Everything posted by Simon TDI Sport
My first car was..
mk3 Ford Escort 1.3L in silver.
Picture of dead front door speaker.
Exactly the same happened to front passenger speaker on mine. Replaced with OEM.
- Android 13 dab radio
Retrofit Auto Lights
I'm not sure as it doesn't bother my son.
I fitted this one to my son's 2013 Monte Carlo https://www.aliexpress.com/item/1005006412538291.html?spm=a2g0o.order_detail.order_detail_item.3.6d86f19csjh7NF Works perfectly.
Amundsen+ (RNS315) firmware.
Does anybody have the firmware CD to update Amundsen+ or know where to download from? Thanks Simon.
Bought a Fabia Vrs 1.4 tsi.
Took the plunge and bought a fabia Vrs with the cave engine. Doesn't burn or use oil. Bit scruffy so need to tidy it up.
Amundsen+ firmware update.
Hi Guys, Does anyone know where I can get firmware download from. It's an Amundsen+ (RNS 315). 3T0 035 192 M SW 0324 HW H59
Traction control light and glow plug light
Need to get fault codes read before anything else. Then you can begin to look at what's happening.
Tires for 2017 L&K 220 Hatch
In currently running rainsport 5 on my superb. Done about 6000 on them at the moment and there wearing well.
Help with payment methods on a Samsung phone
Using Google wallet on a pixel 6 pro. Never had any problems in the last 2 years.
Cruise control fabia Monte Carlo tech
Thanks just what I wanted.
What's involved in fitting cruise control to Monte Carlo tech with 1.6 tdi 13 plate. I have VCDS and already made some changes.
CD Player
Can you not just copy the cd's onto a128 gb sd card. Assuming you got sd slots in the glovebox.
Android Auto
I've had this happen with my pixel 6 pro. You need to go to the AA app on your phone and clear the app cache and any app memory. Then reconnect your phone should work then. Also make sure it's updated to latest version.
Fog/cornering lights led
Have a look at Gizmo's pinned thread in main section first post about fog lights.
New Aliexpress Android Radio
You would probably better off with a Skoda amundsen+ with Bluetooth built in. Then you can connect your phone and Play music off your phone. You could also look herehttps://www.iceboxauto.com/filterSearch?q=Skoda+fabia&adv=false&cid=0&isc=false&pf=&pt=&sid=false.
SOS module faulty for five months. Garage blames Ukraine.
I believe there was a VAG factory in eastern ukraine that was bombed, that produced some modules. But they swapped to another factory somewhere in Germany.
my new(to me) nearly "poverty spec" Superb
Looks like a good one. You want to ask @ApertureS about the switch.
Got a problem with the DPF filter
Had the dpf light come on on my son's Monte carlo. I took it for an Italian tune up, down the motorway left it in 4th Gear get the revs between 2000 and 2500. Drove for about 1/2 he and get presto light went off. Simples.
Octavia 2 Estate rear wash hose split, wiper failure
It will be the wiper motor. It's well known that the design is C***. I had a 2006 octavia sport changed it two or three times.
Trying to remove cigarette socket near handbrake, help plz?
I put a twin usb socket in place of cigarette lighter. I loosened the screw for rear console remove cup holder cover. You can then lift up slightly and you should be able to push the socket up and remove to access the wiring. This was on my son's mk 2 monte carlo.
Wireless Android Auto Dongle recommendations for Amundsen
Have a look at this one https://www.aawireless.io/. I've fitted this to my MIB 2 Columbus not had any issues.
Skoda Yeti Infotainment System faulty touch screen
I would insist that the dealership replace the unit at there expense as they sold goods unfit for purpose. As you pointed out the fault to the salesman before taking the vehicle. Then they should rectify it.
2009 Fabia with coil light flashing
It's possible that it could just be a dirty contact. Try removing and spray with some wd40 and wipe it dry.
