john999boy
Honorary
Everything posted by john999boy
  1. On your filler cap will be something similar to this:- This says for up to 2 people with 14" tyres and a minimum of luggage you should use 2.1bar on the front tyres and 1.9bar in the rear. From what I can see in your post the minimum should be 2.6bar and not 2.5 though. Don't forget to reset the TPMS afterwards. πŸ‘
  2. The only reason I can think why you’d want this is because your car is used as a taxi? The answer is I don’t think so though.
  3. When you lock the car from the inside it only stops people from opening the outside handles.
  4. The map would be the same so the choice is yours.
  5. Ben from Shark moved to Racing Line Performance in Milton Keynes.
  6. It could still be that the bulb had just been replaced before you got the car and it hadn't been inserted correctly. πŸ‘
  7. This thread could potentially be your starter for 10.
  8. On a scale of 1 to 10 it was a 1.
  9. Unfortunately not as it was in 2007 & 2009 when I had those cars. 😁
  10. I have. It was with Velcro attachments to allow easy removal. Others have attached power to that location too.
  11. I've been using AA today and checked out what you said. The solution is simple - just touch the screen and the compass and zoom arrows appear. Something to remember for next time. πŸ‘
  12. Tap the Google compass to change the driving orientation. πŸ‘
  13. Check out the links on my signature for the latest maps.
  14. @Brijo If you'd like to continue fordfan's topic (well actually a Pt2 version) then the least I can do is add it as a pinned thread. πŸ‘ It obviously needs someone of Freedom status to be the thread starter and be able to update the thread as necessary.
  15. Or maybe did you mean a manual parking operation and want it to act like the rear sensors do? If you did, then Dave’s cardboard box will be needed! I don’t think they do act in a similar way though.
  16. If you think this through logically, the car can’t complete a parallel parking operation if it’s going to hit something so……. πŸ‘
  17. There's quite a few ham's on here. 73 de me. πŸŽ™οΈ
  18. BTW, halogens aren't self levelling add they have a roller adjustment.
  19. It could be that they're not quite fitted right too. Maybe check that?
  20. Considering that MartiniB uploaded the links on 22nd October - and I downloaded them a few days after, yesterday was when I managed to find time to begin the install. Total Commander extracted the files from the 'problematic' archive and they transferred to the car as easily as previous versions.
  21. Now now, don't be bitter. πŸ˜‰ I'm sure that incentive is purely to encourage a FULL EV take up. πŸ‘
  22. The metal that you refer to is the strengthened area which prevents the seam kinking. The ' triangles' IIRC are in the dimpled zone on the body.
  23. There's a little triangle on the bodywork at each jacking point.
