;targetId:58761;typeNumber:58761;groups:188;brands:1;page:0/detail:87627;brandId:1;articleNo:87627;targetType:cars;targetId:58761;typeNumber:58761;groups:188 Wire Diameter 10,75 mm Length 348 mm Outer diameter 107 mm Weight 1,55 kg Octavia MK3 2.0TDI 184HP VRS Hatchback Rear Springs 5Q0511115P https://web.tecalliance.net/gkn/en/parts/1/87786/detail?targetType=cars&targetId=59676&typeNumber=59676&groups=188#@brc/brands:Car;targetType:cars/assem:SKODA%20OCTAVIA%20IV%20(5E3%2C%20NL3%2C%20NR3)%202.0%20TDI%20RS;targetType:cars;targetId:59676;typeNumber:59676/lnkparts:Coil%20Springs;targetType:cars;assemblyGroupId:100113;targetId:59676;typeNumber:59676;groups:188;brands:1;page:0/detail:87786;brandId:1;articleNo:87786;targetType:cars;targetId:59676;typeNumber:59676;groups:188 Wire Diameter 11,25 mm Length 326 mm Outer diameter 105 mm Weight 1,65 kg Octavia MK3 2.0TDI 150HP Estate Rear Springs 5Q0511121AF https://web.tecalliance.net/gkn/en/parts/1/87783/detail?targetType=cars&targetId=58767&typeNumber=58767&groups=188#@brc/brands:Car;targetType:cars/assem:SKODA%20OCTAVIA%20IV%20Combi%20(5E5%2C%205E6)%202.0%20TDI;targetType:cars;targetId:58767;typeNumber:58767/lnkparts:Coil%20Springs;targetType:cars;assemblyGroupId:100113;targetId:58767;typeNumber:58767;groups:188;brands:1;page:0/detail:87783;brandId:1;articleNo:87783;targetType:cars;targetId:58767;typeNumber:58767;groups:188 Wire Diameter 11,25 mm Length 341 mm Outer diameter 109 mm Weight 1,75 kg Octavia MK3 184HP VRS Estate Rear Springs 5Q0511115Q 5Q0511115R https://web.tecalliance.net/gkn/en/parts/1/87787/detail?targetType=cars&targetId=59679&typeNumber=59679&groups=188#@brc/brands:Car;targetType:cars/assem:SKODA%20OCTAVIA%20IV%20Combi%20(5E5%2C%205E6)%202.0%20TDI%20RS;targetType:cars;targetId:59679;typeNumber:59679/lnkparts:Coil%20Springs;targetType:cars;assemblyGroupId:100113;targetId:59679;typeNumber:59679;groups:188;brands:1;page:0/detail:87787;brandId:1;articleNo:87787;targetType:cars;targetId:59679;typeNumber:59679;groups:188 Wire Diameter 11,25 mm Length 335 mm Outer diameter 106 mm Weight 1,70 kg Comparing the specification of the standard hatchback and VRS hatchback rear springs shows that the VRS rear springs are 22mm shorter when uncompressed. However, because the VRS hatchback rear springs have a wire diameter 0.5mm thicker than the standard hatchback rear springs they won't compress as much. I would estimate that for every 0.25mm increase in wire diameter, the springs compress about 4mm less under the car's unladen body weight. Hence rather than 22mm shorter, the VRS hatchback rear springs will reduce the unladen ride height by about 15mm compared to the standard hatchback rear springs. The VRS estate rear springs will only reduce the standard estate's unladen ride height by about 6mm. If you don't carry much weight in the rear of your estate and don't tow a caravan, maybe consider using VRS hatchback rear springs on your estate for that low sports stance.
  16. There are 6 common sizes of car battery. L1, L2, L3, L4, L5, L6 All 6 batteries are 175mm wide and 190mm high. The difference in size of the 6 batteries is the length. Approximately in inches, the batteries from the smallest L1 size to the biggest L6 size is 8", 9.5", 11", 12.5", 14", 15.5". So as you can see, the batteries go up in approximately 1.5" increments. The battery that you have is the smallest L1 size. You can see the 6 battery sizes here in AGM format. https://www.yuasa.co.uk/batteries/automotive/ybx9000-agm-batteries.html The 1.0TSI engine is small and doesn't need a big battery. What it needs is a high quality battery. If you live in a cold country such as Scandinavia you might need a bigger battery. Skoda have fitted your car with a low quality and cheap EFB battery. You need an AGM battery. Notice on the yuasa link, that the L1 AGM battery has a CCA (Cold Cranking Amps) rating of 520A. Your 320A rating is a joke. No wonder you are having problems. Yuasa and Varta are both top quality makes. However, they do a range of batteries, so make sure you get a top model such as the 9000 series (in the Yuasa range). Looking at the prices on ebay, you might as well go for the L4 size if it will fit as it doesn't cost much more than the smaller batteries. However, the bigger you go, the heavier the battery gets. So maybe go for the L2 size, if it will fit. L1 AGM 15.9kg Yuasa YBX9012 50Ah 520A https://www.ebay.co.uk/itm/YBX9012-Yuasa-AGM-Start-Stop-Car-Battery-12V-50Ah/363106105341?epid=249064084&hash=item548acf77fd:g:ZwYAAOSw79BgE94W L2 AGM 16.7kg Yuasa YBX9027 60Ah 640A https://www.ebay.co.uk/itm/YBX9027-Yuasa-AGM-Start-Stop-Car-Battery-12V-60Ah/273838188365?hash=item3fc207274d%3Ag%3AhOUAAOSwqHNgE94U&LH_ItemCondition=3 L3 AGM 19.5kg Yuasa YBX9096 70Ah 760A https://www.ebay.co.uk/itm/YBX9096-Yuasa-AGM-Start-Stop-Car-Battery-12V-70Ah/362642920548?epid=249421320&hash=item546f33d464%3Ag%3AP6cAAOSwBQlgE94i&LH_ItemCondition=3 L4 AGM 21.9kg Yuasa YBX9115 80Ah 800A https://www.ebay.co.uk/itm/YBX9115-Yuasa-AGM-Start-Stop-Car-Battery-12V-80Ah/273836223962?epid=248649844&hash=item3fc1e92dda%3Ag%3Aid4AAOSwKlNgE94U&LH_ItemCondition=3
  17. Bilstein 36-314966 matches rear spring with OEM part number 6Q0511115BB https://www.autodoc.co.uk/bilstein/15803380 1 6Q0511115BB coil spring for vehicles with lowered running gear 1 paint mark 1 paint mark 1 paint mark orange white blue Model data: PR-0YA
  18. Both Kilen 63527 and KYB RA5136 rear springs are correct for the Greenline, and both are available for about £25 each on ebay. There's no point fitting the wrong rear springs when the correct rear springs are available.
  19. It's not a good idea to match front sports springs with standard rear springs...in the same way that you wouldn't put wide low profile tyres on the front matched to skinny tyres on the back...it's a recipe for disaster.
  20. These are springs for the 2008 Fabia MK2 1.4TDI Greenline Estate. Front Springs sold to replace OEM part number 6Q0411105M Kilen 23119 KYB RA1140 (1) 6Q0411105M coil spring for vehicles with sports suspension 3 paint marks 1 paint mark red green Model data: PR-L13 Rear Springs sold to replace OEM part numbers 6Q0511115AF, 6Q0511115BB, 6Q0511115BR Kilen 63527 KYB RA5136 1 6Q0511115BB coil spring for vehicles with lowered running gear 1 paint mark 1 paint mark 1 paint mark orange white blue Model data: PR-0YA 1 6Q0511115AF coil spring for vehicles with lowered running gear 1 paint mark 2 paint marks 1 paint mark orange blue white Model data: PR-0YB (1) 6Q0511115AF coil spring for sports suspension 1 paint mark 1 paint mark 3 paint marks orange blue white Model data: PR-1JD/0YB
  21. It sounds like the OP has a small engined softly sprung version with 225 tyres. This will be a recipe for disaster, as the tyres have loads of lateral grip which will cause too much body roll through the corners. The answer is simply. Change the 225s to standard 205s, which is what the entry level suspension will have been designed for. Even 20" wheels won't turn a Skoda into a Ferrari
  22. It sounds like you have a slow air leak. Often this is caused by corrosion around the rim where the tyre bead sits. It can also be caused by a puncture. Check the tyres' air pressures in one or two weeks to determine the tyres which are leaking air. Then find out where the air is escaping. You may have to remove the wheel and submerge it in a bath (or other suitable container) full of water to find the air leaks. You can use a yellow crayon to mark where the leak is.
  23. I doubt it rolls as much as a Renault 12. https://en.wikipedia.org/wiki/Renault_12
  24. 195/55R15 has an outside diameter of 595.5mm 195/60R15 has an outside diameter of 615mm 195/65R15 has an outside diameter of 634.5mm Changing 195/55R15 to 195/65R15 increases the outside diameter of the tyre by 6.5% which is too much. Changing 195/55R15 to 195/60R15 increases the outside diameter of the tyre by 3.25% which is acceptable with the 1.9TDI engine (ie. the high low end torque of the turbo diesel engine allows it to pull the 3.25% higher gearing adequately). Like 195/65R15, 195/60R15 is also a cheaper size than 195/55R15. You should notice increased ride comfort from the higher sidewalled 195/60R15, and you could lower your tyre pressures by 3psi compared to the 195/55R15 size due to the higher load index of the higher sidewalled tyre. Vredestein Quatrac 195/60R15 88H https://www.camskill.co.uk/m138b0s7993p202144/Vredestein_Tyres_All_Season_Car_Vredestein_Quatrac_6_-_195_60_R15_88H_TL_Fuel_Eff_%3A_C_Wet_Grip%3A_B_NoiseClass%3A_2_Noise%3A_70dB I expect Goodyear will bring out their EfficientGrip Performance 2 in the 195/60R15 size later this year. However, I don't think you would be disappointed with the latest Vredestein Quatrac all-season tyre, as that has been made to provide good summer handling as well as good winter grip. Also consider 185/65R15. However, the 6Jx15 ET43 rims that you probably have (ie. standard fitment for the 195/55R15 tyre size on the Roomster) aren't optimised for this tyre size. 5.5J to 6J rims with an offset between ET38 and ET40 would be better. The latest VW Polo for example, fits its 185/65R15 tyre to a 5.5Jx15 ET40 rim. Alcar 4055 5.5Jx15 ET40 Steel Rim https://www.oponeo.pl/felga-stalowa/alcar-kfz-4055#20346887
