tombee
Everything posted by tombee
  1. Just been a for a longer drive this lunch time and love it, get little DSG burps now, no doubt my fuel consumption will go down now, also to note for anyone else as @JR RS has said no drone, you hardly notice any difference when cruising along. Well worth the money, will look into some different tips. Spotted Merc CLS which has nice tips which are not the normal square/rectangle style, might be worth a look @travs
  2. It does, as its for the dip so helps to get a little lower
  3. Guess I might have to continue to adjust each time then, meh
  4. Car is back and my inner child is very happy, luckily I need to get some fuel at lunch so the long way to the pump it is. They did have to slightly modify the res delete pipe to fit the exhaust due to a slight bore size difference.
  5. What I thought your car scanner could do everything haha
  6. Cheers for that, will be on the hunt now for that, also 4 wheel laser alignment as well as I am pretty sure the previous place was not
  7. Yes thats what they are saying it's due to the extreme range, but I am tall haha Ok sure could do that as a test
  8. So I have an issue which is bugging the hell out of me, my steering wheel is right hand down about 20 past the hour, this seemed to have been noticeable since I replaced the steering wheel, I honestly can't remember if the old wheel was like that. I am 99% sure I put the wheel exactly centre after removing the old wheel which was in the same place, I have had tracking done (have seen that some else had tracking done and the settings were incorrect.) so might need to get them checked again. Yesterday Skoda said they checked the Steering Angle Sensor and they made a slight tweak but still the same from what I can see. Is there anything else I can do? Remove the wheel and put it on cocked but then setting the SAS might through it out again? Just wondering if anyone else has had this type of issue, and issue after steering wheel swap.
  9. Car has been at the Dealers yesterday, whilst getting the screen replaced, they checked the seat and 2 techs have said this is normal behaviour, but don't have another to test against. I have said that this didn't happen on my Tarraco with the same seat controls etc. But thinking about it now, the Tarraco was a newer model so could of had the newer seat module. @JR RS where is the module located so I can have a look, they said no firmware updates etc for the current one.
  10. Screen all replaced took longer than I had thought but all done now
  11. Car is currently at the garage having the res delete done, will speak to them about tips when I go back to collect
  12. Thanks @JR RS I was able to get a good deal in the end, for anyone else, RPM have an eBay shop where this was discounted to £119 but was able to submit an offer plus I noticed that it’s free postage on eBay also which is not the case via their website
  13. Thats a good point and it wasn't, so thats for getting me to check. Just spoken with RPM but they are not sure on the Octavia fitting the Superb, can you confirm that this is the right pipe and I will order it, or if anyone has any underneath pictures of their car 2wd https://www.rpmperformances.co.uk/skoda-octavia-vrs-mk3-tfsi-anti-drone-resonator-delete-exhaust
  14. It’s not a competition haha
  15. Been in contact with my local PowerFlow Exhaust company and they can do the res delete for about £120 all in so have this booked in now Will be looking at doing the exhausts with them also but wanting to get the valance/diffuser first so that can get the staggered tips I want
  16. You can do the wipers into maintenance mode from the ignition switch
  17. Thanks, OBD11? I don’t have a Windows device only Mac and iPhone, hence why these products
  18. What device do you have now, as been thinking about getting Carly, be nice to code the boot to shut via the button inside
  19. Thanks, my dealer no longer does the clean now, as when it went in I said not to clean it and they advise they no longer do that service. Thank goodness as them Skoda dealer is at the groups Audi dealer with an RS6 outside with bird poo on and a brand new RS3 in the showroom with swirl marks and scratches all over it
  20. The company local to us can do it which ever way, you take the car there and leave it, then do the wheels and then refit, there lead time is about 1.5/2 days currently Or you can take the wheels to them and then collect when finished Thanks started to do this on the cars I detail now haha
  21. After doing the gear knob yesterday I saw how dirty the interior was so this morning after doing my wife’s Mini, I set to work on the inside of mine.
  22. Found out that my screen replacement has been approved and is booked in for a few weeks time with the unit already in stock, another ticked off the list. This is on a Superb I might add with extended warranty
  23. Got round to doing the Gear Knob swap with the Mk7 Golf/other VAG, added the alcantara to the gear knob and also gaiter which now matches my steering wheel. Very happy with the result and can leave this area of the car alone now.
  24. The gaiter arrived this morning and had the Skoda gear knob off earlier, was a lot easier than I had thought, thanks to @Binx1310 for the manual to confirm. Had to trim the new gaiter as for a mk7, with then gluing on the new to existing Skoda surround to then mount in the DSG panel. Fitting the new gear knob was easy also and it came with a new metal clamp ring also. I am very happy with the results of these bits matching the steering wheel.
