Danoid
Everything posted by Danoid
  1. Hang on, so if you’re at home and on your phone then map apps on your phone cannot pinpoint your location? Or is it phone apps cannot pinpoint location once connected to the car?
  2. I may be wrong but I think with mib3, you insert the card and leave it to do its thing, no need to click “map update” manually like mib2’s. If you do a long drive (30-40mins plus) check back later and should see the map version change
  3. Next time I get 12v low - charge to drive, I’ll bite the bullet
  4. No keyless for me, and no easy open option either. So I guess people who have keyless can open and close with fob Peasants like me without can’t 😁
  5. I was right next to it hmm, is yours non l&k?
  6. Oh maybe and L&K thing hmm Mine opens but doesn’t close, saw others on here had the same so assumed all were like it
  7. My battery is still on its original one too, registered 2016. I always turn stop start off manually as part of my routine, but sometimes starting it is a bit sluggish, doesn’t help I only drive it once a week if that 😞 But yeah cold and heat kills batteries, so I’m suspecting this winter will be its last, I just hate spending money 😂
  8. Is the opening/closing with fob a Aussie thing? Doesn’t work for UK models at least 2016 ones anyhoo
  9. that one there, look at bap33’s post above he says it changes the way the parking brake released and much better
  10. I’ve been procrastinating buying VCDS, really need to buy a new battery but annoyingly it’s still going somewhat okay. i’ll be doing similar mods to you as well, but I’d also give the parking brake early release a go to
  11. I’ve got the Good asymmetric 6’s on mine, good grip in all weather its seen (rarely get ice/snow) where I am, much quieter than P7’s I will however be fitting Michelin cross climate 2’s on my wife’s 500 as heard good things
  12. I test drove one and didn’t like it, felt too big and bulky without the room of the Superb
  13. Do aircare cars have different sensors? Mine isn’t aircare so unsure what the actual difference is tbh
  14. ATE ceramics is what you need
  15. I’m pretty sure new engines will use a bit more and settle down, I believe people have said on here as well it’s almost leaving the factory low. IMO they should be topping to max during its inspection before leaving but don’t think they do
  16. Have you got access to a scanning took? If not there a link somewhere on here where you can see other vcds users
  17. Hmm unlikely to be then but could be flat battery, did you leave it a while undriven with things like dashcam on? If no to all I’m out of ideas, should be more knowledgable folk along soon, I just assumed the usual culprit
  18. Those errors can all be caused by a knackered battery, so is it still on original battery? If it is then time to change if your car has an AGM battery then Varta A7 (don’t quote me on that) is best
  19. This will explain it best https://www.skoda-auto.com/world/range-driving-modes Basically sport steering will feel heavier
  20. Anyone know what Skoda themselves lubcriate door hinges and check strap with? Obviously when they use to service it they didn’t, don’t want to use white lithium and just interested in what they use
  21. Hmm could be sticking but unlikely I would’ve thought. Keep an eye on the car when you start it for the next few weeks, does the car always do the needle sweep at start at? If it doesn’t then that may link in when it doesn’t work, as you said sometimes it does sometimes it doesn’t. I can’t help but might find a pattern at least
  22. I’d avoid the 276 and just stick to the 190, purely based on the miles you say you do. I roughly do 3k miles a year in my 190 diesel, smooth enough and quick enough for my needs. If I did more miles I’d probably want something more pokey, but if all traffic is moving nicely is there any need for more power? Nope
  23. Sounds reasonable to me, I just looked at Timmons as an example and that’s £231 for. So £300 guaranteed to work and genuine bits, much cheaper than losing your current one and being completely stuck
  24. 4 years old, 24k and needs new front suspension parts already, hmm I’d ask for them to be changed as a condition of buying it, they may have just been upselling though but something is odd
