Everything posted by SwallownAmazon
Paint code.
My VW specialist workshop did one for me from SKODA Partslink 24 for nothing. Paint code listed in the Vehicle Data section - F3K; otherwise known as "Rocket Ship Red" as my 1990 Audi 90 20v is the same colour.....
Jacking Point Advice.
I'm having my alloy wheels refurbished in the New Year and I'm seeking advice on the best way to jack up the front end and where to place the stands under the car. I have a large 2.5 tonne trolley jack with rubber pad, smaller 1 tonne trolley jack and 3 pairs of stands of varying capacities (1 tonne to 3.5 tonne). Car is 2016 Octavia hatchback vRS diesel.
vRS brakes on a Scout?
I'd be inclined to try a harder brake pad before ging to the expense of changing calipers and discs. I've used EBC pads with some sucess on my Volvo Amazon historic rally car (now sadly gone) and my BMW 740 Sport. They make pads for different degrees of lunacy (!) but I've found the basic Greenstuff ones adequate so far. They are often available from Euro Car Parts and I'll be switching to these on my Octavia vRS at the next service. One advantage of Greenstuff pads is that you don't get that 'orrible black dust on your wheels because they don't contain copper......
Coil springs replaced at MOT, car sitting WAY too high... think garage put wrong non VRS ones on
What happened when you went to the garage?
- New discs and pads - Free of charge!!
Time for a new DPF, clean or a delete?
I can only offer advice based on my expereince with DPF and EGR valve problems I've had since buying my 2016 Mk 3 vrs diesel at 145,000 miles earlier this year. I had to replace my DPF because the original one was full of ash and the electronics kept trying to regen. Because the ash content was too high, it showed a variety of codes/warning lights and eventually went into limp mode. All sorted now with new EGR valve cooler and DPF, pus assorted sensors, gaskets, etc. With a bit of internet research, I found the service life of these components (and the turbo) is around 120,000 - 150,000 miles after which they need to be replaced. You look to have done considerably more than this and the ash content of your DPF is at the maximum. Bite the bullet and have it changed and at the same time consider a new turbo because if the oil seal fails, DPF will be choked in minutes.....
GEAR KNOB.
Thanks for that, I'll take a look at the weekend - weather permitting....
GEAR KNOB.
Anyone know how to remove the gear knob from the lever on my 2016 Octavia vRS manual? The pretty metal trim around the front edge of the main emblem has started to come apart leaving a sharp edge that cuts into the fingers when changing gear. Is the knob separate from the gaiter or does the whole thing have to be changed?
I had a similar problem with my 2000 BMW 740 Sport a few years ago. Broken front spring replaced with a standard item which made the car sit lop-sided. Garage told me that the "Sport" springs were only available in pairs,so they got the standard one without asking me. When I gently "blew my top" at them for not asking me, they had the car back and changed both fronts for the proper items only charging for the parts, including the refund for the wrong one. In your case, they have clearly fitted the wrong spring / strut assemblies, front and back. Take measurements of the ride height of your mate's car, centre of the wheel to the lowest point of the wheelarch, and compare that to the measurements on your "repaired" car; there will be a significant difference. Present those to the service manager and tell them to sort it..... If you still have the sales brochure for your car, it will state the vRS suspension is 15mm lower than standard but it only actually quotes overall height. You mention in the original post that it was a "major franchise EH"; is that a Skoda franchise or other manufacturer? If it's a Skoda franchise we need to know so as to avoid in future....
- Broken infotainment system
OBD Fault Code Reader
I bought one of these back in the summer: AUTOPHIX V007 OBD2 Scanner Compatible with Volkswagen VW Audi Skoda SeatI paid around £60 from Amazon but they seem to have gone up a bit since then. It reads codes and enables fault deletion but I havn't got around to finding out what else it can do.
Appalling Customer Service
No it won't, Manufacturers will only appoint dealers that can afford the shiny white elephant showrooms that now seem to tbe the norm. They don't care a monkeys about customer service because once you've bought the car you're stuck with it for good or ill.
Update? Are you content now?
Interior Light
These folk might be worth a try: https://www.classiccarleds.co.uk/ They specialise in old car fittings but may have modern stuff as well. I've fitted LED's from them to my 1937 Morris 8 so I can see and be seen a bit better.
Passenger door lock
My wife's 2008 SEAT Altea has had exactly the same problem twice - new door lock needed each time.
- Skoda Octavia 3 Facelift vRS TDI Oil consumption and other issues
Like JohnMack, I pensioned off my 2008 BKD engined Octavia diesel earlier this year to buy a 2016 vRS diesel with the CUNA engine on around 145,000 miles. Like any car, previous maintenace is vital and the car I bought didn't have much recent history - silly me! The memsahib and I both loved the car when we saw it but after a few weeks, the problems started. The pale orange engine light came on shortly followed by the curly glow plug light which sent it into limp mode; I'd also noticed a heavy oil consumption -~ 1/3rd litre in 200 miles. To cut a long story short, it's had three exhaust gas temp sensors, two DPF pressure sensors, EGR valve cooler and DPF all replaced at a total cost of around £3,000. The heavy oil consumption turned out to be a leak from a missing gasket somewhere in the turbo area which allowed oil to leak onto the manifold but it's still a lot higher than I am used to. It is because the oil used in these engines is so thin (0-30) that it just disappears. If thicker oil is used, the residues clog up the DPF which will ultimately block with replacements available at £1,200 - £1,800 depending on where you get them from. Ignore re-worked ones as a bad job. Notwithstanding the above horror story, we both still love the car; it seems to be well engineered, (DPF system aside) has more than enough power and handling to keep a retired rally driver happy in his dotage!!
Special tool
Hi John, Yes it's me - sent you a PM. BW Chris.
Special tool
Not if you use it properly........ It has lots of different fittings because there are lots of different calipers.
Special tool
Yes, Tornado red (fading to pink in places!) B3 2.3 litre 20v. My company car back in the day and I bought it for the memsahib when it was written down to zero in the books. 180,000 miles and still on the original clutch and exhaust..... Took it to Spain on a tour 3 years ago - never missed a beat.
Special tool
That's what I used on my old 2008 Skoda, my 1990 Audi 09 and 2000 BMW 740 Sport. Excellent piece of kit. Just beware of the excess brake fluid possibly overflowing from the reservoir when you use it.
235/35/19
That's what I intend to do when my fronts are due a change - wheels need a bit of TLC at the same time.....
Which one to choose?
My personal view would be to go for a manual gearbox - lots of potentail problems with poorly mainatined DSG boxes..... If diesel check for proper maintenance of the DPF and associated components. Try and get a good quality scan done for stored faults before you commit. I speak from personal experience....
1.6TDi 2017 has failed a fuel injector resulting in disaster
Alan, You've clearly had a bit of "bad do" but if you like the car it doesn't really matter if repairs cost more than it's worth. It's the replacement cost you should be comparing the repair costs to. I spent many hundreds on my old 2008 Octavia until it became untenable because of the need to go into the London ULEZ quite frequently. In many ways I still regret selling it because its replacement ULEZ compliant vRS has been an absolute sod.....
Fuse for rear wiper - question from a beginner
My previous 2008 Octavia 2 got through two rear wiper motors in 160,000 miles. Something to do with the seals for the concentric water pipe that passes though the motor assembly not being terribly good causing corrosion which ultimately makes the whole thing seize up. Not repairable! Make sure yu get the correct replacement - there are two different types...
