Cairus
Everything posted by Cairus
  1. You can buy it on AliExpress or DIY
  2. So, wiring harness 4B and the wiring harness for the axle sensor are mostly finished. Today I ordered more colored wires so I can complete the wiring for 4B to the headlights. Connector 4B still needs to be replaced; it's just my wiring harness test connector. Then I can finally start the Retrofit I gathered some important information from the retrofit in the O3 so I don't make the same mistakes again.
  3. G11 latest 1447 what i have @caraushv
  4. Every Other Radio activate CP
  5. SVM is Coding from Factory Server
  6. Wrong, you dont have to do this. A Other Skoda Unit in the Car, CP is Possible to Unlock. But SVM ist not Possible
  7. Dont use Carly, i have buy it with all inklusive and it's the worst tool of all that I've ever used.
  8. Yes, or Take Off the Batterie
  9. Airbag? I have own Tools and need them
  10. And Always jewellers screwdrivers was enough?
  11. Then you hadn't had many types of plugs yet.
  12. First Violett then Pin
  13. Facelift have Xenon? Only LED Low and Matrix or Not?
  14. Your door control unit is located in the door itself. Therefore, make sure you choose a door with the same or more features. Pay attention to pre-facelift and facelift models, as well as sedan and station wagon versions. The control unit still needs to be coded to the vehicle.
  15. I never have done this, when i Code the Option it was Automatic on or Not
  16. Stabilus is OEM seller for 80% der OEM
  17. I use This DAB Antenne in 1x Octavia 3 Facelift, 1x Kodiaq 1 Pre Facelift and in 2x Seat Leon 5F. IT Works perfect...
  18. First, perform abrake pads change sequence. That is, open and then close. Unfortunately, OBD11 isn't always reliable with default settings.
  19. And you have No ESC/Abs/ESP Error? Fuse Number 1 in the Engine-Room is OK?
  20. This function ensures that the wiper blades aren't always tilted in the same direction. Simply put, they are tilted once to the left and once to the right. This is called alternating parking position. It's intended to extend their lifespan. This function can be coded out.
  21. Vcds have a Change Log File Which light you have? Halogen? LED? Xenon?
