PetrolDave
  1. I'm 99.99999999% certain it can't be done by a TCU coding change - whay would VAG include in the TCU firmware a feature they are never going to use? Their race & rally cars don't use production TCUs so there's no reason to include it. Of course a company that does TCU 'hacking' might be able to do it...
  2. It's not normally that simple - the shifter assembly usually has a normally open and a normally closed contact for each position (for safety and redundancy). Some investigation with a wiring diagram is needed I reckon. And what about the now incorrectly labelled trim - how to you plan to solve that?
  3. Here's the newest one I can find at the moment 5L0 051 236 AH
  4. Not quite all passenger cars - my previous Toyota Aygo with x-shift had the manual mode the right way round (forward to shift down, backward to shift up). To me this makes so much more sense since the G forces when accelerating or braking now work in your favour! I too would like my DSG Octavia to work this way, but I suspect that due to the redundant switching in the shifter assembly it will require more than just moving wires - and there's also the problem that the trim piece will show the now wrong +/- direction.
  5. Sounds like you have a MIB2 Amundsen - yu can get the 5L0 prefix SD card you need off auction sites such as eBay.
  6. I'm already running 2110, just wondered if VW have published a newer version without the traditional half year delay?
  7. When was the last MIB2 Amundsen fitted in production? Are we now past the 5 year limit that VAG have for map updates, if we are then there will not be any more MIB2 Amundsen map updates?
  8. It's been a topic of much discussion on here over the years (at least since 2016 to my knowledge) how different the advice from Skoda UK was to the rest of the VAG world. It's great that Skoda UK have fallen into line with the rest of the VAG world, but it took them far too long and it has cost UK Skoda owners a LOT of money in unnecessary cambelt changes - if this was the USA someone would be starting a Class Action case against Skoda UK!
  9. The 1.5 is a different engine type to the 2.0 in the vRS, so the recall doesn't apply.
  10. 4 identical glow plugs fitted, but the ECU expects glow plug 3 to have an additional pressure sensor - I think you've diagnosed the problem yourself?
  11. AFAIK that only applies to the TDI, and definitely not to the EA211 engine (1.4TSI and 1.5TSI).
  12. There is a LOT more than just a relay within J519, so the measurement you made is based on an incorrect assumption.
  13. Between which two points exactly? Remember the BCM isn't just a straight through connection - the input will go into a microchip and the output come from a microchip, so the BCM resistance will be very high.
  14. Please explain - if you have VCDS then you can do an Auto-Scan - even if it shows no fault codes the information will help.
  15. The use of a code was removed many years ago and replaced with component protection (which can only be removed by a dealer or an independent with online access to the VAG servers).
  16. Really? I suppose being Electronics Manager for an automotive consultancy hasn't equipped me with that information? I think you need to look in the mirror for someone who doesn't know how CAN bus systems work.
  17. Probably not, my L&K has an Amundsen (plus Canton) and AFAIK Columbus was still an option on L&K models.
  18. I'm not suggesting bypassing a fuse??? - just connecting the input of a fuse to a switched feed not an unswitched feed. BTW any lead that carries power is NOT CANbus, CANbus is data signals only.
  19. Need to know a lot more: - it appears you have a 2019 Octavia (is this correct?) - what model of infotainment unit was fitted? Swing, Amundsen, Columbus, ... - do you have Canton? - what vehicle did the unit you have fitted come from (make, model and year)? - what model of infotainment unit is it?
  20. No, remove the fuse for the 12V sockets and connect the output wire from the piggyback fuse (with its input connection connected to the input side of the switched fuse, so they are independently fused) to the output pin of the place where the 12V fuse was.
  21. I'm 99% certain there ARE ignition switched fuses, even with KESSY.
  22. Over the years on here I reckon I've seen equal numbers of owners wanting the sockets to be ignition switched or always live! Shame that Skoda don't offer it as an owner configurable choice via the infotainment system. However, it can be achieved by remvoing the fuse that powers the 12V sockets and replacing it with a piggyback fuse into an ignition switched slot - such as the rear wiper?
