Everything posted by Danoid
Map updates
Hopefully will be good, ignore some of the pictures are in the darkmode and not, i switched to a different PC. There's a lot of steps, but dont worry it's easy enough I just wanted to be more in depth for you Skoda Columbus Map Update.pdf
Map updates
I’ll be writing the guide shortly, I’ll attach it as a pdf hopefully
Map updates
OP has Columbus going by the picture Did you have a look to see if you had a microsd to sd card converter?
Map updates
Hello, just to confirm that you have an adaptor to put your microsd card into one of these (top of picture) I’m guessing your 512GB micro SD is like the bottom one, but you’ll need to insert that into the top picture
Map updates
Ah so the Skoda card is no good. 512GB will be too big to format (completely wipe) to change it to FAT32 like Skoda asks for however the drive I use is formatted to NTFS which always works so we can certainly try it. If the above makes no sense don’t worry. Please makes sure whatever is on your 512GB card is copied somewhere as tomorrow you’ll be completely wiping it and lose anything on it. In the meantime go to your car tomorrow and look at the windscreen bottom right you’ll see your vin number, write this down or take a photo of it (don’t post it here, no need) but you’ll need this tomorrow Depending on my workload tomorrow at work I will write the guide at some point
Map updates
Where you saw it has 14.8GB free, it should say something like 14.8GB free of XXGB It’ll say total size when you right click and select properties, you can take a picture from your phone and upload it here. Tomorrow I’ll make the guide for you Here’s an example
Map updates
Oh great stuff, plug the Skoda SD card into the adaptor then plug into your laptop Go to Computer and you’ll see the SD card there, can you see what size it is? Should say below the card in Computer, if not right click the card and click on properties then let me know the size, hopefully it’s around 32GB
Map updates
Thanks, so your laptop does not have an SD card slot. If you don’t have something like this already you’ll need to buy one https://www.amazon.co.uk/Jiasoval-2-0-Card-Reader-SD-Black/dp/B07S2Z8Y31/ref=asc_df_B07S2Z8Y31?mcid=369ff21bec0a3eed9403595e9cbbc59c&tag=googshopuk-21&linkCode=df0&hvadid=696386561224&hvpos=&hvnetw=g&hvrand=1524839333522385496&hvpone=&hvptwo=&hvqmt=&hvdev=m&hvdvcmdl=&hvlocint=&hvlocphy=9199185&hvtargid=pla-813533712854&psc=1&gad_source=1#aw-udpv3-customer-reviews_feature_div As I’m not sure what size the Skoda card you pictured is, it’s best to buy this https://www.amazon.co.uk/Ultra-HD-Video-Premium-Memory-Integral/dp/B07FB7NQF7/ref=mp_s_a_1_1_sspa?crid=2HOSZF27PJZB2&dib=eyJ2IjoiMSJ9.6AbWHkR_OS00jFOLQugllw7EqzhT7qFlwffybTydWmNQttQUuTZbyZDoiCgCPJekq0l49OTYJLd9ceaPhwT_67rFBk3bf2eIoecR5rSM1kXCXN2aImfGC4v_7icF3upuc0kVsEvC1gtD93t4F4Pevef8mGJrGxaGsSUcV4V1nanmiHXT7YyP8hoLnn53Etzp0JepJzVQAYVzEKgMxLpnaA.OTSMKKAaHIX516eVxkk1VGR9jCyuAQGdwvfdVHiDQFs&dib_tag=se&keywords=64gb+sd+card&qid=1741541788&sprefix=64gb+sd+card%2Caps%2C119&sr=8-1-spons&sp_csd=d2lkZ2V0TmFtZT1zcF9waG9uZV9zZWFyY2hfYXRm&psc=1 Then on your laptop you’ll plug the top item into number 2,5 or 7 Once you’ve got that lot delivered, let me know and I’ll write the guide up
Map updates
Can you find the model number? Usually under the bottom If it has an SD card slot then I won’t need to go that in detail Does your current SD card look like the top one
Map updates
I can write a detailed step by step if you like? My profession is IT so I always write guides for things for various abilities. Whats the make and model of your pc/laptop and is it Windows?
- Brake Pads
data transfer notification
Have a look in the manual, it’s by design and you won’t be able to ignore “Personal data Personal customer data is collected, processed and used by Škoda Auto in accordance with the generally binding legal provisions. The current privacy statement on protecting personal data can be found on this website: https://www.skoda-auto.com/other/personal-data As a party to the use of Škoda Connect services, you must ensure the protection of personal data and privacy rights. Inform vehicle users and passengers that the vehicle transmits user data and uses location services. Failure to inform may violate the rights of vehicle users and passengers. Localisation services include, for example, information about the last parking position, notifications about leaving an area or speeding notifications. If the passenger does not agree to the use of location services, turn off the services by setting the appropriate privacy level.”
MIB2.5 Upgrade Issues
I bet that was quite a sickening experience but glad it’s all worked, far braver than I am
Brake Pads
I’m happy with ATE ceramics, just make sure you fit them the correct way (goes for most pads these days, they’ll be a small arrow or crescent moon shape) But I’ve not actually put the ceramics on my car, only my wifes Fiat 500, but a friend of mine has them on his beemer, drives like a loon and still clean wheels and excellent braking. It’s what I’ll be fitting on mine when needed
That sounds more like a security notification, who exactly are you sharing your location with? 100% I’d turn it off
DSG service.
I thought DSG gearbox oil + filter is every 40k miles where applicable and not every 80k?
Alcantara sports seats, are the sides leather?
Best way to tell really is to poke it, if you see like creases then it’s leather. Looking at your pictures, the thin strip around the seats will be leather, headrest, strip under the headrest and the armrest. When I clean my seats I use Gliptone, smells like you’ve fisted a cow afterwards though (leather smell not poop). I use it on all of my seats which is more real leather than not (backs and side fake stuff) https://gliptoneeurope.com/product/leather-conditioner/ https://gliptoneeurope.com/product/intensive-cleaner/
4x4 tdi performance 😕
If you got vcds obd11, you can always change the throttle setting to Audi mode Worth a shot and free to try if you already got the kit
19" Sirius alloys, are they diamond cut?
£420 for all 4 seems good enough to me tbh I’m not sure how they they refurb them, I guess strip it all, powder coat it all then finish the fronts off with a diamond cut the rim and front. I wonder if you can ask nicely and get them to ceramic coat them before you pick them up as I believe that takes like 24-48 hours to cure then should be good for many years After that powder coat all the way
They are diamond cut, looks nice but can get the worm effect too annoyingly. Others here have just had them powder coated but I personally love the diamond cut look as it looks a more better quality finish, but you get the worm problems and limited amount they can be recut
Superb 3 2020 rear brake
Something like this should do but probably other videos about showing Skoda but should be the same https://youtu.be/4OO971IRn9g?feature=shared
Still looks bad but not as worse, but judging by the rust on the disc hub I guess the drivers side sees more rain when parked? If I were you I’d change them, if you don’t have vcds etc then you’ll need to buy it or get a garage to do them as the caliper piston has to be electrically retracted. I put brembo discs on my car and OEM pads because that’s the least my local Skoda dealer would do When I do my fronts myself I’ll go brembo discs and ate ceramics The brembo discs are just the basic ones but have a painted coating on the hub part so don’t rust
Does the Skoda Superb MkIII estate have a timing belt cover?
The top part has a cover but not the bottom part, which is easily seen when the wheel arch liner is removed, VW probably thought the liner is a good enough cover
Car passed MOT, grand total of 2819miles between MOT’s Last year I had bang on 2k miles between MOTs 😂
It’s very common; however your passenger side should look similar, if it doesn’t then that’s not common at all and could be a number of things. The brake dust shield going crappy is common too but a much bigger job than it needs to be in replacing the rears, it’s on my to do list of using something like kororust and some hammerite black paint to go round the edges (done the same on my wife’s fiat 500 rear drums and held up nicely the last 4 years. Upload a picture of your passenger side too to compared
