Everything posted by Redboy
2019 Superb 4x4 272 - maybe not 🙄
What a shame as the other one which sold was loaded with all the best extras. Stick with it @Gaz there will be a decent one. Having owned a Stage 1 VRS and 245 GTI, I know the 272/280 are more spacious, relaxing to drive and will easily beat them away from a standing start. The FWD cars simply can't put their power down. However, the slight downside is that the 272 and I think the older 280 have less torque. Easily solved by a stage 1 map and the DSG box will handle the extra load. I think the 280 has a 6 speed DSG, vs the 7 speed in the 272. If you can get a 18/19 reg I think they were under £40K for the cheaper road tax
@Gaz the L&K lights were very good adaptive beam shaping. Hopefully they are on this one
What's not to like? Great colour, heated front screen and looks like Canton, which is ok despite all the negative comment I have seen. I had a 19 reg L&I 272 so can speak from experience. DCC makes it less floaty. They are smooth and quick. 32-34 MPG in summer and 40 Mpg if driven at legal limits on the motorway. You are aware of usual service requirements. Check the black plastic sunroof surround roof panel for cracks. Mine cracked and had to be replaced under warranty cost around £1000. The front discs look a bit lipped, they are not particularly cheap to replace. Check the coolant expansion bottle water level..mine dropped several times, I gave up trying to get the dealer to investigate beyond filling it up repeatedly, even though it was under warranty! Hopefully this example is flawless.
My first car was..
1976 Toyota Celica 1600 ST ...with an Eagle on the bonnet! 🤩
DCC Longevity
@Steve vRS DCC is a good option. There have been issues on Superbs with leaking dampers, probab!y related to mileage and sleeping policemen
Price when new ?
Probably worth about 2/3rds of your purchase price. It will probably even out to around 40-50% after 3 years.
Losing coolant
This seems to be a common issue on TSI engines. My old 272 started to lose water, dropping 2-3cm below the max line over 3000 miles. I pointed it out on two occasions and mentioned the common issue, as it was on a fixed service / warranty plan. Expecting a fix I lost confidence in the dealership, who filled the expansion tank to the full mark twice for 'observation' and patronisingly told me it's a TSI characteristic!! I often find the company responds slowly or negatively to common non-wear and tear problems, i.e. design or component faults, even when forums like this have multiple examples of similar failures. Good luck to @100andthirty getting it sorted.
Heated Windshield
What a helpful post. It was simply a picture of the OEM screen fitted to my last car to illustrate. It was identical to the one fitted to my Golf GTI. They are a good safety benefit. By all means don't buy a VAG car with one if it offends your sensibilities. You stick to scraping ice and getting cold.
- New Croatian VRS 236hp 19inches
Second hand Karoq advice
My commute is 10 miles on A roads with one set of lights at mostly 50-55 mph, recently with around 43-46 mpg indicated, which will improve slightly with warmer weather. On a 30 mile drive last weekend on A roads, keeping up with traffic, it was showing 51 mpg. After 30 years of manuals, my last 3 cars have been DSG and I am converted, I can't fault their overall performance. Unlike my last Superb which had the oomph to sit in 7th unless urgent acceleration was required, the Karoq's DSG box keeps it in 6th on a light throttle at 50-55 and will drop down into 6th fairly easily on inclines. It's just an observation and is simply holding the car in the right gear, matching economy/power requirement . When power is required urgently, i.e. kickdown, my experience is that regardless of engine power, a DSG box hesitates and can go down too many gears. In the Karoq it's smoother and safer to pre-plan and flick down a gear or two using the paddles behind the steering wheel. Finally beware the "smaller engines always equals better economy" mantra. My friend recently got a 23 plate 1.0 Fabia Monte Carlo DSG. It's very nice but its economy is definitely slightly worse than the 2020 Octavia 1.5 TSI which he traded in. I hope you get a reliable car and a good deal.
Cars is acting geriatric
@AMiles MKII Octavias suffered from corroded wheel hub sensor rings, which illuminated ABS and TCS warning lights on the dashboard clocks. Did they replace the hubs? I am not sure why this would be the reason for an alarming/uncontrollable surge in RPM. Good luck with getting it safely to the garage tomorrow.
Can you get a 4x4 petrol vRS estate?
Just map your car. Torque increase with the bhp will help. Otherwise just buy a 4x4 Superb that will put the power down with virtual cockpit and Columbus ICE
When to buy a new Karoq
There were a lot of 23 reg Karoqs with under 50 miles on the clock for around £29-30K when I bought mine in December. It had 8 miles on the clock, lots of decent kit but unfortunately no ACC and heated screen. I figured I could live without those extras and enjoy the savings.
Space saver kit error
Not happy with the compressor and can of gel, I bought a new space saver from eBay after some generous advoce from @Modders, along with a Karoq-specific 2WD space saver kit from Caffyns Spares online. I fitted the spare on Tuesday and was surprised to see the jack, fully extended, only just managed to raise the car about 5-10 mm off the ground. The label said Octavia, Rapid. I called Caffyns on Weds to question if it was the correct jack. They called on Thursday to confirm the part number was wrong and would send a replacement. It arrived today. Dealers so called 'stealers' get a hard time from some on this site. I can only praise their customer service and quick response. Not sure if you can read the label on the photo but the difference in size is immediately apparent. I.e. the larger one is for the Karoq.
Karoq 19 inch Crater Alloy Wheels
Yes £105 per wheel....or £175 if they discover a buckle, which I have just paid for my son's Audi 19" Turbine to be repaired. It was either but the kerb or hit the oncoming bus! I thought £175 was a bit rich until I saw that a new set of wheel rims was £ 3360 at 30% discount according to one website. Madness.
Coding on s 2023 Sportline 1.5dsg
We tried OBD Pro on mine and there was no expensive hidden option that came up. It allowed us to disable the annoying seat belt warning bong and fill up fuel quantity. Traffic Sign recognition wasn't an option. I wonder if what I think is a camera in the front screen mirror, is a rain or headlight sensor. I can't see lane assist as an option and am happy not to have it.
Crazy Skoda sale offer
Unless you can pay outright then there will be a premium for driving a new car. PCH was fairly cheap but those cheap deals are now scarce. As for trade-in values, the dealers have to provide facilities, pay staff, taxes etc. The 2nd hand market is apparently weakening. We all expect cheap deals and max trade-in value. The best deals are in my experience pre-registered or almost new with low mileage. I.e. you aren't paying the initial lump of depreciation.
2023 Superb 280 Sportline Plus 4x4. A good buy?
@HappySam Yes stop overthinking it. I have had a mapped 300 bhp Octavia and a GTI 245 PP. Both would be easily beaten from the lights by my 272 4x4 Superb L&K. The 2WD cars just can't put the traction down effectively. However once rolling the Octavia had awesome torque and could possibly catch the Superb. MPG in summer keeping up with most traffic will be 32-35 MPG on short A road trips and up to 40-ish on longer trips. It will feel a bit 'boaty' after the VRS, so on the test drive try out it the DCC Sport mode if it has DCC and you'll realise how you can really push it along twisting roads despite its size. The equipment and comfort was fantastic and overall it's the best car I have had, particularly since it only cost me £26K at 6 months old with 2500 miles on the clock and £155 road tax. You get one life so if you can afford it, spend the money and enjoy.
Some Facelift SportLine Questions
Mine came with 18" 50 profile Goodyears so am happy with the road noise and comfort levels they offer
The digital dash has lots of options.Sunroof doesn't rattle...yet. Performance is ok, I wouldn't bother trying to race anybody. MPG is very good....44 MPG on my usual A road commute road. I say very good MPG against the background of having had 2.0 petrol VAG cars for 16 years
Early days…
That mirrors my impressions. It is a quiet car,until you stamp on the accelerator for kickdown. Very economical. Occasional wheelspin during fairly gentle pull away in slightly cold or damp conditions. Unlike my previous 2.0 TSI DSG cars, it definitely does jerk at low speeds when you lift off and let the DSG box slow the car down. Well equipped, comfortable and a big plus....a sunroof that doesn't rattle....yet.
Off to the Karoq forum
Isn't a Kodiaq a jacked-up Superb? Horses for courses. I grew up being driven around in 1960 -1970 Jags so it's all been downhill since then. 😁
My driving requirements have changed. Most trips are mostly under 10 miles. Even where I live the traffic as grown to where it presents few opportunities for overtaking and making ground. If I want some fun I can take my Kawasaki 1000 out for a ride.
PX
Just cancelled
I was surprised to find my new Karoq doesn't have lane assist
