Paws4Thot
  1. I'd be doubtful that this will extend the life of an LED unit.
  2. @Hardcore @Breezy_Pete I'm also wondering if the ESC "fault" could be low voltage?
  3. Not as such, but using the supplied wheel brace will normally give you about the right torque.
  4. I kind of hope so because used pads don't bed well to new discs.
  5. I'd missed on that. Jack the corner up, support it on an axle stand and see if there is any fore and aft play. If there is, suspect an issue with the bushes or swivels.
  6. As @skomaz, I think the alternator is most likely another well documented 15 mins at the local garage fix.
  7. The 150 is heavier than the Furbie and has less power and torque than the 170,
  8. Do not buy illegal pirate software. At best it won't work well, if at all. At worst it will brick your ECUs and don't expect any sympathy if it does.
  9. As you may have gathered, I think that, at worst, making the temperature lights work normally will be about £30 (parts) and maybe 15 minutes labour at a local garage.
  10. Not knowing the model, I'll just comment that it's possible that it was air cooled and didn't have water to have a temperature.
  11. Well, in anything I've driven the red one is supposed to be for overheating (and possibly low coolant). The most likely cause of it illuminating on a cold engine is a false positive caused by muck on the level sensor prongs, often visible if you unscrew the cap on the expansion bottle and look inside. This is usually fixed by scraping a broad flat blade screwdriver down the visible side of the prongs 2 or 3 times. If you can't see them, a new expansion bottle is under £30.
  12. WoW!! JayOrr admits to not knowing something. Honda have used low temperature (warning) lights for at least 10 years.
  13. In this case, the only way I'd see "8" as a typo for "5" would be if I was looking at a matrix of numbers which might be entered with a numeric keypad when 8 is just above 5, rather than them being separated by 6 and 7. Still, other than brake fluid DOT numbers stopping at 5 or 5.1, I think we can agree that LHM is only applicable to Citroens (and possibly a few Mercedes and/or Royces)?
  14. I'd expect a low temp light to be blue or maybe green.
  15. Pete23 last visited in June 2020.
  16. @ludvig @nta16 According to this Wiki there is no such thing as "DOT 8" brake fluid. If you have evidence to the contrary, please supply photos and/or web pages.
  17. During the first hour after you make a post if you click on the ellipsis (...) top right on the post you get an edit option.
  18. Curious. I've never known the coolant light throw a latching fault. Could it possibly be dirty prongs in the expansion bottle?
  19. 1) There's a good chance this is electrical, but in the driver's door, not the passenger door. Continuity check the wiring through the driver's door bellows. 2) The cupholder is common with the Elegance and Lauren and Klemens trim levels. It may also be on at least some late Ambiante models. 3) That may well well be a dead wiper motor, or wiring through the LH boot hinge. 4) Leave the boot trim until you get the wiper motor fixed.
  20. @zom414 Get round tyres; Rudolf Uhlenhaut tried square ones on a Mercedes GP car but the drivers complained about too much vibration!
  21. I like the idea of turning lane enforce off permanently. Turning off "randomly slam the brakes on" seems more useful than turning off stop/start.
