Cairus
Everything posted by Cairus
  1. That is correct. Update make Problems by some Users
  2. Cairus replied to A6TDH's topic in Skoda Karoq
    Offroad is a Option with SwaP/FoD
  3. With one SD Slot, you have To make the URART.
  4. All the hardware parts have now arrived.
  5. We want to add a bit of bass to the Kodiaq. After much deliberation, we purchased the Helix sound system. This includes a woofer with a small DSP for the speakers and woofer. What is needed in our case: Helix system ---> 000051419B Short-circuit adapter if the woofer is removed ---> 000051727B More details to follow...
  6. 2Q0 Kamera TSR is SwaP Protection Patch Camera or use manipulate Dataset
  7. You can Not Update from Firmware x3xx to Firmware x4xx
  8. Password PM https://mega.nz/#P!AgEWbXJNihmMYuO4uyZm-6bB5pDjb9xNsqyZXk0bqofMzQYlpRFtj9XJF2vdfW2hAhIaGKyoQpiqQZW9gkgxn8mXKB5ryZ_ef9euCqmTocRmtfQlKVJSVNwwI4eULf-6d6a-HQRv1e4
  9. I converted a Kodiaq myself and find the prices of the adapters simply outrageous... There must be an OEM solution for this, and I seem to have found two solutions after studying the SLP and comparing it, etc. But currently only affects the Continental Gateway. I should have the Kodiaq available this week, then I'll do a real-life car test..
  10. t Roc dataset works without problems on the Kamiq where I made the parameterization
  11. Realy? H(umen) M(aschin) I(nterface)
  12. 100% wrong You want to Change something Over HMI
  13. You can Not Update direct To Firmware 353T
  14. Error 1: Basic Settings for the flaps triggern Error 2: The Lights are in the travel Mode, you can Change it in the Car Settings in the Radio
  15. Let's take a look at this topic: Skoda Kodiaq VFL Model Control Unit 13: Hardware Number 2Q0907572B Hardware Version H03 Software Number 2Q0907572Q Software Version 0342 What hardware is required: Steering column switch for ACC: 5Q0953502AL ---> NOTE: Depends on the vehicle's production date. Steering column cover for Kessy & ACC: 565858559G 9b9 for Satin Black I bought both for €90. The rest is all software-related. Request password via PM https://drive.google.com/file/d/1gvzALfST6INKoTQLhB5SqGNY11FUr-Gu/view?usp=drivesdk
  16. The principle and functionality of the Haldex has remained the same since its development. A multi-disk friction clutch, controlled by oil pressure. I know the part inside out, having supported the assembly line for almost 10 years.
  17. The Sensor can detection max 6 Objects
  18. Unfortunately, it looks like this at the moment; there's too much distance, with the new lights, regarding pedestrian protection, etc. Now we wait calmly for the pole.
  19. The firmware is completely irrelevant. The data set is what matters.
