varooom
Everything posted by varooom
  1. @Gratax You have PM, hopefully with video and document you can achieve success.
  2. I thought someone would have replied by now. Did you have a log of the fault? Each tool will kind of be better or worse than another.
  3. Yeah get it booked back in, and at least you now know there's an update. It might not help at all, but I am sure they will exhaust this possibility before escalating it to next level.
  4. @Tootickie I will check and send link in next few minutes.
  5. I think perhaps one of the flaps is stuck in a position or is needing re-calibration. Sadly I don't now the reset process for manual AC system. Did they scan any fault codes in the car when looking at your AC?
  6. Welcome 🤝
  7. Maybe more, but I have not entered it. Wiring diagrams depend on what your car has specification as to what is wired up. Should you take a picture of your quadlock and each connector wiring, then it can be decoded in time.
  8. Give me 10 minutes to double check software train compatibility.
  9. Do you have dual zone climate control? Does the temperature difference occur right away, or does it happen after 30mins or some other time value. What settings are on your climate controls (face, feet, window or auto)
  10. I have them all, but you need to narrow down the search. Hold down menu key a few seconds to enter hidden menu. Post back your Software Train details.
  11. I can only suggest you try to locate someone on your travels with VCDS or VCP from the map. https://www.briskoda.net/forums/topic/262215-list-of-vcds-owners-previously-known-as-vag-com-vcp-owners/
  12. MOI3_EU_SKMQB_P30603P is available, which is 0306 version. Nothing in the way of a changelog, but at least you can report back to dealers and you know there is an update. Your current firmware was released 2011-05-11 Newer firmware was released 2022-04-07
  13. You could try it sending in a support request to see if you are able to access the PDF's without issues/payments. https://erwin.skoda-auto.cz/erwin/showRequestSupport.do If they interpret your question correctly, then all good. A few years ago I did have issue getting any documents and it started my hour session, they looked into it and refunded the hour back as they could see I hadn't made any progress/downloads. Times have changed, but never know if you get issues, chances are you might get a refund. Family/friend with PC? Running a virtual machine on your Mac could be alternatives.
  14. As @Breezy_Pete mentioned. 1. Try it, might be just fine 2. See if you can purchase the ECU from donor engine, and sort immobiliser 3... See what anyone else can suggest
  15. Cannot add too much, other than the engine map between the 2 engine codes will maybe make your old ECU make engine run rough. Mainly for the fuel injection strategy being different between them.
  16. Take a few pictures if possible and attach. Then can get diagrams found nice and easy.
  17. I will tag @pab567 as he will probably be the best person to answer. He most likely has a unit that he can post from Poland that will be without Component Protection on, and he might be able to pre-activate android auto.
  18. I can send you the firmware to bring you up to 0369 version in a few minutes. After you can attempt to patch with MIB Toolkit (I presume?) to activate what you wish.
  19. And probably fitted to reflector style headlights too 🤔
  20. It's his MDI, media in socket for what he wished to plug in. https://skoda.7zap.com/en/cz/superb/sup/2011-632/0/051-51040/#4
  21. ...I like taking risks 🤣
  22. As @J.R. mentioned, you may wish to find VCDS member for a scan and report back.
