Everything posted by Binx1310
Please about with coding a couple more bits after reading through the list of options last night. Today I’ve done: Changed autohold and hill hold to “early” and it’s transformed the car. No more jerks when coming off autohold at all. Blower level when on auto Refuel quantity on dash I also tried to code for wipers to park when ignition turned off. Code accepted but no change. So wipers seem stubborn to the settings. Also tried to add wiper service position to MMI menu but that hasn’t taken either.
I don’t have that option. I just have report or share. I wonder if it’s a paid feature.
Steel Pedal Covers for DSG
Amazing thanks. I really need to stop coming on this forum. It keeps making me spend money…
I meant courtesy indicator increased to 5. It’s quite annoying you can’t edit posts!
I’d love to do this but footrest isn’t available for RHD unless you pay for OEM
Upgraded my OBD module and had a play with some basic coding using CarScanner App. Successfully applied: Increased cut tower indicator flash to 5 Increased headlight washer interval to 20 Turned on eyelashes with DRL (but didn’t work as I have the A part number lights) So turned this off again to avoid errors According to the coding I also turned on teardrop wipe for front and rear but haven’t seen any behaviour change on the drive. Does anyone know if this works on MY2016 superb and what the criteria for it to occur is?
That’s a nice quick turnaround.
Cloudy mark on dash
Ordered the meguairs stuff as the reviews were pretty good. Should come tomorrow.
Something I’ve wondered with this. Do they loan you four spare wheels while they refurb them or do you leave the car with them during the work?
Adding USB ports in armrest?
Looks good. A nice neat solution. Really pleased with mine. Although I’m now thinking about adding a MagSafe wireless charger to the front slot. And wiring in using 12v to 5v usbc adaptor hard wired in. Can get all the bits for about £15. Just deciding if it’s worth it.
Ooooo stripes in the mats. Fancy.
Apple play / google maps radio issue
Theirs is a setting for not muting the navigation during a phone call but I’m not sure there is the other way round. Perhaps in the settings of Google maps when connected to CarPlay? I’m sure mine does mute and listening to podcasts it’s really annoying so I ended up muting the maps and have got used to it.
Reversing Camera Query
The build Codes should be on a sticker on the boot floor next to the spare wheel well. In a 2023 car it should be nicely readable. I’m sure if you post a photo on here people can help you interpret them. If not You can get full build codes from Erwin. It costs €8 for 1 hour of access and you can also download all the maintenance manuals if you were wanting to do work on it yourself. You have to claim to be a garage to get the login but there are no checks done. Make sure you have your vin ready. Also I’m pretty sure any Skoda dealer should be able to produce you a print out of the build codes and shouldn’t charge you for it.
DAB aerial replacement
I don’t think it’s the antenna as it’s no worse than before. When I undid the fakra on the back of the radio it pulled out a few mm and I could see the wire behind. I wonder if there’s something loose inside the radio
No better driving around either. I generally use CarPlay and FM is good enough. Just annoys me if there’s something that doesn’t work, even if I don’t use it.
This arrived today and installed without issue. Signal no better sitting on the drive. Nipping out later so will see if it improves when out and about.
Cloudy mark on dash
If the meguirs one works as it says that might just do it. Thanks I tried wd40 as I was cleaning off some superglue residue elsewhere and wondered if it was the same thing here.
Cloudy mark on dash
As I’m coming to the end of little tarting up jobs this one is now starting to annoy me. There’s a cloudy mark on the clear plastic covering the dials. Generally it’s just out of line of sight but I know it’s there and that’s enough to annoy me! I think is scratches in the surface and I guess someone had used something a bit abrasive on it at some point. I tried wiping over with wd40 and it disappears until the wd40 dries off, so it’s definitely on the surface. Any magic tricks to remove this type of thing or is it something I’ll have to put up with? Not worth changing the dash for.
Rain held off for a bit so managed to check the front too. Clearance is tight around the calliper but clearance is clearance. Drives fine. Very happy with that. Also filled up the screenwash for what feels like the 1000th time in the four months I’ve owned it!
VAG DSG gear knob swap
Looks good. I found with mine i got a bit of whitening of the gloss black around the gaiter from the superglue fumes. I think I was a bit impatient putting it all back together! WD40 on a cotton bud cleans it off though so all good now.
Test fit the spare on the rear today. Went on well and no issues. Went for a drive for a few miles and no tpms either. Was going to swap it to the front but it started to rain so that will have to wait for another day. At least I know for sure now if I do have an issue the spare can go on the rear.
Only when they’re muddy! That’s a good tip. Got some off aliexpress for £3!
Leaking boot skoda superb Mk3 estate
Looks pretty straight forward. Lights off, 12 screws and 4 catches. Just another pair of hands needed to remve bumper
It’s not going to make it any worse so long as you clean it up well and get a good seal. So might as well Give it a go. I haven’t looked at the manual but I don’t think removing the bumper will be a massive task.
Put in a boot liner. Nothing fancy, but will contain the mud when picking up the kids from football! Just a cheap one from Amazon. https://amzn.eu/d/0ekCj4qT
