Everything posted by Sanqhar
Fob battery
I have never had any warning of imminent key battery failure. My dealer changes the battery as a matter of course at each annual service. Battery failure is not a disaster. It happened to my wife when away from home. She phoned me and I talked her through the procedure to sort it out. It's in the Manual. Prise off the small cover on the underneath of the door handle. This reveals the key 'slot' then unlock the door the old fashioned way. This will set off the car alarm. Get in the car and press the starter button using the body of the key not your finger. This latter bit might take more than one attempt. tom
TMC traffic events no longer being received...firmware update required?
Noticed the lack of traffic information recently on my 2018 SeL. I don't hit traffic problems that often however I ventured into Essex, near Southend on Sunday and ended up with delays and roadworks on the A12. Nothing showed on the Nav screen. Just checked the car and... Radio>Advanced Settings>Dab Traffic Announcements is greyed out Nav>Map> Traffic Flow Setting is greyed out. I'll raise at at the next service that is due now. tom
Door warning lights
Sorry, when I do a search on this all I get is this current thread. Do you have a link? tom
Skoda Karoq Tyre alts from 19”
This may help: https://tiresize.com/comparison/ tom
225 55 18 on a Karoq
Only problem is the larger diameter which may cause the speedo to under read. This is illegal. Speedos can only over read and then by not more than 10%. tom
Karoq or Tiguan
Take a test drive, then decide. tom
1.5 TSI engine cover
Closer to the engine means it runs hotter, better for the particulate filter. tom
Axle Stands & Jacking
Sorry have I missed something? The video I get shows how to lower the car and the jack is not placed at the sill jacking points. How is this relevant to jacking a car at the proper sill jacking points and then putting the car on axle stands? tom
Karoq bonnet struts
...I suppose I'm just a bit reluctant to buy stuff from China. Silly really, half the stuff you buy in the UK is probably made in China anyway. tom
Sorry can't answer this question, but here is an observation. I had a problem using my small trolley jack on the specified jacking points. The head of the jack did not spread the load around the seam. I solved the problem by cutting a groove in an ice hockey puck. They are a hard rubber and not expensive. This idea may be useful with the axle stands. I'm curious why you need four wheels off the ground all at the same time? Good luck tom
How friendly is your dealer? See if they will let you have a look at the computer or even tell you what you need to fit the cover. tom
New sportsLine mirrors
Amazing. One hand covering the sensor, one hand holding the torch and one hand taking the picture! tom
DPF regeneration frequency
Have you tried using one of the better quality fuels like Shell V-Power. The different/extra additives in these make for a cleaner combustion. tom
Karoq cam belt change - start saving now !
Glad you have worked it out. I'm still lost! tom
Locking Wheel Nut?
...but https://kumhotyre.co.uk/kumho-news/should-you-fit-new-tyres-to-the-front-or-rear/ https://www.edentyres.com/should-i-fit-new-tyres-to-the-front-or-rear/ tom
Silica bag in header tank potential problem
Anyone come across the bag of silica crystals cooling problem in their Karoq? There is an article in the 1st March Car Mechanics (UK). Apparently a reader had the bag break causing cooling problems in their Ateca. There appears to be some posts here on Briskoda but mainly regarding Octavias. Another thread similar to the one mentioned in the article https://www.seatcupra.net/forums/threads/removing-silica-bag-from-coolant-header-tank.470769/ mentions a marking on the header tank 'Mit Silikat'. My Karoq's header tank doesn't have this marking. tom
My take is that the high cost compared to other cam belt changes is down to the cylinder deactivation. They are covering themselves for any extra stresses this puts on the pulleys and the belt as well as the extra labour involved because of all that technology. I think this has been said previously and deserves repeating. tom
Problem with selecting Driving Modes, other than Normal.
My SeL resets to normal every time the ignition is switched off, tom
Karoq space saver 2022
On a 2wd car it's a good idea not to put a skinny wheel on the front, too much torque will be put through it. Would you really want a skinny wheel on the front in an emergency braking situation? Put the skinny spare on a rear wheel and use the 'good' wheel taken off to replace the front punctured one. tom
Karoq SEL without rear tables on "build your own"
Cannot the tables be removed? Looks like they unscrew from underneath. Just need to work out how to cover the holes. tom
Check your engine oil level. Regens are made by extra diesel being injected into the engine. If these regens don't burn off this diesel then it runs down the bores into the engine thus diluting and raising the oil level. Not good. If this has happened you will also need an oil change. If a regen is occurring and you turn off the engine before it has finished the engine will be hot and often the cooling fan will remain running. After "the fix" my 2010 diesel Yeti did this regularly. I would then immediately restart and go for a decent 60/70 mph drive alternating between 3rd or 4th gear, not top gear, in order to burn off this extra diesel and complete the regeneration. Modern diesels are not designed for too many regular short journeys. This was the reason that when my driving pattern changed I got rid of my Yeti and bought a petrol Karoq. I am currently only doing around 5000 miles a year. tom
What have you done to your Karoq today?
I top up using filtered water and Skoda/VW/Audi washer fluid. I have done it this way since buying a new Passat in 1996. I would never use water straight out of the tap whatever the dilution with washer fluid. tom
Passenger Sun Visor for the Karoq 1.5 TSi 2019
Varooom is about right with the price. see: https://www.skoda-parts.com/spare-part/5g0857551aj2f4-sun-visor-left-skoda-35283.html https://skodapartsdirect.co.uk/product/skoda-karoq-drivers-sun-visor-2017-21/ the illustration show both driver and passenger. tom
Damp in front passenger footwell
Anyone know where the aircon drain is? If it is in that area then dry the carpet with a hair dryer and then turn OFF the aircon. If the carpet remains dry then you have isolated the problem. Similarly, dry the carpet and put water into the well underneath the wipers, nowhere else. Again this may help to isolate the problem. After the above, if the carpet is still dry then pour water over the windscreen and see what happens. tom
As said by Dappernut above clear the void between the rear of the bonnet and below the windscreen wipers, a good place for leaves to collect. tom
