petrolcan
Everything posted by petrolcan
  1. Go to AliExpress and search start stop module for your specific car
  2. @WaveyDavey If you're sure they're the same then these are what I stuck on mine the other week, https://www.aliexpress.com/item/1005004092174448.html
  3. Have a look here about the headlights As to the rear cam, why?, what would it achieve. Better to have front and rear dash cam, at least that way you might make a few quid if the clip went viral on youtube.
  4. Whip out the 12v socket and change it for one of these https://www.aliexpress.com/item/1005003890795636.html
  5. Pull it out, with gentle force
  6. I'm showing these pics to my OH as she thinks my car is untidy ðŸĪĢ
  7. Check yourself on https://updateportal.skoda-auto.com/en-GB
  8. Likely brake pipes but without an actual picture.....
  9. A battery on the way out possibly could so testing that would be a good first step.
  10. Have you changed your battery recently?
  11. I've run the same tyres for five(ish) years now and that wear on the front looks the same as what I had on my previous car, a Signum. So long as the tread depth is legal I wouldn't worry. FTR, after liking them so much on my Signum I've put the same tyre on my OH's & FiL's cars and on Friday had a set fitted to my Superb. Great tyre 😃
  12. Sounds to me like you two need to move to nicer areas ðŸĪĢ
  13. Ummm, you have the car and unless you've run the tyres on the kerbs so much that you've worn off the lettering, go outside and look maybe?
  14. You have a dodgy level sensor, you need to find out which one it is.
  15. 90°C I would have thought. Easiest way to know would be to take it for a run on a regular day (i.e. not today!) and see where it settles.
  16. Does your insurance cover missing keys?
  17. Stuck on some cheap pedal covers https://www.aliexpress.com/item/1005004092174448.html Also stuck on some not so cheap rubber on all four corners - Vector 4Seasons
  18. Your starting point is a VCDS scan and work from there.
  19. If it helps any, my level sensor failed a couple of months back and it still passed the MOT with the lights in the 'safe' position. YMMV.
  20. The specsavers comment wasn't aimed at you @Carlston
  21. Go to specsavers would be my advice
  22. I was joking about the gaffa tape! Seriously though, look at you pics and examine how much grip the bar ends actually have on your rails. Ask yourself, would you be happy travelling behind something like that?
  23. Bear in mind that you'll notice a difference with new suspension anyway. My advice is just drive it and if it's still annoying you in 6 weeks time, do something about it then.
  24. You need to make sure that they have a snug fit, those pictured don't. I know on my FiL's Yeti, there's locating holes for pins for additional security. Maybe a bit of gaffa tape would help ðŸĪŠ
