andrehj
Everything posted by andrehj
  1. New: Dealer or Skoda-parts.com (for around € 1100) Used: Scrap yard
  2. With an OBD diagnose you have an answer in a few minutes. I recently had something similar, which turned out to be a faulty ABS wheelspeedsensor. But it can be anything, and even if it is an ABS sensor, you still don't know which one without a diagnose.
  3. VCDS. See https://www.briskoda.net/forums/forum/23-diagnostics-amp-vcds/
  4. @nigelw I think it would be wiser to fix the missing cap (and moisture) issue first....
  5. That's correct, the picture above shows a subframe for 4WD. The question is whether this will also fit the 2WD version...
  6. @raul_allin As I thought, you're not right about the 4WD having the same subframe as the FWD version though. The online ETKA (https://ifinterface.com/prog/car/cp2/inprog.php) reveals it: FWD: 4WD:
  7. Ouch, that is quite severe. I painted mine two years ago since it started to develop rust, and I hate that. Currently it looks like this (picture taken from the right side):
  8. First a question: Why do you want to replace the subframe? If you know the the exact type number, you can look for that. My 2WD 2012 S2 has the 5N0505235Q, but that number was (according to my ETKA) only used until 27-05-2012, so yours will have a different number. And the 4WD models also have a different part.
  9. Thanks for the feedback, but this question might have received an answer if you'd specified which engine your car has... That info is also very relevant if somebody ever wants to use your feedback info.
  10. I've read a case (don't know where I read it though) of a wiring loom below the battery which got damaged. It's on my list to check if I ever have my battery removed. In your case that would be the first place I would look. Just remove the battery and the battery tray and the loom should be accessible.
  11. That's interesting! So the newer generation alarm units do not have these Varta 5/V200H batteries anymore, but simple standard AA-size batteries! That's good news. If my alarm ever breaks down (already from 2011, so fingers crossed), that might be a good reason to buy a new unit instead of trying to fix the old one. Too bad a new unit costs € 283...
  12. Please use the search function. There are already many threads about this subject: https://www.briskoda.net/forums/topic/355341-just-switched-from-18s-to-16s/ And more....
  13. @davehutch Have you ever mounted the battery from the eBay-ad above? They are still for sale, and still with the picture of @FatblokeVRS used in the TS of this topic. See https://www.ebay.co.uk/itm/403297455731. If yes, what were experiences? Very strange and suspicious that they advertise something without a picture of the item they are selling....
  14. Yes. If your car is from 2023, it's an S3, and you're in the wrong section.
  15. A rattling air box is definitely not common, this is the first time I read about in the last 15 years of experience with an S2. You'll have to find out exactly what is rattling and solve that. If you want usable tips, it might be an idea to tell a bit more about your Superb, especially the motor type and model year may be useful...
  16. @AliG81 and @PetrolDave This is the Superb 4 topic. And the Superb 4 (S4) only entered the market in the autumn of 2024. So you won't find any water ingress issues with 2023 models due to the very simple reason that no 2023 models of the Superb 4 exist...
  17. @Edwa That's only a very temporary fix! You clearly have the same issue with many (most?) of the other wires, which will also break soon. You may not like it, but you have to replace the entire loom.
  18. What's the source for the ET45 for 7.5J? The factory-fit 7Jx17" wheels have ET49...
  19. Hm, that's a strange combination. With the higher sidewall on the rear tires, it will tilt the car slightly (lift the rear). This will definitely change the steering geometry a bit as well. Not sure though whether that is the cause of your problems, but I would advise to test your car with four equal tires to see if that changes anything. Have you ever compared your S2 to another S2, preferably with (almost) the same tire dimension and engine?
  20. The S4 only entered the market in late 2024, so you won't find any problems with 2023 models...
  21. @GoneToBeemer Panoramic roof problems never occur on new cars, which an S4 is. You only see them on older cars. So most likely nobody in an S4 already has problems.
  22. @Outfoxed Sorry, no help, but never use a torque wrench to unscrew things. It will ruin your torque wrench calibration. Use the proper tools for the job.
  23. The active TPMS (with sensors in the wheel) is optional for the Mk4 Superb. Most do not have it (and use the ABS sensors).
  24. The satnav update policy of manufacturers is nothing less than ridiculous. Cars last at least 15 years, and providing these updates is technically no problem at all. This is where the EU should step in, by simply demanding updates for such periods (instead of making al these stupid Advanced Driver Assistance Systems mandatory, which only made cars more expensive, and most small cars EOL).
  25. Thanks for the very good report 👍. Inspecting the wire loom at that position should be standard practice when changing the battery. If I had know this I would have carefully inspected that location last year when I replaced my DSG oil (which required removing the battery and the tray below it).
