Everything posted by UndertheRadar
Reversed in to a lamppost.
I’d paint the entire bumper. But it depends on what you expect from it. I can’t deal with ghosting or colour issues, so I always do the entire panel.
The 280PS Thread
Think there was a heat shield or a fuel pipe that used to be an issue for rattling on the bulkhead.
Rear discs replacment
This made me look closer at my own rears. At a year and a half old with just turned 15k they are heavily worn and the discs are showing signs of scoring. Guess what’s getting a set of BSD’s and yellowstuff pads this summer? 😂
Ford Fiesta - asthmatic interior fan
As above. Check the drain channel as they get blocked some times and allow the pollen filter to get wet. This then damn near stops air flow entirely depending on how wet it’s become.
The 280PS Thread
Revo do a stage 2 now for the 272. With the inter cooler and intake replaced it’s something like a claimed 400bhp dependant on fuel. I’ll wait until my warranty’s expired first though. Something like an R600 intake with intake pipe and elbow would be more cost effective than the revo carbon version.
Enable Traffic sign recognition
It’s not showing in the one touch adjustments. There’s nothing in the worshop section yet either. Few items in adjustments. Scandinavian drl’s and door locks, mirror dip and several others, but no traffic. Whether that’s a sign they can’t do it, or they just haven’t added it yet I don’t know. May be adjustable in coding. Can you download the app free and then check what’s there without an account? Or even ask them directly or on the discussion board maybe.
EA113 2.0 TSI issues - experts help needed please
Coolant at temp within about 300yds from cold. Start car, 2min spool up. Drive off. It’s about 300yds to the end of the village and then into a N/S/L zone. Oil up to temp within a mile. It’s the DSG that plays catch up. It seems to take between 2-3miles going by live data readings.
My unit is at full running temp within less than a mile. Get a second opinion. a dealer will detect a map and so will another tuner. nothing wrong with a map as long as it’s well done. I don’t hide the fact I prefer revo for these units.
Water/ice in compartments under boot floor
I removed and sealed my N/S/R taillight last night for a slight weep during very heavy rain. 10min job to remove and replace with silicone to aid the seal. Worth a try first as it’s simple and quick to do, and a well know issue.
Painted the callipers on my last motor bright yellow. Actually turned out quite well compared to the red or silver I would normally use.
EBC. Never use anything else on my own vehicles.
The PCM is the module that controls engine firing etc. Sometimes it can cause a fault but not show as such. have the thermostat or the temp sensor checked. The stat if stuck open will allow the car to run all the time on a rich mixture as it does when first started to warm up. If it doesn’t warm up it can stay on this mixture. It won’t show as a fault as the car is doing as it should when running a cold engine. some of the stats Come in a housing with a new sensor. Not sure on yours from memory, but the stat is my best guess given the symptoms.
Suddenly need a new car on a tight budget... recommendations please!
Ring some of the dealers and ask as a trade enquiry on what they’ve had traded in. You’ll have to take it as is, but it’ll be quite a bit less. Most will sell trade first and then auction.
Is it mapped? are you getting a signal from the power train control module? thermostat issue could cause the engine to run on a constant rich mix, or faulty temp sensor could cause similar fault. I’d check the stat first incase it’s stuck open. the extra fuel will get pushed past the rings into the sump, hence the smell. It’ll also cause wash, so get the issue fixed before it does expensive damage.
Battery removal for charging NOT changing
I’ve mine in the driveway at the minute with a Ctek on it as well. Battery still in place.
Electric tailgate problem
Any chance it’s cold where you are the latch was frozen confusing the system to thinking it was already closed when it was actually open?
The 280PS Thread
Consider the driving you’ve been doing as well. Just because your engine is up to temp after a short distance, doesn’t mean your box is as well.
Changing chrome trim around side windows to black sportline (dechroming)
I would just wrap the chrome on the grill surround and slats along with the front bumper strip and see how that looked before changing the grill. Only reason I haven’t done mine before now, is, I’m not sure I want black wrapped roof rails. Don’t think chrome rails and everything else black would look right either.
Heated washer nozzles
I’d say they are probably working, but the engine bay is poorly insulated and the feed pipes from the pump freeze quite easily. I’ve had to adjust quite severely my washer concentration after being used to my last motor, which had a heated bottle, nozzles and insulated pipes. check your fluid as some don’t go that low even when neat.
The 280PS Thread
Contact Skoda directly and ask them if a failed turbo with such low mileage on a dealer serviced car is considered to be fair wear and tear at 4yrs old, in their eyes. There’s a chance the claim has been turned down due to your dealerships unwillingness to contribute.
Screwfix Screenwash
I haven’t seen it for a while. I ran out of it at the end of last winter and this year is the first I’ve had frozen washers in a long time, and I was running 60% concentration of the replacement wash I’d bought. Was about the same temp as you had or maybe a degree or so colder. That Lidl stuff was fantastic.
Driver's door lock issue in freezing temperatures
Just be careful with the heat gun. They put out more heat than you think and if your to close will damage paint or plastic handle. my wife’s last two Fords have been prone to the same issue. I always leave a drinking bottle in the boot during the winter as cold water over the handle and latch area always releases it. It will freeze sharply again, so get in and close the door soon after releasing it. The cars heaters when driving will make quick work of thawing it out once your driving.
No RS Theme on Virtual Cockpit
I changed mine to see if the red needles helped, but I still find it not the best dash to be able to read with just a quick glance. A small individual point at each speed point would be a simple addition and a great help.
I’d say it’s top and bottom for each door and then quarter light trim as well. Estate needs the roof rail covered as well. Then front bumper trim and grill. Wrapping gloss black is a much simpler solution and if done properly should last quite a while.
The 280PS Thread
And now you have an entire car for the same price as 3 services in the Gallardo?
