What would you change about your Octavia?
We have a coolbox that we use in the boot, if the socket went off with ignition it would be a real PITA especially when in a really hot climate (e.g. south of France). The battery management will turn the sockets off to protect the battery if necessary so it won't flatten the battery enough to prevent starting the engine.
Lost: marbles
Create an account, login, pay for shortest access possible, enter your VIN, download EVERY document you see as a PDF onto local hard drive.
Conversion from left hand to right hand driving
RHD cars always get an "after thought" conversion, the majority of worldwide sales are LHD cars and that's how cars are initially designed. On some the conversion is OK, some it's poor and some it's downright bad.
Display Blank on Media Unit
Since it's an aftermarket screen take a look at the labels on it when you've got it out, then we'll all stand a chance of knowing what it is. I'm wondering if a previous owner fitted a different screen along with a "black box" for either navigation or DVD playing or WHY?
Which Camper Van?
Owning a camper van only makes some sort of financial sense if you use it at least once a month for weekends away, maybe alone or at a club (e.g. Caravan Club) meet, as well as for main holidays, half-terms, etc.
Adjust camber?
I would have thought that the specs for the Octavia II and Octavia III would be different. Worth going back and pointing out the error to them?
bonnet lifters
I fitted those 4 years ago (with extra washers) and they are still working great.
Adjust camber?
The printout says Octavia II specs have been used, but presumably you have an Octavia III?
Will decat pass an MOT?
If the MOT tester thinks the cat has been removed and (maybe or, not 100% sure) the emissions don't meet the limits for a cat-fitted car then it will fail.
List of VCDS Owners (Previously known as VAG-COM) & VCP Owners
A bug fix that only affects a small number of vehicle types.
Which Camper Van?
I well remember sleeping in the roof bunk of a Commer Dormobile and waking up in the morning to see ice on the inside of the pop-up roof above my bunk! For me good insulation (possibly double glazed windows), a fire, a hob, a chemical loo (with a separate waste tank not an all-in-one) and a solid roof (probably a high top) are the essentials in a camper van.
Which Camper Van?
I can recommend the NC500 having done it twice in a camper van - the scenery is awesome!
Esc and traction control speed threshold
If you only have those options then you cannot change the ESC mode. My 1.4 Elegance didn't use to have the option for ESC Sport so I changed the coding of the ABS module with VCDS to add them, al I had to do was change byte 29 of the ABS coding from 02 to 09. I now have 3 options: ESC On, ASR Off & ESC Sport.
Which Camper Van?
Definitely agree with the advice to hire first so you can work out what YOU need in terms of space and facilities. I started out in the mid-1970s with a Commer Dormobile but soon got frustrated with the lack of space and lack of loo facilities so gradually upgraded via an Auto-Sleeper Talisman (luton style coach built) to eventually a Hymer S650 (A class) as we wanted all the creature comforts and ability to use it year round.
Trouble at early test stage
They will likely ask you to post a picture of the cable showing the serial number - would be good to post the picture here too.
Independent Servicing West Sussex / Hants area?
When we lived in Southampton I always used to take not only our Skodas but also my Audi RS4 to Abtech AVSS http://www.abtechavssltd.com/ who are based in Totton.
No dedicated HVAC controls
I think many people would be happy if you could post a short How-To guide
Rear hissing noise
Fuel pump?
Satnav voice guidance - A and B road numbers
The sat nav pronounces road numbers like Americans would, hence the A one hundred twenty three etc. - it did this on my previous Audi too, so I've just got used to this "foible". Place names are pronounced phonetically not as locals would, other examples I know of that are pronounced very strangely are Bicester and Fareham.
Simple and effective phone mount
That's Android Auto - on MIB2 infotainment systems which were factory fitted to cars made after May 2015.
Austin Allegro V6 Street sleeper project by Jonny Smith Car Pervert.
Hope it's got a genuine "Quartic" steering wheel
09-Cent. Elect. Missing.
Access to a module is different to being able to change coding As I said there is NO CODING (look at your Auto-Scan there is no line for coding in 09), all changes have to be made via 10 Adaptation. Try looking at the stickies at the top of the Octavia III forum on here, you will find threads about changes that can be made to FL models like yours.
No SD Card Slots
Some do but not all, for those you need to be able to add then from e.g. USB stick (as you could on the Octavia III).
Help with my FOB Keys
What was the expiry date on the "new" batteries? It's pretty common on here for owners to report fitting "new" batteries and them not working - it appears that the "new" batteries have a high internal resistance and even though their open circuit voltage looks OK they are unable to supply the current needed to operate the key fob. Get new batteries of a reputable make from another retailer.
Your logs show that you CAN access the BCM at 09 but that it is the newer type that does not use long coding, every setup is by adaptation channels.
