Everything posted by SkOmk4
Best Winter Tyres
I don't know about you guys, but on my recently arrived Formentor they fitted Continental Eco Contact, which is a LRR (low rolling resistance). If you sneeze behind the wheel, those tyres will lose grip... if you try to take off a bit faster (NOT sporty) they lose grip; if you brake a little harder (non-emergency brake) God forbid it would be a bit wet - they will lose grip. At this point I'm betting anyone that a premium all-season tyre or a premium winter tyre will outperform the Eco-Contact in most cases. For sure under 15-20 deg Celsius on any kind of surface, dry or wet... So before you take a decision concerning the winter tyre I suggest you have a good look at those comparative tests - you'll get a pretty good idea, assuming the tests are objective.
Any tips on driving an automatic?
That's also the effect of "Auto Hold" usage, it doesn't necessarily mean the driver has his foot on the brake. Using this function will keep the brake lights on as long as it is engaged and there's actually no need to switch to Neutral or Park and apply the parking-brake. The clutch will be completely disengaged while on Auto Hold, so that's not affected either...
Option to disable headlight washer
I can't say I know for sure they're different or not, but it makes no sense cost-efficiency wise for VAG to produce different version of Matrix-LED between different trims. And when I see how profit-oriented car manufacturers are nowadays, I doubt they would try to diversify - more likely to standardize across as many cars/brands they can...
I totally agree. I've seen that on most Xenon headlights, in most EU countries the homologation of the vehicle required that they had washers. I think that (depending on each country's road authority) there's a certain threshold for light output (lumens) above which the washers are mandatory - I wouldn't disable that... But on the particular case of Octavia, since you get the same headlight (hence same light output) with and without washers depending on trim level, I would conclude that the car homologation didn't require mandatory washers.
I fail to understand why you're making such a big deal about this story... I just checked the UK Skoda webpage, configured an Octavia SE (a trim without headlight washers) and added as an option the Matri-LED headlights. There is no headlight washers automatically added on the car as a consequence of this - therefore I can't see where you find the legal obligation to have a headlight washer for the LED-headlights. In most EU countries (imagine I haven't checked all) the washers are not mandatory on LED headlights (basic or Matrix), but they are somehow trim-dependant or in some cases optional. I had a Style trim Octavia with Matrix-LED and there was no washer installed, but I could have added it as optional. I totally agree with the idea you mentioned in the first place: IF it's mandatory by country-regulation, one shouldn't disable the washers. But since they're not mandatory in UK or in Australia (where @FillNill is) I don't see the problem...
There's an App in OBDeleven alowing you to turn off the headlight washing. There's also another topic around here (coding-related) where someone was posting that it is possible to code some DELAY for the headlight washing system - so it will only start if you wash the windscreen for more than several seconds...
Infotainment System Restarting endlessly
Follow the Forum rules guys, that's really impolite to the other members... You can send each other private messages if you want a separate conversation.
Best Winter Tyres
Yep, I had the Blizzak on Octavia last winter; no problems and they were obviously quieter than the Factory (noisy) GoodYear.
Best Winter Tyres
The Auto Bild test you mention is dated October 18th, please have a look at the Tyre Review winter tyre test published October 2nd: https://www.tyrereviews.com/Article/2023-Tyre-Reviews-Winter-Tyre-Test.htm Could anyone explain how is it possible that the winner of the latter test is positioned 10th in the Auto Bild test? There's even the same tyre size, so factors such as width or radius don't come into play... (in case they ever would) WTH??? I'm fully against conspiracy theories, but in this case: who's paying who for those tests???
Best Winter Tyres
https://www.tyrereviews.com/Article/2023-Tyre-Reviews-Winter-Tyre-Test.htm Check the podium at the end of the above article/test for this year. Last year I bought the Blizzak LM005 for the Octavia, this year I think I'll buy the same for the newly arrived Formentor... Each time I checked, the Alpin6 was at least 10% more expensive than the Blizzak - a price difference not justified by the scores in the tests I read so far. The Hankook iCept is significantly cheaper than both the above, with pretty good performance in the test.
1.5TSI Octavia Real World MPG
Yep, I think all cars with "hidden wipers" under the bonnet have this option available - service position; it makes life a lot easier. Just remember: this option of holding the wipers lever down for a few seconds to lift the wiper arms - it's only available for about 10 seconds after you switch off the engine (it's written somewhere in the manual). If you'll try 1 minute later or let's say the next day when you unlock the car - it won't work. So the workaround is: ignition ON (no need to start the engine), then ignition OFF, then pull down the wipers lever for a few seconds. Wipers will go back down if you hold down again the lever for some time, but there's also an automatic mode (that I prefer) - they will park themselves once you start moving and go above some 10 km/h.
For point 2: use "wipers service position" with confidence - I always do... I actually rarely clean my windshield using the wipers (unless I'm on a long trip and don't have time to stop). Most often I'll stop at the first gas station (when needed) and clean the windshield using wipers service position and lifting the wipers. And don't bother with the tablet menu - just pull down the wipers lever for a few seconds after you turned the engine off.
If you want to see what is already installed on your car you have to go to: Menu => Settings => System Information It's there you can see the SW version, display SW version and the Navigation Database (how old your maps are...) - see picture
Backseat right door disassemble
Try to have a look here, maybe you get some hints:
Digital Skoda Service Records
It looks like the "eager-beavers" that worked (or pretended to work) on your car didn't want to leave any digital trace of their failures (inability to fix the problems reported by the user).
Sure, I thought it was self-implied...
Yes, one can check his own service digital record for free. I can't see how to do that on the MySkoda App (mobile version), but it works with the web-based Skoda-Connect interface. Once you login to your account, go to the car's Dashboard where you can see car status (locked/unlocked), mileage etc. and you'll also see a section called "Digital Certificate". Click on that and you'll get the option of generating a new Certificate and also to have a look at the existing Certificates. I have two in my list: one generated soon after I got the car (and found out I had this option), and the second one after the dealership visit this summer for the 1941 SW update (as shown by the first attached screenshot).
Volume keeps turning up??
AFAIK the volume level is displayed on the VC when adjusted from the steeringwheel, and it's displayed on the upper side of the tablet when adjusted from the touch-sensitive area under the tablet. So try to notice if any of the two cases is displayed when you have the volume increase; this might be an indication of which is the controller that is taking "fake input": the wheel on the steering or the touch-bar under the tablet.
Window Regulator/Lift Drive Assembly (Front)
You might find some useful tips on the topic below. On page 3 there are some posts of @Felix2021 addressing the problems you mention:
Skoda Octavia 1.5 tsi dsg7 etec 2021
It's a nonsense what that dealer told you... If there's no (or weak) side-wind, the car will not (should not) go to the right or left simply because there is front wind resistance. Just change the dealer if that was the answer of the current technician you're visiting. If you mentioned sport suspension setting we can understand you have DCC on you Octavia? On Sport setting it should be clearly "stiffer" than standard (non-DCC) suspension. So once again, the dealer would have no reason to say "the car has soft suspension".
Ok, what you describe is clearly different from what I experience. There's really no reason the car should wobble right-left on it's own on a straight-flat road without external factors, such as strong side-wind. Are you sure it's also doing that with the Lane Assist turned off? If so, you should definitely go for a road-test with a Skoda mechanic onboard. See if they still tell you it's normal behavior... Did you get the chance to have a test-drive with another similar car?
On mine I have exactly this kind of "instability" on surfaces such as those mentioned by @Jorgeminator If the road is "wave-like" for various reasons, the car starts behaving like a boat above certain speeds. If it's on a straight line I can live with it. But it sometimes occurs on some curvy-road and the combination of centrifugal force with the boat-on-top-of-waves behavior makes it really dangerous. I learnt to deal with it on roads that I know already, but I'm quite worried about it happening on roads that I don't know. And just to be clear: I'm not talking about driving at the limits of the car or the limit-speed for those curves. On those very same roads and asphalt-waves, my 15 y-old Megane drives great at the same speed. I partially blame myself for the "bouncy" mk4, because I added the "rough-roads pack" on mine when I configured it. It could be an effect of comfy-suspension combined with increased ride-height... I don't remembrer the drive-test car having a similar behavior, but on the other hand the test-trip was quite short and done on pretty good roads.
Brake lights and battery regen
Yes, they do light up depending on the regen intensity: (snapshot from Formentor's User Manual, but it's al the same VAG hybrid system)
Heated windscreen?
The easiest way is to look for the area that doesn't have the heating - positioned left/right to the mirror. Read the other/older topic. IF ONLY people would try a "search" before opening a new topic - it would be much easier to look for the information one needs....
VRS tdi 4x4 operating temps
