Cairus
Everything posted by Cairus
  1. Ich habe 2 Stück OEM Skoda Halter für blind Spot daheim. Besorge dir 2 fix fertig codierte und Parametrierte 2Q0 Steuergeräte. Lege dir dafür die 3D Druck Adapter dazu. @Lutz_91 hat die selben. Hab einen funktionierenden vas5054a noch bekommst dazu. Du brauchst dich nur um Kabel Satz und Außenspiegel kümmern. Alles andere per PM I have two OEM Skoda blind spot brackets at home. For Superb 3 Combi. Get yourself two pre-coded and parameterized 2Q0 control units. Also get the 3D-printed adapters. @Lutz_91 has the same ones. I also have a working VAS5054A unit that you'll get with it. You only need to take care of the wiring harness and the side mirrors. Everything else via PM.
  2. 9,2" Display works Only with mib 2 High ---> Columbus Install VC need odis online, Cluster is Immo Master
  3. You make a Lot by the car , buy a vnci Red
  4. Cairus replied to vRSG60's topic in Skoda Yeti
    Yes i know it better. I have it for all mib 2 pq and zr Units. SD Card Patch Only Navigation Unit
  5. Cairus replied to vRSG60's topic in Skoda Yeti
    80£? 😂 The Patch is free in the Internet
  6. Cairus replied to vRSG60's topic in Skoda Yeti
    Oh 🤦
  7. Es gibt unter der Haupt Durchführung noch eine mit der Gummi Tülle sogar welche sogar verschlossen ist. Sicherungskasten ist bei mir Höhe BCM aber davor. Hölle was nachpinnen. There's another one under the main cable gland, this one even has a rubber grommet and it's sealed. My fuse box is at the level of the BCM, but in front of it. What a pain to repin!
  8. Cairus replied to vRSG60's topic in Skoda Yeti
    Of course, that was the question. Apple CarPlay and Android Auto haven't been officially enabled. Now, a firmware update is being rolled out to fix the clock bug, which means the patch for Apple CarPlay and Android Auto is gone. So, the unit needs to be patched again.
  9. Cairus replied to vRSG60's topic in Skoda Yeti
    Yes, you need New Patch
  10. You have vnci red/vas6154a or b?
  11. SwaP Patch Unit, Dataset with Odis VC Tool VCP etc. Dataset is easy With a Tool
  12. The 5F module has multiple data sets with different addresses and functions. These are stored in the EEPROM.
  13. No, but the need to set route data from the navigation system should be eliminated.
  14. The pACC has been deactivated. The system not only affects the speed, but also the lighting, etc. Normally, if pACC has been deselected in the menu, it should have the same effect.
  15. Oh, IT IS correct IT IS now a FeC, Patch Unit
  16. I'm from Austria... the parts were way too expensive. 5Q0 is rubbish, just upgrade to 2Q0. Much better.
  17. Dont Work anymore What i know Can check with my 3 devices
  18. The mounting base is screwed to the door. You have to detach the mirror from the base plate.
  19. Octavia 4 But you need the Ground plade from Octavia 3
  20. OBD11 and Carista will not receive an SFD 2 license from VW.
