Danoid
Everything posted by Danoid
  1. Have a look in the manual, it’s by design and you won’t be able to ignore “Personal data Personal customer data is collected, processed and used by Škoda Auto in accordance with the generally binding legal provisions. The current privacy statement on protecting personal data can be found on this website: https://www.skoda-auto.com/other/personal-data As a party to the use of Škoda Connect services, you must ensure the protection of personal data and privacy rights. Inform vehicle users and passengers that the vehicle transmits user data and uses location services. Failure to inform may violate the rights of vehicle users and passengers. Localisation services include, for example, information about the last parking position, notifications about leaving an area or speeding notifications. If the passenger does not agree to the use of location services, turn off the services by setting the appropriate privacy level.”
  2. I bet that was quite a sickening experience but glad it’s all worked, far braver than I am
  3. I’m happy with ATE ceramics, just make sure you fit them the correct way (goes for most pads these days, they’ll be a small arrow or crescent moon shape) But I’ve not actually put the ceramics on my car, only my wifes Fiat 500, but a friend of mine has them on his beemer, drives like a loon and still clean wheels and excellent braking. It’s what I’ll be fitting on mine when needed
  4. That sounds more like a security notification, who exactly are you sharing your location with? 100% I’d turn it off
  5. I thought DSG gearbox oil + filter is every 40k miles where applicable and not every 80k?
  6. Best way to tell really is to poke it, if you see like creases then it’s leather. Looking at your pictures, the thin strip around the seats will be leather, headrest, strip under the headrest and the armrest. When I clean my seats I use Gliptone, smells like you’ve fisted a cow afterwards though (leather smell not poop). I use it on all of my seats which is more real leather than not (backs and side fake stuff) https://gliptoneeurope.com/product/leather-conditioner/ https://gliptoneeurope.com/product/intensive-cleaner/
  7. If you got vcds obd11, you can always change the throttle setting to Audi mode Worth a shot and free to try if you already got the kit
  8. £420 for all 4 seems good enough to me tbh I’m not sure how they they refurb them, I guess strip it all, powder coat it all then finish the fronts off with a diamond cut the rim and front. I wonder if you can ask nicely and get them to ceramic coat them before you pick them up as I believe that takes like 24-48 hours to cure then should be good for many years After that powder coat all the way
  9. They are diamond cut, looks nice but can get the worm effect too annoyingly. Others here have just had them powder coated but I personally love the diamond cut look as it looks a more better quality finish, but you get the worm problems and limited amount they can be recut
  10. Something like this should do but probably other videos about showing Skoda but should be the same https://youtu.be/4OO971IRn9g?feature=shared
  11. Still looks bad but not as worse, but judging by the rust on the disc hub I guess the drivers side sees more rain when parked? If I were you I’d change them, if you don’t have vcds etc then you’ll need to buy it or get a garage to do them as the caliper piston has to be electrically retracted. I put brembo discs on my car and OEM pads because that’s the least my local Skoda dealer would do When I do my fronts myself I’ll go brembo discs and ate ceramics The brembo discs are just the basic ones but have a painted coating on the hub part so don’t rust
  12. The top part has a cover but not the bottom part, which is easily seen when the wheel arch liner is removed, VW probably thought the liner is a good enough cover
  13. Car passed MOT, grand total of 2819miles between MOT’s Last year I had bang on 2k miles between MOTs 😂
  14. It’s very common; however your passenger side should look similar, if it doesn’t then that’s not common at all and could be a number of things. The brake dust shield going crappy is common too but a much bigger job than it needs to be in replacing the rears, it’s on my to do list of using something like kororust and some hammerite black paint to go round the edges (done the same on my wife’s fiat 500 rear drums and held up nicely the last 4 years. Upload a picture of your passenger side too to compared
  15. @travs My MOT is Friday too as everyone’s happy on a Friday, another extra on making it pass Tbh nothing wrong with my car and only driven it about 3k miles since last MOT 🤪
  16. Cleaned it for the MOT as obviously a clean car automatically means pass
  17. Do you have auto on? If so you get different temps from the vents or not on at all. Bit like mine if I have it on auto I get warmer side vents compared to the ones above centre screen, taking it out of auto and pressing the forward only vents “fixes” it, but auto gets the whole car to your desired temperature quicker
  18. Do you mean euro6d? I didn’t think euro 7 exists yet?
  19. They are activated by pressure I believe, so maybe the valve has failed
  20. Is it not mirrorlink you use? So your phone screen (almost) is on the car screen? I’ve not used it in a while but I believe your phone needs the Skoda app, so might be worth removing that and reinstalling https://www.sinclairgroup.co.uk/news/how-to-activate-skoda-smartlink/ scroll down and it says how to connect using mirrorlink
  21. Someone fixed this recently, can’t remember who but just needed silicone spray somewhere in the vents to relube it
  22. It’s just doing its thing because of colder temperatures, basically they made it too efficient. Nothing to worry about
  23. I bought 10vin vcds as well, so I kept putting it off as it’s hardly cheap but then I have a habit of not spending money
  24. Changed my battery today, got the expected errors on dash so full lock left, full lock right then centered, all errors went but I did have “error stop start” so went for a mini drive, turned the car off then it disappeared. Everything else works and didn’t lose anything maybe trip counter but I rarely ever look at that. Car starting is so smooth now, I thought my engine mounts were going because it felt quite violent Basically wish I’d done it sooner
  25. I don’t have Canton, just normal which is fine for me, but if you’re playing via Bluetooth have a look at the Bluetooth audio is set to “loud” or “high” When I first got my car it sounded crap then changed that setting and all good, as yours is 2015 I’d imagine that’s been changed by now though
