What happens if you charge a car with a '7kw on board charger', from a domestic 13 amp supply?
While you find something to do for the remaining 3 hours 59 minutes and 50 seconds... If you're on a long drive that's a lot longer than it takes for a comfort and snack break. If it's in a town that's a lot of shopping buying things you don't want/need.
Is it SATNAV or not
Correct, provided the in car infotainment system supports CarPlay (if you have an iPhone) or Android Auto (if you have an Android phone) so the maps can be seen on the car screen. I used to live in North Devon where many of the roads I used regularly had zero mobile coverage and by downloading maps onto the Google maps app on my iPhone I had maps 100% of the time - Apple maps does not have the ability to download maps so was pretty useless in that area (and also when on holiday in the mountains of Maine in the US where mobile coverage was virtually non-existent).
Continental Eco Contact 6 durability / alternatives
The Eco Contact tyres have a hard compound, like all eco tyres, which means they are 'supposed' to last longer but at the cost of grip - so them performing poorly in snow is expected IMHO. My preferred tyres are Good Year F1 or if budget/longevity is more important Vredestein Quatrac - I got over 15000 miles on both of those on my previous Audi RS4 compared to less than 9000 miles on Pirelli PZero.
Is it SATNAV or not
Not if you use Google maps (which I do on my iPhone using CarPlay), because it has the option to download maps while on WiFi at home. The only thing you lose without a mobile signal is the latest traffic data, but that will download when mobile coverage is restored. I have downloaded maps covering England south of Manchester, which covers all of my current trips - when we go on holiday to Scotland later in the year I'll download maps for the rest of England & Scotland then.
About to change wipers for the front, Recommendation needed.
I always use Bosch wiper blades.
Technical Bulletin about parasitic current draw measurement
When the car is unlocked many of the electronic modules stay awake only going to sleep when the car is locked, so to minimise current drain the car should always be locked when left unused for a long(ish) time.
Should the brake fluid be replaced when a rear brake calliper is replaced by a Skoda dealer?
Normally it just needs to be topped up, however if the dealer checks the brake fluid for water content they may advise replacing the brake fluid but IMHO they shouldn't replace the brake fluid (and charge you for it) without asking permission.
Maybe the design of the chargers needs to have a tweak to automatically physically eject the charger plug when the charge rate drops to the point were it's clear that the vehicle is fully charged (or maybe even 90% charged)? That would stop charger hogging.
2015 Octavia - ACC and Front Assist not available - VCDS codes interpretation help
Check out the steering angle sensor fault, without steering angle info the ACC and Front Assist will be disabled. It's a bit difficult to advise further as your cable (HEX-USB+CAN?) doesn't support the longer CAN bus messages that VAG introduced a few years ago (hence the comments about more information not available), you need a newer cable like a HEX-V2 to get complete diagnostic information - no the HEX-USB+CAN can't be software updated there's just no room for more software updates in the cable!
Latest software update
The screen between gauges is NOT part of the infotainment, it's part of the instruments and is controlled by the software in module 17 not 5F. Head unit is another term often used for the main unit of the infotainment behind the dash.
Straightlining roundabouts?
I think as well as the "Think Bike" signs that you see on popular roads (e.g. A32 south of Alton) there should be "Think Car" signs too, on several occasions a bike pulling in after a risky overtake has caused me to brake sharply as it pulls in in front of me - defensive riding and defensive driving should be equally promoted.
Reports say that many company PHEV vehicles are returned at the end of lease with the charging cable still sealed in the plastic bag it was put in at the factory. https://www.autoexpress.co.uk/car-news/105206/fleet-owned-plug-in-hybrids-may-never-have-been-charged If those reports are correct then it would seem that there is a 'tax dodging' minority(?) of company car drivers - with the beneficial BIK rates for hybrids it's not surprising that hybrids are chosen.
Thinking of buying a small Skoda
I would suggest looking at the Fabia, it's of a very similar size to your Clio.
I suppose it depends on your definition of 'major changes' - a change to the engine ECU SW or gearbox ECU SW or front radar ECU SW (amongst others) will have IMHO a 'major change' in the behaviour of the car but none of those will be reported in the infotainment SW version.
I've posted that several times on here, but people continue to post the infotainment software version number - seemingly without understanding/caring that their car has maybe 30+ different processor controlled modules all with their own software versions that are not reported in the infotainment system. You can take a horse to water but you cannot make it drink 😠
DSG gearbox emergency mode
Translation - no fault codes appeared on ODIS so we don't know what to do.
Wireless Carplay not working
Sounds like the coding is now being set wrong in the factory as so many recent build cars have WiFi disabled and missing from the menu?
Adaptive Cruise Control bug
Most media companies are dependent on the advertising revenue from car manufacturers, so they have to be "careful" in their criticism of cars on test. CAR magazine used to be (no longer a subscriber so cannot comment on current situation) more concerned about accurate writing and have lost advertising contracts because of it.
Delivery times?
Unless you live in Japan and want a Land Cruiser when the wait is 4 YEARS https://www.carscoops.com/2022/01/toyota-confirms-there-is-a-four-year-wait-list-for-the-land-cruiser-in-japan/
Start Stop not working
Not sure if this is relevant - wasn't there a spate of reports on here in the last couple of years of a faulty batch of Moll batteries that were replaced under warranty?
At least it was honest
Upgrade MFSW
Have you made any coding changes with e.g VCDS or OBD11 to try to enable the CC?
Skoda production?
Yes, in fact the longest production delays on the Octavia 4 are on the hybrids, the latest info on the Octavia 4 forum here is that hybrids have an estimated production delay of 18 MONTHS - longer than any of the ICE versions.
Been mentioned several times in this forum, seems that the car randomly thinks it's in a country where they drive on the right so it thinks you're trying to undertake not overtake.
DAB has not worked properly since I brought the car from new 2018
The switch mode voltage regulator in some of those can generate so much interference (radiated as well as conducted which is why the ferrite cores don't always cure the problem) that it completely drowns out the DAB signal.
