john999boy
Honorary
Everything posted by john999boy
  1. Yes in answer to the first part and I normally remove the folder.jpg files to reduce clutter. Whether they'd override is a different question to which I don't know. Does mp3tag actually adjust art sizing instead of just being excellent at sorting & naming?
  2. The album art needs to be a max of 500x500. There are some programs that will automatically do the leg work to sort that out.
  3. We still allow Golf R owners on Briskoda!
  4. Done.
  5. It looks like they also removed the brilliant green. @FarEaster Please only use English.
  6. You really need to put in in the Wanted section as that could bear fruit too.
  7. Remember to keep it factual please.
  8. @Rustynuts may be able to assist?
  9. I normally put all tracks in to the root of the album name and ensure that their name begins 101, 102 - 201,203 etc. Then I make sure their playlist tag follows with 1/60, 2/60. A good mp3 editor can soon sort this for you.
  10. It may well be down to whichever ISP you've chosen but I'd certainly give it a go. If passwords etc are required then they'll be able to tell you what goes where.
  11. I don't think trailer assist was available then. Not too sure it's available now either but hopefully someone can say. My MY 2018 L&K with a factory tow bar certainly hasn't got it.
  12. Which phone do you have as quite a few don't support mirrorlink?
  13. Can you please use English in future. [Quote]Regards I have a Škoda Octavia 2019 I can't connect to the mirror link with my mobile phone and how the software can be upgraded[/quote]
  14. As long as the PCD is the same and the offset is similar then 17" wheels will be fine - they may be tight as @Kenaimentions but will definitely fit.
  15. Have you seen if a short drive resets things?
  16. Have a read of this thread and you'll save the £30 as mentioned above.
  17. The wiper requires the door to be closed. Maybe check that.
  18. @Diljit Can you please ensure that new threads aren't started when you already have existing ones regarding the same thing. It makes for annoying reading - especially for the people who are able to help! Thread locked.
  19. Have you checked the phone volume as IIRC the output depends on that.
  20. I'd make sure that the wiring inside the quadlock connector hasn't got a dodgy connection.
  21. Why not post an Ad in the Classifieds?
  22. It is but you may need to have either a Maxidot display or access to someone with VCDS. Hopefully someone else can confirm the first part of my answer.
  23. Two quick presses will unlock all the doors.
  24. Does the driver's door unlock with one press but the others don't? Do you have different profile settings on each key? I can't remember if the Mk2 had that ability but later cars do.
