Everything posted by Aldfort
- How do I reset the service reminder on a Skoda Scala built on 13/1/25 with an 8" infotainment?
Coil pack issue
That makes sense, a leaky injector will lead to an overworked or fouled plug which will put strain on the coil pack. Glad it's sorted.
- Can sombody explain this PR code please
Servicing mileages and components.
I'm going to suggest something different. Service the car annually as a minimum even if you don't do many miles. In fact more so if you don't do many miles. Make sure the right oil and the right oil filter are used. (They don't have to be "Skoda" but they do need to be OEM meeting OEM specs.) Active cylinder technology and stop-start place a lot of strain on an engine and if you are not careful it will gum up a lot faster. I'd also do the air filter more regularly than specified for the above reasons. Pollen filter, follow manufacturers recommendation unless you live somewhere really dusty. There is a YouTube channel called The Car Edition, it features real mechanics working on real cars. It's an eye opener and regularly gives the lie to manufacturer service recommendations.
Renewing app subscriptions
I have my 1 year old Kamiq linked to the Skoda Connect app on my phone. I don't have any banking apps on my phone. How do I renew a subscription to an app (Traffication), do I go into the Skoda Connect shop on my PC or can I do a one off entry of card details in the phone app?
Coil pack issue
Something else is happening to cause this. I'd suspect a slight water or oil leak as the first culprits allowing contamination of the coil packs. If he lives in a rural location then I'd also add in a suspicion of animal damage. Given it's happened more than once and happened twice inside warranty then Clearly it's not fixed. So he has a claim. I'd ask the garage to do some proper diagnostics and check running voltages and currents on the coil packs on a diagnostic device. Easy enough to do if you know how and there will be specs on all the forgoing. The bigger issue will be finding a technician who knows how to do it. Independents are often better than main dealers at this. So it might be worth spending a few quid to get to the bottom of the issue quickly. Have a look at this: Repeated ignition coil failure. What may cause this?
Brand New Kamiq Clutch Issues, Creaking and other Shenanigans
I too would be tempted to reject the car. Too many issues. You could try resetting the infotainment to fix Laura. Long press on the on off "button" until the system re-boots.
Total mileage reset to zero!
Ah, sorry, pre-digital cluster. That said, the cluster should simply repeat what the ECU knows. It's worth checking if the odometer moves at the same rate as the trip meter. Do 5 miles on the trip increase the odometer by 5 miles? If they don't then you should suspect a cheat device. That could explain the mystery re-set as well. BTW - any garage that has an Xtool diagnostic reader should be able to reset this fault. If you Google Odometer reset on Skoda Kamiq you should find the related video.
Trip is on the bottom left, just sayin' Odometer is bottom right but not always visible. This is why I find your problem a bit odd. The display needs to refresh every time the odomoter is to be displayed. If, as you have been told, the car knows it's actual mileage then the display not showing correctly is odd. Have you ever had the car plugged in for any sort of diagnostic reading to be done? Some diagnostic tools are very powerful. Also did you buy the car new? There are a number of "cheat" devices that restrict the mileage shown by the odometer.
If the car knows it's mileage then restoring the memory to the odometer should not be that difficult. Before you commit ask exactly what they intend to replace and what assurance you have it will fix the problem. The "cluster" is just like a PC screen, a relatively dumb device! The ECU holds all the data, if the display is "wrong" then this points to a data bus error. Also, dumb question, but are you sure it's not just the trip meter that reset to zero? Depending on how you have the display configured the actual odometer can be hidden and only the trip meter is visible.
Spark Plugs
Yes, I'd change them before you hit 50,000 miles.
- Interior light switch illumination
Scala 1.0 tsi SE L 2024 sat nav
This sounds pretty normal to me. If your preference is set to Fastest then the Sat Nav will route you to avoid traffic congestion. If your preference is set to Shortest then it'll route you to do that. Note shortest is more than often also the longest duration. It's easy to confuse the Sat Nav. Essential that you halt route guidance before programming a new route or changing preference. Best thing is to have the destinations stored as favourites, then you can just select the one you want. Note if you don't follow the sat nav directions exactly it'll re-calculate as you drive with the intention of getting you where you said you wanted to go. So in your case if you retraced your steps it would have been fine and would have figured out what was happening eventually. (OK, it's annoying when it keeps telling you to "turn around when possible" but just press on and it'll catch up eventually.)
- Inspection required.
Skoda LED Headlights
The LED's will be brighter than most halogens but the beam is also better focussed.
- Help - EPC LIGHT
Gear changing started making sounds
Ask that a "master technician" goes out with you for a test drive. Suggest you drive and then tell them when you hear the sound. "Master Technician" may be a UK term - here it means a technician who has had a lot of Skoda training.
- Help - EPC LIGHT
Strange engine sound after turning off in freezing temperatures
Well mine certainly makes a number of noises after I switch off the ignition. Our Golf is the same with similar sorts of noises.
I think you just get the LED headlight and DLR. Also LED rear light. Probably means that the fog lights etc are not LED. Owners manual here might give some clues: Skoda
- Help - EPC LIGHT
No idea - sorry.
- Help - EPC LIGHT
- Help - EPC LIGHT
I can't hear anything except the distinct click as the gear leaver moves across the gate.
