Everything posted by andrehj
Front Facing Camera on a 2025 Skoda Superb Lauren & Klemin 200 diesel estate
The camera is located behind the windscreen. So most likely you don't have to replace the camera, but the windscreen. Or maybe it can be repaired with spot repair?
S2011 Superb 3T5 fast Idle
I would suspect the throttle valve (and throttle body). A good clean of those might solve the issue. But it can also be an air leak in any of the hoses of the inlet circuit. A smoke test will reveal the location of the leak.
Read fault codes?
Oil light - Am I blind?
All the lights are described in the manual. Is it listed in there?
- Headlight conversion for european driving - Skoda Superb II
2014 Superb Elegance AFS problem.
First: What is the question? Second: There are two link bars between the suspension and the sensor, one on the front left and one on the rear left.
High oil temperature
The quality of the answers will massively improve if you specify which engine your car has. The coolant temperature is not 90 °C, it's software that keeps the needle at 90 when in reality the coolant is anywhere between 70 and 110... With OBD software you can view the real coolant temperature.
4th clockspring in 2 years?!
When mounting a clock spring, it is extremely important to have to steering wheel position match the orientation of the clock spring. The clock spring can only handle the ~3 rotations of the steering wheel. If the clock spring was mounted one complete rotation offset from the position of the steering wheel, it will break very quickly.
H22 Buzzer Location
@mdauncey This movie shows the buzzer location and how to repair it: Location in the estate should be the same.
H22 Buzzer Location
@mdauncey Just checked Elsawin. H22 is the FRONT buzzer, and is located behind the dashboard. The rear buzzer is called H15, and according to Elsawin it is located on the rear ceiling, near the shark antenna. So I was wrong, it's not near the control module in the boot. Edit: confirmed here: https://www.briskoda.net/forums/topic/497949-access-rear-park-sensor-module/#findComment-5588456
Skoda Superb IV Check Engine light
Some brilliant designer (or accountant) decided not to fit these new 1.5 TSI evo 2 engines with a dipstick.... There is only the (apparently not so reliable) sensor. Luckily it seams that the dip stick of the this engine is the same as the one of the previous 1.5 TSI evo, and that the dipstick hole is still there, just covered with a blind plug. So I would recommend to retrofit a good old dip stick. Somebody even made a Youtube movie about this.
H22 Buzzer Location
Behind the dash you will only find the buzzer for the front sensors, which you do not have. The buzzer for the rear sensors is located in the right rear of the vehicle, most likely somewhere near the control module for those sensors, which is behind the right upholstery of the luggage compartment.
My 2008/9 Superb heated seat.
Have you ever had water in your car? I thought that the control module (relais) for the heated seats is below the seats, at the lowest point of the car interior. Any water will accumulate exactly at that control module. Brilliant design.... I would check that module. Maybe you can exchange left and right (don't know if they are the same, but seams logical), and check if the problem moves to the other seat.
- Electrical fault
Rear Door Control Module
Are you sure that module is broken? How was the diagnosis done? Usually a non-responsive door module is caused by broken wires in the wiring loom between the A-pillar and the front drivers' door.
Skoda superb 2014 universal water leaking
I've seen many reports of panoramic sunroofs which were internally leaking. A glue connection seems to come loose. The famous Youtube car techs "Die Autodoktoren" have reported about that problem a lot. This is their channel: https://www.youtube.com/@Autodoktoren/search?query=panoramadach And I believe it was this episode: https://www.youtube.com/watch?v=5JkoSx68HWw Also this episode shows exactly what I mean (at 10:20): https://youtu.be/1zeYVvnoXLc?si=THuWPRAVuaXY55jL&t=620
Alternator / battery dead, how to get car to garage?
If you run out of electric power while driving, the problem is the alternator. Get your battery charged asap to save it. Batteries don't like being discharged for a long time. This charger is my favourite: https://www.ctek.com/uk/battery-chargers-12v-24v/mxs-5-0-uk No idea if a full battery will last the 22 min to the garage... Do you want to risk stranding on a motorway? Exchanging an alternator is no rocket science. Instead of picking up your car on a tow-truck, maybe your garage can fix your car where it is now?
Headlamp ballast
Before randomly changing parts: Have you checked power and ground?
Petrol TSI 204/265hp questions
@JuSko Open the bonnet and you know. Intake manifold injecors can usually easily be seen.
Koni Special Active Shock Absorbers
@JamesBrown What's the mileage of your Superb? And did you fit the new Koni's yourself or did you have your garage do it? I'm thinking about fitting these Special Active shocks as well, but the ones needed for the front (8745-1038) are sold out everywhere. 😥
What gearbox oil- help please!
B.t.w.: I changed the oil in my DQ200 gearbox last December. See this thread in the Dutch Skodaforum.nl: https://www.skodaforum.nl/forum/i/oliewissel-dsg-versnellingsbak-dq200.50395/
Xenon ballast replacement without removing bumper?
Nice job, but I don't understand this sentence. Normally you remove the wheel, and remove the wheel liner (around 10 Tx25 screws). This is also a good opportunity to clean out all the dirt that collects behind the front wheel liners (between wheel and front door). Wasn't removing the wheel liner possible?
- Inside window horizontal scratches superb mk4
The correct oil type for your gearbox (not the Mechatronic!!) is G055512A2 (you need 1.7 liter). That is however not going to fix any clutch issues, since the clutch is dry, and completely separated from the gearbox and its oil.
How To Start an Octavia MK2 via the starter solenoid
If the clutch switch is the issue, can't you simply unplug (or bridge, depending on whether it's NO or NC) that switch?
