Cairus
Everything posted by Cairus
  1. So, the passenger side is installed. Mirror lowering is active. For the driver's side, I have a genuine Skoda glass available for €60 including shipping. But I’m going to see if I can get hold of a complete mirror assembly instead. The plan is to get everything finished this year.
  2. Naturally, using a decent automotive test light, you check the fuse while it is installed to see if it is in good condition.
  3. Measure and check the battery voltage while the vehicle is starting; just because it is new doesn't mean it is in good working order.
  4. When an incoming call arrives, it is displayed in the instrument cluster. You can then answer the call by pressing the right-hand rotary dial on the multifunction steering wheel. Or have you actually read the manual?
  5. Check this https://mibsolution.one/index.php/f/157055 User: guest Password: guest
  6. Just take a test light and check all the installed fuses—both in the interior and in the engine bay.
  7. Link activ 24h No warrenty, your own risk https://mega.nz/file/1n8VxQ6a#bufS0VbAB09EhnCV7DQD6BJ9JcqLGbfmcah2xFMLE08
  8. SKODA Superb 3 L&K 2022 Car Factory 5F Unit: 3V0035816G When you Patch with USB CP Off & Fec's aktiv., IT Only works Maximum with Firmware 0332. You also lose all online things of the Unit
  9. Officially, you cannot skip firmware versions—for instance, going from FW03xx to FW04xx. Unofficially, it is possible, but the device must be patched. While navigation units can be patched via SD card, non-navigation units must be opened up and connected directly to the eMMC to install the Toolbox (using a virtual QNX machine, for example). I am referring to MIB2 Std units.
  10. Dataset for 4B? VCP dont have? Remote?
  11. Interesting... in both of our Skoda models, kodiaq & Octavia 3, the 8-inch displays have the blue connector, while the 9.2-inch displays have the black one.
  12. Yes, Cutter and 1 Minute Work
  13. Even so, the feature activation won't work properly, because the data on the server is different.
  14. Du weißt das du eine Ocu High 3 brauchst? Du bekommst eine Funktion Freischaltung nicht legal über odis. CP entfernen geht. Desweiteren arbeitet MIB3 und Ocu 3 mit Car Ethernet mit dem virtual Cockpit und dem Soundsystem wenn vorhanden. Beides muss Ethernet tauglich sein. You realize you need an OCU High 3? You cannot legally unlock the function via ODIS. Removing Component Protection is possible. Furthermore, the MIB3 and OCU 3 use Automotive Ethernet to communicate with the Virtual Cockpit and the sound system (if present). Both must be Ethernet-compatible.
  15. My 9,2" Display Display, the same in the kodiaq, 50€ 😂
  16. Firmware 0334 ist Last one for this HW
  17. Firmware 253T https://mega.nz/file/A3kVnRrb#5USQHMiRRmq3dhy1cjEvacw4y6GoXxRMGnsVhhOIhAw Patch for 253T https://mega.nz/file/cy9SyZYB#7Hoi6A-cIl1xc-J5oqRJ8Q27mOv7JbzYbnb9sLRcJQg
  18. MIB3? Preh Manufactur? Simple to patch CP Off via USB, but Software dont Higher then 332
  19. The latest map is rarely available for download on the Škoda homepage. Here is the current one: https://navigation-maps.volkswagen.com/vw-maps/Update_25_26/DiscoverMedia2_EU-AS_2710_V24.7z Europa All need more then 16GB
  20. You have to Share the Picture Here which Software train is installed
  21. Picture of actual Software train. Press Long Menü, Service Menü Open, Then Software Update, then picture
