DieselMonte
Everything posted by DieselMonte
  1. Axles now painted, stonechip first then 2 coats of glorious hammered black. Nitromors stuff cause the shop didn't have hammerite, and I wasn't bothered going anywhere else. Looking real sharp. Bit left over for touch up once it's in too. Also sealed up the firewall from the time I tried chopping it out for the vrs one. Feels like I'm getting to the point where Everything's lining up, and I'll just be able to bang everything in like that.
  2. More fooling around with this axle. Wire brushed it and soaked it in rust remover gel, which didn't really work. In fairness its rougher than the axle i put in the monte. Used the dregs of a tin of silver hammerite to see what that'd look like. Looks ok, but I think hammered black will look better and won't be so obvious when rust starts popping through. Tried to use a tool from work to swap the bushes but didn't get a chance. So did it myself. Pain. Used a makeshift puller tool consisting of some nuts, a threaded bar, a pipe and a wheel bearing to try pull the bushes but it only removed the centre part. So did what I done last time and drilled the nylon part of the bush out to try get it to collapse. Took ages, made a mess. But eventually got there. New bushes I have are Lemforder ones with a 6R0 part number which matches the number on etka for the vrs. If I destroy these I'll get poly bushes again but I'd much rather these. Seemingly the standard bushes allow for a bit of (passive) rear steer. Although the part number matches on etka, these bushes don't have the black end caps the bushes in the vrs axle had. Etka had 2 bushes for it, the other being 1k0, which was greyed out indicating its not for the vrs. Stripped down and hanging up. Will order heatshields and replace them on the car so they aren't damaged. These ones aren't great.
  3. Very tasty car and really could not be in better hands Jealous I didn't win it but I've enough around me at the minute.
  4. Did some checks on this today. Pulled the top of the carb off to check the jets and bowl for rust. All good. Lowered the float slightly as I was told it might help with hot starts somehow. Pulled the plugs and 1 2 And 3 Seem to be burning pretty good. Cleaned the contacts on the cap and rotor and lubed the cam for the Points. Running well. Gonna recheck timing, idle mix and idle itself next time I'm arsed. Still need to change the brake fluid, change the coolant. Replace a coolant temp sensor (gauge reads low). Intending on making retrorides in it. So far it's proven to be reliable enough, considering it's been out of action since 2010. Found a few things out about it recently too, namely some records of it. Came into work in 2002 for an nct prep. Some time after that it came in on a no start, which was just a bad battery. Last record of it was in 2008 where the mid section of the exhaust was replaced. It still looks brand new and when I got the car I figured it had been changed when it was off the road. Not 14 years ago.
  5. Disc rear axle been removed ready to be cleaned up. After this, more or less its all reassembly into the sdi. More time to work on this (and funds slowly rising) now since the justy is roadworthy, and "finished" as it were. Few other bits stripped and swapped but the axles the main thing.
  6. Was running e5 until I ran that through, e10 since April as that's the only petrol available locally. As I say I'll take it further afield and fill it with premium and see what happens.
  7. Few pics of this turned up. Also found the government's e10 checklist says any subaru after Jan 31st 1991 is good for it. Then found another which states the same, except all vivios and justys before April 1994. Nice. Closest station to me is a fair drive but looks like I've no other options as all fuel stations near me use e10.
  8. Still not been up your way to meet you. Did you do skodafest? Must do it next year if it's on. More photos from the weekend Good meet (impreza is a complete stranger, very cool car though) Noticed a guy next to a red celica taking photos as we went down, must try hunt down them photos. Halfways hiding regs, don't care about mine but don't know if anyone else does so. Fitted the spare lamp. Cars beaten and smokes even more when it's cold now. Definitely deserves a some downtime for repairs. If it gets it though, I doubt it.
  9. Pics of the damage. Intercoolers bust through the splitter, not sitting right on the bar either but it's not bust. Happily the new genuine undertray seems to have held up, impressed. See the exhaust has flattened at the bottom, again, cosmetic and not a big deal. Pretty impressed it stuck so much abuse especially with my apparent skill issue. Made it back to the ferry safe And home from there Just over 1000 miles on the trip meter. Definitely wants a good going over now. And it turns out I have a spare foglight to throw in for now too. Gonna respray the lip soon, it needed doing anyway so not a big deal. 145k on it now and somehow still going. I'll upload any more pics I get of mine here If the ferry was any cheaper I'd be over every weekend.
  10. So, Invading England: Around the penines again. Roads rough as ever. Intercooler and sprayer helped massively with heat soak. It ran a LOT better this year. The K brace and the caster increase bushes helped a lot, as did the new brakes, they were needed. Did an awful lot of brisk driving, got caught in standstill traffic in Penrith and the car starting ticking really bad. Figure it was running very hot. Thankfully as soon as I got out of gridlock the ticking went away and hasn't come back. Some beautiful views. Did hartside pass quite a few times, busy spot. Saw an RS3 on its roof near the end just before Alston. Thing behaved very well for what it is. On the last big drive last night I sent it a bit hard and did some damage. Hit a very rough cattle grid at a brisk pace and made ****e of the backbox, bottomed out hard. Thankfully it just slipped off the hangar but it was only when it was sparking off the road that I noticed. Oops. Then pulled into a lay by with a big ass hole and destroyed the splitter and broke the tab on the drivers foglamp. Minor damage and not a big deal to me since the fogs were rough and the splitter was needing paint anyway.
  11. Just back from my big trip. Just over 1000 miles done in 5 days. Gonna start with stuff that I did before going away. So I wanted to hook up a cb that was lying about for this trip. Wired up temporarily with a fuse tap and mounted into the cubby beside the headlight switch. Used a mag mount and strapped it to the roof. Then set about giving the car a full detail before setting off. So wheels off, checked all the brakes suspension etc. Washed and detarred the arches, painted the brakes again. Washed, decontaminated, polished and sealed the alloys. Photos are a bit out of order here but anyhow, original grille was flaking so sprayed a spare one and swapped it out. Came out fantastic for a rattle can job. Grilles out, cleaned the spots, polished the intercooler. Also took the fogs out as the tints were flakey, got some tint spray paint and tried it. Did not end well These fogs are pretty beat and cracked, recently got new ones for another monte for £35 a side, so will buy some new ones and tint them again, eventually. Very fine machine polish, then a few coats of glaze, then waxed. Lucky I have the justy on the road so can actually have this sitting for more than a few hours now. Can see the painted fogs now, looks alright from a few feet but not happy with it. As I say they needed changed anyway.
  12. Driving 100 percent otherwise. Doing 60-70 happily on the way home, handles absolutely amazing, especially considering I haven't touched the suspension at all. Extremely comfy and surprisingly quiet considering its an 800 odd kg economy car that's been made since the 80s. Insurance disc didn't arrive still so while it is insured the disc on the window says expires October 2010. Will post any photos I find of it online.
  13. Gonna be driving around "My hooptie" all summer Been driving it around since, running pretty good. Has a mean hot start problem though. Cranks and cranks and cranks until it eventually fires. Changed the Fuel filter before the carb. Still gunk coming out but the filters seem to be catching it all, looking through the window into the bowl the fuel there's clear, happily. Washed and waxed it last night for cars and coffee today, was behind a ferarri 440i there and on the way back too. Place was jammed when I arrived, so was put out in the bleachers, know to get there earlier next time Plenty of cool stuff there though Sort of out in the bleachers but still got a few looks and photos. Seemed to get a fair bit of attention. Even driving it had people come up to me asking what it was, or saying they hadn't seen one in years, which was nice. Tried moving it from its spot and it would not start, so left it. Started once i went to leave though. Mean hot start problem and this heat is not helping.
  14. So It's now taxed and insured. 190 a year insurance, 56 euro tax Been driving it about locally to make sure its running right. Drives out great comfy, pretty sharp handling, tyres good, brakes are fair. Small bit of stumbling at times but I think I've the idle mix set a touch lean, for nct. Fatten that up and see. Looks are deceiving, it's covered in an inch of dust cause the garage is full so it's been sat outside for over a week. 20230602_234559.mp4 Radios fantastic in it. I'm sure its gonna break constantly now its back in service, but for now I'm happy. Again, not cost me much to get it on the road and insurance and tax is very cheap, figure it's getting about 40mpg so it's not hard to run. Considering that the Monte is getting on a bit now it's nice to have a useable second car.
  15. Going away in a few weeks all going well, same as last year. Since I won't have the power I want, I want to do everything to minimise power loss. My biggest problem last year in the summer heat, was heat soak. I've since put a front mount on, but I figured I could do more in the form of an intercooler sprayer. I could buy a kit ofcourse, but that costs money and there's no way really to mount it stealthily. So then I thought about plumbing into the washer bottle, but I couldn't figure out a good way of splitting the feed on the fly to the intercooler. So, I had a look and noticed the mk1 has the bottle on the passengers side. Whereas the mk2 has it on the drivers side. After a bit of looking. I noticed the top bolt is in the same spot, and there's a hole near the power steering reservoir on the mk2 where the bottle also mounts to. Good enough. Hoped to just remove the splash panel and snake it up through there, which proved optimistic. Had to loosen the bumper off and pop the headlight out to get the best access. And with a bit of fettling, it fits. Looks standard, if a bit odd. It's a pretty tight fit, but the splash panel and fog do go back in properly. This is only a 2l bottle, I seriously doubt a 5l fits. Even used the nozzles from a mk1, fit pretty well, tied on top of the bumper spraying down. Wired it with a relay, fused of course. Then used one of those fuse taps inside on the fuse for the wipers (switched ignition), and put a push switch through that to turn it on and off. It's taped into place for now near the radio, until I can find a good spot for it. Works well for a parts bin bodge job. Think I'll add some isopropyl alcohol to it, which is meant to cool things even more. I'll need to add some sort of return valve to the washer hosing as it drips down if the bottles too full. But happy thus far. 20230523_214406.mp4
  16. Rear axle is out. Brake lines were horrid to remove.
  17. Service this evening New air filter New oil and filters No glitter in the oil or filter. Oil was very watery though. New fuel filter too Primed the system with vcds, lot easier than bleeding it the normal way, doubt that'd work on this anyway. What came out of the fuel filter. Might cut the old one open just to see how bad it was. Probably gonna service it more frequently now on since it's racking up the miles. Also got the darkside feed line aswell as all gaskets (genuine) to put the turbo on. Everything got now to fit the turbo, waiting for someone to get back to me if they can map it. New undertray got too. Was bought for another car but that ended up using one of my damaged trays, so now I've a new genuine tray to go on whenever. Also making another gearbox mount as the one on it is going.
  18. Progress since Interior loom In Abs pump swapped over and front lines ready to run
  19. Be taking it to retrorides in a few months Debating taking it to the penines next month. Hoping to take the Monte to that if its not broken by then.
  20. In for nct this afternoon Towed up because I didn't want to chance getting stopped. And... Clean sheet pass. So now tested until September next year. Should be 2 years but due to the unique way nct works, it goes from the month it ran out to that month the next year. Because it's over 30 years old it gets a "2 year test". If it were any younger it'd be tested until September of this year, and have to go back in again. Makes complete sense right?
  21. 280mm fsiii is seen on mk5 and mk6 golf platform. Never used on fabias.
  22. New wheel bearing on. Took me 40 minutes. Didn't need a gear puller it just came off. Only thing I had to buy was a 30mm 12 sided socket for a whopping €6.50. Fronts are a different beast and I wouldn't want to tackle one of them without the proper too. Thankfully it's not needing one yet.
  23. Finally messaged powerflex to try warranty the dogbone bush. Extremely impressed with how quick they were to respond and send another out. Its a revised part so hopefully won't break again. In now and feels great. New pads on the front. Bit of life left in them but since I had the Mtec pads I threw them on. Feel great and so far no noise. Discs were lost in transit so I've got my money back from them. Ended up swapping the rear pads from the Mtecs to some Ferodo pads as they got very squealy. Guessing I got some dud rear pads. Alls fine now so far. New discs already rusted as it's been teaming rain.
  24. Not much here but after some more fine tuning it's running much better, well enough to have it on (definitely private) roads. Filled it up and as you can see the fuel gauge is reading right. It's driving fine but a bit slow and it's not giving me the big bump in power when the second barrel kicks in. Gonna Check timing again and maybe advance it a hair and see how it goes. It is absolutely filthy now so I'll give it a good scrub soon. Nct on the 13th all going well. I'd like to drive it there to make sure its "hot" and give it a better chance for passing emissions. I'll see closer to the date. Nice to see it running well again. Set idle a bit higher just to let it idle smoother. Starts in half a turn 9 times out if 10 too. 20230417_212233.mp4 Still don't think it'd pass nct first try. Just have this feeling it will fail on something extremely stupid. But all the light work, brakes are good, trackings good etc etc.
