Everything posted by JR RS
Apple Carplay vs Bluetooth connectivity
It's the same for me - listening to Spotify via the car's Android Auto is much louder than listening to Spotify on the phone via Bluetooth. I've played around with the settings, no improvement.
I drive past a commercial building site on my way to work everyday - so I'm pretty sure where I'm getting my share of screws!!!
Android 11 & Android Auto Wireless
For the 4th time, since getting the car brand new 3.5 yrs ago, I've had to put on the spare tyre!!! Yup, I got screwed....again!!!
Aircon asymmetry...
16 degrees!!! Eesshhhh.
I've got an MIB2 unit, so no chance of it having wireless capability. Hence I too have signed up for an AAWireless unit. I'm looking forward to it as it will pair nicely with my wireless phone charging.
Superb 2017 or Octavia 2019?
I came from an MY11 Octavia RS liftback to my current MY17 Superb 220 liftback. The rear space for the kids & passengers is immensely more. The boot space, again, immensely more. Ease of driving the bigger Superb is still the same as wat the Octavia was. The Superb is a nice comfortable "cruiser", compared to the more sportier & firmer Octavia RS.
Gandalf's Evolution
It was relatively easy to do. The front cover unclips easily from the top, then unhinge from the bottom. The actual tray has two hinges at the bottom - the right side pops up, allowing u to slide the left side out. Then unclip the wire plug to the car, and u can then proceed to freely remove the 12V socket from the tray. The replacement USB socket fit perfectly in the existing hole.
Gandalf's Evolution
Completed the rear console 12v socket to a dual port USB. Was nice n simple to do. Clean finish. Happy with it
First car with TPMS. Do I need to change valves / sensors etc?
the indirect TPMS version is good and accurate. it uses the ABS sensors to determine "tyre pressure loss". the direct TPMS uses a sensor valve in each tyre to give u actual tyre pressure readings. the battery in the valve sensors have a 10 yr lifespan. i recently upgraded mine from the indirect to direct version, as per the link posted above by @MartiniB. standard/default Indirect Tyre Pressure Loss Indicator (Indirect TPMS) vs Direct Tyre Pressure Monitoring System (TPMS) not really. it cost me $200 to retrofit the direct tpms (OEM version) to my Superb. u can get much much cheaper direct tpms kits that use either a smartphone app, or a small unit that sits on ur dashboard, showing the readings. @MartiniB has got this version, and has provided links for it.
2018 Superb. How does Adaptive cruise, front assist, emergency brake, and blind spot work in real life?
Manoeuvre Assist was introduced from MY18 onwards, at least with the Superb. i have an MY17, and it didn't come with, or have the option for Manouevre Assist.
Manoeuvre Assist - "The integrated Manoeuvre Assist brake function detects obstacles in front of and behind the vehicle and automatically brakes if necessary."
Gandalf's Evolution
Removing the snow filter didn't make any difference to the power delivery or feel, or induction noise. It was more about knowing that having it removed would allow an uninterrupted airflow through the airbox. With the turbo inlet elbow - can't really say there was a noticeable difference on its own. In combination with the inlet pipe, and air filter - it definitely felt more eager. It didn't feel like hesitation, and would want to keep urging u on for more the car throttle also seems a bit more throatier. There is more induction noise. I like how the engine sounds now
My dash cam fitting
Fuse no. 48 is the blind spot detection. I used to. 47 (rear wiper). No issues with the dashcam, working only when there is ignition.
What was my car built with?
Wat @Winosaid. It's the only place that will give u a report of every PR code (item) from factory the car was built with, based on the VIN. I've done it myself.
206TSI AWD Wagon: Suspension
Link for the rubber insert. Link for Hardrace Rear swaybar for AWD. I got the FWD (7759) version. Very happy with it.
Gandalf's Evolution
@Colin170CRlol, now that u point it out, yeah, I've let that one slip The engine bay would certainly look much better with the hard plastic version how is it held in place though? Does it "stay" by simply sitting on top of the battery? With regards to the air intake cover - it's the standard factory one. All I did was stick the Superb lettering (that I debadged off the rear bootlid) on it, spaced out
Gandalf's Evolution
@Colin170CR - so i went away, much to my fear, and put some numbers against it!! wat was i thinking?!?!? lol end of day, it wasn't too bad. all up, over the 3.5 yrs, i've spent a total of $7k on the above modifications. most were cheap, small mods - but there were lots of them, so they added up. the "significant ones" were:- - Rieger side-skirts (total cost just under $1K to ship it across the world and have it painted. i fitted it myself) - Sportline rear diffuser (cost $420 in total. the shipping alone, cause Superskoda, cost more than half of the actual diffuser itself!! i fitted it myself) - Roof wrapped Gloss Black vinyl (cost me $450 to get it professionally wrapped) - Rear sway bar (cost me $330) - Eibach Prokit Lowering Springs (supply and fit cost me $900) - Smart Light Assist (SLA) retrofit (parts cost me $800. sold my original headlights. so total cost was just over $400) i've saved on a lot of labour costs by doing/fitting many things myself. i also invested in a VCDS cable, costing me $330, but i've done many many codings over the years. p.s. the doctor's don't want to see me - they say there is no hope for me!!!! p.p.s yes, planning to keep Gandalf for a while. we're both going to go grey n old together
Gandalf's Evolution
again, all installations/retrofits i did myself Technology/Lights Modifications - Start-stop memory device - Smart Light Assist (SLA) retrofit (P/N: 3V2941015B, 3V2941016B, 4H0941329 x2, 8P0941621) - Direct Tire Pressure Monitoring System (TPMS) retrofit (P/N: 5Q0907273B, 5Q0907275B x4, 3G0907538) - Dynamic Wing Mirror Indicators - Mega Power LED boot lights - Auxito LED bulbs - reverse and indicator bulbs. top = factory halogen bulb bottom = LED bulb - Lumileds LED fog light bulbs - Philips xTremeVision Gen2 D3S bulbs top = factory bulb bottom = Philips bulb - Rear door warning lights retrofit - SUPERB Ghost LED door warning lights, front & rear - Blackvue DR450 front dashcam - Rear console 12v socket converted to Dual USB ports (in progress)
Gandalf's Evolution
Mechanical Modifications - 034Motorsport Turbo Muffler Delete - CTS MQB Gen3 High-flow Turbo Inlet elbow - Torque Solution Turbo Inlet pipe - Modified air intake - unblocked air intake flap, additional holes in front of airbox - Snow Guard removal - aFe Magnaflow Air filter - Engine dust shield cover - ECS Atmospheric Diverter Valve Spacer (removed after 3 months)
Gandalf's Evolution
Handling Modifications - 15mm front & rear aluminum hub-centric spacers - 25.4mm Hardrace rear sway bar (P/N: HR7759) - Whiteline rear end-links (adjustable) (P/N: KLC202) left = whiteline right = factory - Eibach Prokit Lowering Springs (25mm) (P/N: 10-84-042-02-22) top = eibach bottom = factory - 034Motorsport Billet Aluminum MQB Lower Dogbone Mount Insert
Gandalf's Evolution
apart from painting of the side skirts, and wrapping the roof, I fitted/installed everything else. Exterior Modifications - Rieger side-skirts, color-coded (P/N: K00079041+ K00079042) - Black Fog light Frames - Sportline rear diffusor - Heko Wind Deflectors - Blackened (plasti-dip) front lower grille chrome bits - Spaced out SUPERB lettering, front & back - SUPERB fender badge - Roof wrapped Gloss Black vinyl - Chrome strip across rear lights and boot edge, like Facelift model - Chrome strip across lower door guard protector edge, like L&K models - Chrome strip across front bumper lower edge, like L&K models - Mudflaps, front (modified to accommodate side-skirts) & rear - Skoda tire valve caps - Aluminum alloy fuel cap cover - Stainless Steel door lock cover - Aluminum Boot Lid rear door sill - Chrome Door Handle Bowls - Lightly smoked tint rear tail lights - Lightly smoked tint fog lights - Sound deadening - boot floor, inside wheel arches (front & rear) - removed blocked brake duct in front wheel arches
Gandalf's Evolution
Interior Modifications - Chrome strip across dashboard. flexible chrome strip placed it between the silver trim and the black plastic. above the glovebox, and above the headlight switch. - Chrome rings on interior door handles flexible chrome strip wrapped around the top of all the door handles, as per the facelift Superb. - Aluminum alloy DSG paddle shifter extensions stick on ones. been 12 plus months. still solid and nice feel to it when pressing. - Chrome plated 12v socket cover - Stainless Steel footrest Accelerator & Brake Pedals - Chrome boot close button - Chrome Car Seat Memory Switch - Key bottom Chrome end tip RS6 style - SUPERB - Headrest multifunctional coat hanger - Rubber mat over rear tunnel
Gandalf's Evolution
decided it is finally time to catalog all the bits n pieces I've done to Gandalf (MY17 Superb 162TSi). its been 3.5 yrs, and a lot has been done, but u wouldn't think that looking at it. below is full listing of everything I've done. all things small, and some big. Geez - there is a LOT of things!!! I didn't realise how many until I listed each & every one of them them down!!! yes, I need an Intervention hence, this is going to b a long long post - u've been warned!! firstly - a summary of all the things done, including links. This will b followed by subsequent posts of pics, and details for some of the things. things I may, or may not, do in the near future:- - ECU Tune - TCU Tune - Front Strut brace - Front End-links - illuminated front door sills enjoy, cringe or look away........ Interior Modifications - Chrome strip across dashboard - Chrome rings on interior door handles - Aluminum alloy DSG paddle shifter extensions - Chrome plated 12v socket cover - Stainless Steel footrest Accelerator & Brake Pedals - Chrome boot close button - Chrome Car Seat Memory Switch - Key bottom Chrome end tip RS6 style - SUPERB - Headrest multifunctional coat hanger - Rubber mat over rear tunnel Exterior Modifications - Rieger side-skirts, color-coded (P/N: K00079041+ K00079042) - Black Fog light Frames - Sportline rear diffusor - Heko Wind Deflectors - Blackened (plasti-dip) front lower grille chrome bits - Spaced out SUPERB lettering, front & back - SUPERB fender badge - Roof wrapped Gloss Black vinyl - Chrome strip across rear lights and boot edge, like Facelift model - Chrome strip across lower door guard protector edge, like L&K models - Chrome strip across front bumper lower edge, like L&K models - Mudflaps, front (modified to accommodate side-skirts) & rear - Skoda tire valve caps - Aluminum alloy fuel cap cover - Stainless Steel door lock cover - Aluminum Boot Lid rear door sill - Chrome Door Handle Bowls - Lightly smoked tint rear tail lights - Lightly smoked tint fog lights - Sound deadening - boot floor, inside wheel arches (front & rear) - removed blocked brake duct in front wheel arches Handling Modifications - 15mm front & rear aluminum hub-centric spacers - 25.4mm Hardrace rear sway bar (P/N: HR7759) - Whiteline rear end-links (adjustable) (P/N: KLC202) - Eibach Prokit Lowering Springs (25mm) (P/N: 10-84-042-02-22) - 034Motorsport Billet Aluminum MQB Lower Dogbone Mount Insert Mechanical Modifications - 034Motorsport Turbo Muffler Delete - CTS MQB Gen3 High-flow Turbo Inlet elbow - Torque Solution Turbo Inlet pipe - Modified air intake - unblocked air intake flap, additional holes in front of airbox - Snow Guard removal - aFe Magnaflow Air filter - Engine dust shield cover - ECS Atmospheric Diverter Valve Spacer (removed after 3 months) Technology/Lights Modifications - Start-stop memory device - Smart Light Assist (SLA) retrofit (P/N: 3V2941015B, 3V2941016B, 4H0941329 x2, 8P0941621) (video) - Direct Tire Pressure Monitoring System (TPMS) retrofit (P/N: 5Q0907273B, 5Q0907275B x4, 3G0907538) - Dynamic Wing Mirror Indicators (video) - Mega Power LED boot lights - Auxito LED bulbs - reverse and indicator bulbs. (video) - Lumileds LED fog light bulbs - Philips xTremeVision Gen2 D3S bulbs - Rear door warning lights retrofit - SUPERB Ghost LED door warning lights, front & rear - Blackvue DR450 front dashcam - Rear console 12v socket converted to Dual USB ports (in progress) VCDS Coding Modifications - activated alarm chirp when locking/unlocking - enabled SLA (next level up from HBA) - activated eyelashes (requires SLA headlights) - activated Fog lights as Coming-Home/Leaving-Home - activated rear lights with DRLs - activated DRL menu in infotainment - activated Traffic Sign Recognition (TSR) - disabled tailgate beep - activated refuel quantity - activated traffic notifications (TMC) - disabled undertaking prevention - enabled High Beam Assist (HBA) memory - comfort indicator from 3 to 5 flashes - enabled instrument (dash) illumination at all times - Throttle change to direct - Engine Start button strobe effect (video) VCP Modifications - upload SLA parameter file for 4B Multi function module - upload TPMS parameter file for 65 Tire Pressure module
blind spot detection and rear traffic alert use the same radar, located inside the rear bumpers, one on each side. yes, its useful, and works well in real world situations.
